root/radiance/ray/doc/man/man1/robjutil.1
Revision: 1.3
Committed: Thu Apr 2 20:50:59 2020 UTC (5 years, 2 months ago) by greg
Changes since 1.2: +6 -4 lines
Minor wording changes
1 .\" RCSid "$Id: robjutil.1,v 1.2 2020/04/02 20:44:15 greg Exp $"
2 .TH ROBJUTIL 1 3/31/20 RADIANCE
3 .SH NAME
4 robjutil - operate on Wavefront .OBJ file
5 .SH SYNOPSIS
6 .B robjutil
7 [
8 .B +/-r
9 ][
10 .B +/-v
11 ][
12 .B +/-t
13 ][
14 .B +/-n
15 ][
16 .B "+/-m mname"
17 ][
18 .B "+/-g gname"
19 ][
20 .B "-c epsilon"
21 ][
22 .B "-x 'xf spec'"
23 ]
24 [
25 .B input.obj ..
26 ]
27 .SH DESCRIPTION
28 .I Robjutil
29 reads and manipulates a Wavefront .OBJ file, removing degenerate and
30 duplicate faces.
31 If the
32 .I +r
33 option is specified, a Radiance scene description
34 will be produced on the standard output.
35 If
36 .I -r
37 is given, a modified .OBJ file will be sent to the standard output.
38 This is the default, and is
39 typically more useful, since surface normals are better handled by the
40 .I obj2rad(1)
41 and
42 .I obj2mesh(1)
43 converters.
44 The latter also preserves local texture coordinates for mapping materials.
45 The
46 .I +v
47 option turns on verbose progress reports.
48 .PP
49 The
50 .I \-t
51 option tells
52 .I robjutil
53 to remove texture coordinates from the input.
54 The
55 .I \-n
56 option will cause all surface normals to be removed.
57 .PP
58 The
59 .I "\-m mname"
60 option tells
61 .I robjutil
62 to remove all faces that use the material
63 .I mname.
64 Multiple
65 .I \-m
66 options may be given, each with a single (unique) material name.
67 Alternatively, the
68 .I "+m mname"
69 option may be used to specify a material one wishes to keep, discarding the rest.
70 Multiple
71 .I +m
72 options will keep all the named materials.
73 The
74 .I \-m
75 and
76 .I \+m
77 options are mutually exclusive.
78 Similarly, the
79 .I "\-g gname"
80 option says to remove all faces belonging to the group
81 .I gname,
82 and multiple
83 .I \-g
84 options may be given.
85 There is also a
86 .I +g
87 option to save just the named group(s).
88 .PP
89 The
90 .I "\-c epsilon"
91 option tells
92 .I robjutil
93 to coalesce vertices that are within the given epsilon.
94 This is useful to improve the connectivity of models that were produced
95 in a sloppy conversion process from independent polygons.
96 When producing a Radiance file via the
97 .I +r
98 option, there will be no savings in the output size, but there can be
99 a benefit in reducing the number of "cracks" in the resulting geometry,
100 at least for triangle mesh input.
101 .I Robjutil
102 does not attempt to break up non-planar polygons into triangles,
103 which is usually not a problem for .OBJ output, but may be for Radiance
104 scene descriptions (+r).
105 .PP
106 The
107 .I \-x
108 option may be used to specify a final transform to apply to all
109 coordinates in the file before output.
110 This specification must be contained in a single quoted word and
111 match the standard arguments used by
112 .I xform(1),
113 except that the
114 .I \-a
115 option is not supported for creating arrays of objects.
116 Also, any scaling factors do not affect the epsilon value given for
117 coalescing vertices, as this operation is applied prior to the transform,
118 even if
119 .I \-c
120 appears later in the command line.
121 .SH EXAMPLES
122 To remove degenerate and duplicate faces from "orig.obj" and write to "final.rad":
123 .IP "" .2i
124 robjutil +r orig.obj > final.rad
125 .PP
126 To convert the same file, preserving surface normal interpolation:
127 .IP "" .2i
128 robjutil orig.obj | obj2rad > withnormals.rad
129 .PP
130 To extract only the groups "cat" and "bell" from the file "kitty.obj" and
131 write to a Radiance triangle mesh using materials from "kitty.mat":
132 .IP "" .2i
133 robjutil +g cat +g bell kitty.obj | obj2mesh -a kitty.mat > kitty.rtm
134 .PP
135 To rotate the scene 90 degrees about the Y-axis and scale by 10:
136 .IP "" .2i
137 robjutil -x "-ry 90 -s 10" orig.obj > transformed.obj
138 .SH AUTHOR
139 Greg Ward
140 .SH "SEE ALSO"
141 obj2mesh(1), obj2rad(1) oconv(1), xform(1)
