root/radiance/ray/doc/man/man1/rpict.1
Wed Oct 19 21:25:20 2022 UTC (2 years, 6 months ago) by greg
Changes since 1.27: +18 -1 lines
Diff to previous 1.27
Wed Oct 19 18:23:14 2022 UTC (2 years, 6 months ago) by greg
Changes since 1.26: +14 -14 lines
Diff to previous 1.26
docs: made use of "virtual" and "secondary" sources more consistent
Tue May 19 16:00:58 2020 UTC (4 years, 11 months ago) by greg
Changes since 1.25: +8 -6 lines
Diff to previous 1.25
Added remark to clarify what "resolution" means
Sun Jun 9 17:48:13 2019 UTC (5 years, 10 months ago) by rschregle
Changes since 1.24: +5 -9 lines
Diff to previous 1.24
Removed erroneous reference to (unsupported) -n in combination with -aC
Fri Jan 11 21:12:24 2019 UTC (6 years, 3 months ago) by greg
Diff to previous 1.23
Fixed incorrect wording on -lr option
Tue Mar 20 02:40:38 2018 UTC (7 years, 1 month ago) by greg
Diff to previous 1.22
Wrote rtpict program to run rpict as if it had a -n option
Fri Jan 26 18:30:27 2018 UTC (7 years, 3 months ago) by rschregle
Changes since 1.21: +5 -3 lines
Diff to previous 1.21
Documented treatment of contrib photons as global under rpict/rtrace
Wed May 18 12:45:55 2016 UTC (8 years, 11 months ago) by rschregle
Changes since 1.20: +28 -1 lines
Diff to previous 1.20
Updated man pages with pmap parallelisation and ooC options
Fri Jun 5 08:49:01 2015 UTC (9 years, 11 months ago) by rschregle
Changes since 1.19: +21 -11 lines
Diff to previous 1.19
Revised -am and -ab options, the latter defaulting to 1 in pmap mode
Tue May 26 10:00:46 2015 UTC (9 years, 11 months ago) by greg
Changes since 1.18: +1 -2 lines
Diff to previous 1.18
Tue Feb 24 19:39:26 2015 UTC (10 years, 2 months ago) by greg
Changes since 1.17: +63 -6 lines
Diff to previous 1.17
Tue Feb 18 12:13:38 2014 UTC (11 years, 2 months ago) by greg
Diff to previous 1.16
Sat Jan 25 18:27:39 2014 UTC (11 years, 3 months ago) by greg
Changes since 1.15: +4 -5 lines
Diff to previous 1.15
Fri Oct 8 22:08:26 2010 UTC (14 years, 6 months ago) by greg
Changes since 1.14: +8 -8 lines
Diff to previous 1.14
Tue Jan 26 04:42:16 2010 UTC (15 years, 3 months ago) by greg
Changes since 1.13: +4 -3 lines
Diff to previous 1.13
Corrected description of -lr option.
Mon Nov 10 19:08:17 2008 UTC (16 years, 5 months ago) by greg
Diff to previous 1.12
Tue Mar 11 02:21:45 2008 UTC (17 years, 1 month ago) by greg
Changes since 1.11: +11 -3 lines
Diff to previous 1.11
Tue Sep 4 17:36:41 2007 UTC (17 years, 8 months ago) by greg
Changes since 1.10: +6 -6 lines
Diff to previous 1.10
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
Tue Jun 14 03:34:14 2005 UTC (19 years, 10 months ago) by greg
Diff to previous 1.9
Had to change new -R rendering option to -u to avoid conflict with rpiece
Mon Jun 13 20:07:55 2005 UTC (19 years, 10 months ago) by greg
Changes since 1.8: +7 -1 lines
Diff to previous 1.8
Tue May 31 18:01:08 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.7: +20 -4 lines
Diff to previous 1.7
Thu Apr 14 18:04:12 2005 UTC (20 years ago) by greg
Changes since 1.6: +10 -10 lines
Diff to previous 1.6
Wed Feb 16 05:40:06 2005 UTC (20 years, 2 months ago) by greg
Diff to previous 1.5
Tue Jan 18 01:13:23 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.4: +4 -1 lines
Diff to previous 1.4
Added comment about -vd length being used by -pd option
Tue Jan 18 00:33:15 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.3: +19 -2 lines
Diff to previous 1.3
Thu Jan 1 19:31:45 2004 UTC (21 years, 4 months ago) by greg
Tue Dec 9 15:59:07 2003 UTC (21 years, 5 months ago) by greg
Fixed RCSid specification
Tue Mar 11 19:20:21 2003 UTC (22 years, 1 month ago) by greg
Added documentation to repository
