root/radiance/ray/doc/man/man1/robjutil.1
Tue Jan 31 16:29:19 2023 UTC (2 years, 5 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 1.7: +3 -4 lines
Diff to previous 1.7
docs(robjutil): improved clarity on +T option
Thu Apr 15 23:51:04 2021 UTC (4 years, 2 months ago) by greg
Changes since 1.6: +5 -13 lines
Diff to previous 1.6
Fri Mar 12 18:32:33 2021 UTC (4 years, 3 months ago) by greg
Changes since 1.5: +7 -1 lines
Diff to previous 1.5
Added +T option to triangulate all faces with 4 or more sides
Fri Apr 3 02:45:13 2020 UTC (5 years, 3 months ago) by greg
Changes since 1.4: +8 -1 lines
Diff to previous 1.4
Added some notes about object and group statements being treated the same
Fri Apr 3 02:32:58 2020 UTC (5 years, 3 months ago) by greg
Changes since 1.3: +32 -2 lines
Diff to previous 1.3
Added some application notes
Thu Apr 2 20:50:59 2020 UTC (5 years, 3 months ago) by greg
Changes since 1.2: +6 -4 lines
Diff to previous 1.2
Minor wording changes
Thu Apr 2 20:44:15 2020 UTC (5 years, 3 months ago) by greg
Changes since 1.1: +24 -2 lines
Diff to previous 1.1
Added -x option to robjutil to transform .OBJ files
Mon Mar 30 18:28:35 2020 UTC (5 years, 3 months ago) by greg
