--- ray/doc/man/man1/robjutil.1 2020/03/30 18:28:35 1.1 +++ ray/doc/man/man1/robjutil.1 2023/01/31 16:29:19 1.8 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: robjutil.1,v 1.1 2020/03/30 18:28:35 greg Exp $" +.\" RCSid "$Id: robjutil.1,v 1.8 2023/01/31 16:29:19 greg Exp $" .TH ROBJUTIL 1 3/31/20 RADIANCE .SH NAME robjutil - operate on Wavefront .OBJ file @@ -18,6 +18,10 @@ robjutil - operate on Wavefront .OBJ file .B "+/-g gname" ][ .B "-c epsilon" +][ +.B +T +][ +.B "-x 'xf spec'" ] [ .B input.obj .. @@ -33,13 +37,10 @@ will be produced on the standard output. If .I -r is given, a modified .OBJ file will be sent to the standard output. -This is the default, and is -typically more useful, since surface normals are better handled by the -.I obj2rad(1) -and -.I obj2mesh(1) -converters. -The latter also preserves local texture coordinates for mapping materials. +This is the default, and is more useful for preserving +texture coordinates if directed to +.I obj2mesh(1). +.PP The .I +v option turns on verbose progress reports. @@ -73,6 +74,7 @@ The and .I \+m options are mutually exclusive. +.PP Similarly, the .I "\-g gname" option says to remove all faces belonging to the group @@ -83,10 +85,17 @@ options may be given. There is also a .I +g option to save just the named group(s). +Object statements are treated the same as group statements in the input, so +.I +/-g +option can also be applied to object names. +Note that an object name will be overridden by a group name that follows +it in the input, and vice versa. .PP -Finally, a +The .I "\-c epsilon" -parameter may be given to coalesce vertices that are within the given epsilon. +option tells +.I robjutil +to coalesce vertices that are within the given epsilon. This is useful to improve the connectivity of models that were produced in a sloppy conversion process from independent polygons. When producing a Radiance file via the @@ -98,20 +107,69 @@ at least for triangle mesh input. does not attempt to break up non-planar polygons into triangles, which is usually not a problem for .OBJ output, but may be for Radiance scene descriptions (+r). +To break all surfaces into triangles, include the +.I +T +option. +.PP +The +.I \-x +option may be used to specify a final transform to apply to all +coordinates in the file before output. +This specification must be contained in a single quoted word and +match the standard arguments used by +.I xform(1), +except that the +.I \-a +option is not supported for creating arrays of objects. +Also, any scaling factors do not affect the epsilon value given for +coalescing vertices, as this operation is applied prior to the transform, +even if +.I \-c +appears later in the command line. .SH EXAMPLES To remove degenerate and duplicate faces from "orig.obj" and write to "final.rad": .IP "" .2i robjutil +r orig.obj > final.rad .PP -To convert the same file, preserving surface normal interpolation: -.IP "" .2i -robjutil orig.obj | obj2rad > withnormals.rad -.PP To extract only the groups "cat" and "bell" from the file "kitty.obj" and write to a Radiance triangle mesh using materials from "kitty.mat": .IP "" .2i robjutil +g cat +g bell kitty.obj | obj2mesh -a kitty.mat > kitty.rtm +.PP +To rotate the scene 90 degrees about the Y-axis and scale by 10: +.IP "" .2i +robjutil -x "-ry 90 -s 10" orig.obj > transformed.obj +.SH NOTES +The .OBJ output of +.I robjutil +uses relative indices, so files it produces may be concatenated +on the input of other tools such as +.I obj2rad +and +.I obj2mesh +by piping from +.I cat(1) +or similar. +This offers a convenient way to separate geometry from a single .OBJ +input, manipulate it in some way, then recombine during conversion. +.PP +Unlike +.I obj2rad +and +.I obj2mesh, +.I robjutil +with the +.I +r +option will not substitute the group name for a material id if no +.I usemtl +statements are found on the input. +Instead, it will assign each surface the material +.I DEFAULT_MATERIAL. +Since it is possible to use the +.I +/-g +option to select groups to include or exclude on output, it is +still possible to assign materials by group manually. .SH AUTHOR Greg Ward .SH "SEE ALSO" -obj2mesh(1), obj2rad(1) oconv(1), xform(1) +cat(1), genbox(1), gensurf(1), obj2mesh(1), obj2rad(1) oconv(1), xform(1)
