--- ray/doc/man/man1/robjutil.1 2021/03/12 18:32:33 1.6 +++ ray/doc/man/man1/robjutil.1 2021/04/15 23:51:04 1.7 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: robjutil.1,v 1.6 2021/03/12 18:32:33 greg Exp $" +.\" RCSid "$Id: robjutil.1,v 1.7 2021/04/15 23:51:04 greg Exp $" .TH ROBJUTIL 1 3/31/20 RADIANCE .SH NAME robjutil - operate on Wavefront .OBJ file @@ -37,13 +37,9 @@ will be produced on the standard output. If .I -r is given, a modified .OBJ file will be sent to the standard output. -This is the default, and is -typically more useful, since surface normals are better handled by the -.I obj2rad(1) -and -.I obj2mesh(1) -converters. -The latter also preserves local texture coordinates for mapping materials. +This is the default, and is more useful for preserving +texture coordinates if directed to +.I obj2mesh(1). .PP The .I +v @@ -136,10 +132,6 @@ To remove degenerate and duplicate faces from "orig.ob .IP "" .2i robjutil +r orig.obj > final.rad .PP -To convert the same file, preserving surface normal interpolation: -.IP "" .2i -robjutil orig.obj | obj2rad > withnormals.rad -.PP To extract only the groups "cat" and "bell" from the file "kitty.obj" and write to a Radiance triangle mesh using materials from "kitty.mat": .IP "" .2i @@ -181,4 +173,4 @@ still possible to assign materials by group manually. .SH AUTHOR Greg Ward .SH "SEE ALSO" -cat(1), obj2mesh(1), obj2rad(1) oconv(1), xform(1) +cat(1), genbox(1), gensurf(1), obj2mesh(1), obj2rad(1) oconv(1), xform(1)
