root/radiance/ray/doc/man/man1/rmtxop.1
Revision: 1.36
Committed: Fri Apr 4 18:06:48 2025 UTC (2 months, 1 week ago) by greg
Changes since 1.35: +9 -3 lines
# User Rev Content
1 greg 1.36 .\" RCSid "$Id: rmtxop.1,v 1.35 2025/03/27 01:26:55 greg Exp $"
2 greg 1.23 .TH RMTXOP 1 5/31/2014 RADIANCE
3 greg 1.1 .SH NAME
4 greg 1.10 rmtxop - concatenate, add, multiply, divide, transpose, scale, and convert matrices
5 greg 1.1 .SH SYNOPSIS
6     .B rmtxop
7     [
8     .B \-v
9     ][
10 greg 1.3 .B \-f[afdc]
11 greg 1.1 ][
12 greg 1.27 .B "\-C {symbols|file}"
13 greg 1.1 ][
14 greg 1.25 .B "\-c ce .."
15     ][
16 greg 1.1 .B "\-s sf .."
17     ][
18 greg 1.27 .B \-t
19     ][
20 greg 1.22 .B "\-rf|\-rb"
21 greg 1.1 ]
22     .B m1
23     [
24 greg 1.13 .B ".+*/"
25 greg 1.1 ]
26     .B ".."
27     .SH DESCRIPTION
28     .I Rmtxop
29 greg 1.10 loads and concatenates or adds/multiplies/divides
30     together component matrix files given on the command line.
31 greg 1.28 Each file must have a header containing the following metadata:
32 greg 1.1 .sp
33     .nf
34     NROWS={number of rows}
35     NCOLS={number of columns}
36     NCOMP={number of components}
37 greg 1.24 FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_xyze|Radiance_spectra}
38 greg 1.25 .fi
39 greg 1.1 .sp
40     The number of components indicates that each matrix element is actually
41 greg 1.34 composed of multiple channels, most commonly an RGB triple.
42 greg 1.1 This is essentially dividing the matrix into planes, where each component
43     participates in a separate calculation.
44     If an appropriate header is not present, it may be added with a call to
45     .I rcollate(1).
46     A matrix may be read from the standard input using a hyphen by itself ('-')
47     in the appropriate place on the command line.
48 greg 1.28 Similarly, any of the inputs may be read from a command
49 greg 1.9 instead of a file by
50     using quotes and a beginning exclamation point ('!').
51     .PP
52 greg 1.1 Two special cases are handled for component matrices that are either
53 greg 1.20 XML files containing BSDF data, or Radiance picture files.
54     In the first case, the BSDF library loads and interprets the
55     transmission matrix by default.
56     Alternatively, the front (normal-side) reflectance is selected if the
57     .I \-rf
58     option precedes the file name, or the backside reflectance if
59     .I \-rb
60     is specified.
61 greg 1.9 (XML files cannot be read from the standard input or from a command.)\0
62 greg 1.1 In the second case, the RGBE or XYZE values are loaded in a 3-component
63     matrix where the number of columns match the X-dimension of the picture, and
64     the number of rows match the Y-dimension.
65     The picture must be in standard pixel ordering, and the first row
66 greg 1.7 is at the top with the first column on the left.
67 greg 1.21 Any exposure changes that were applied to the pictures before
68 greg 1.18 .I rmtxop
69     will be undone, similar to the
70 greg 1.19 .I pcomb(1)
71 greg 1.18 .I \-o
72     option.
73 greg 1.24 Radiance spectral pictures with more than 3 components are also supported.
74     These are typically produced by
75     .I rtrace(1)
76     or
77     .I rfluxmtx(1).
78 greg 1.1 .PP
79 greg 1.28 Before each input, the
80 greg 1.1 .I \-t
81     and
82 greg 1.25 .I \-c
83     and/or
84 greg 1.1 .I \-s
85     options may be used to modify the matrix.
86     The
87     .I \-t
88     option transposes the matrix, swapping rows and columns.
89     The
90     .I \-c
91 greg 1.25 option can "transform" the element values, possibly changing
92 greg 1.1 the number of components in the matrix.
93     For example, a 3-component matrix can be transformed into a single-component
94     matrix by using
95     .I \-c
96     with three coefficients.
97     A four-component matrix can be turned into a two-component matrix using 8
98     coefficients, where the first four coefficients will be used to compute
99     the first new component, and the second four coefficients
100     yield the second new component.
101     Note that the number of coefficients must be an even multiple of the number
102     of original components.
103 greg 1.27 .PP
104     Alternatively, a set of symbolic output components may be given to the
105     .I \-c
106     option, with the following definitions:
107 greg 1.25 .sp
108     .nf
109     R - red channel
110     G - green channel
111     B - blue channel
112     X - CIE X channel
113     Y - CIE Y channel (aka., luminance or illuminance)
114     Z - CIE Z channel
115     S - scotopic luminance or illuminance
116     M - melanopic luminance or illuminance
117 greg 1.26 A - average component value
118 greg 1.25 .fi
119     .sp
120     These letters may be given in any order as a single string, and if
121     .I "-c RGB"
122     or
123     .I "-c XYZ"
124 greg 1.28 is specified for an input picture or the
125 greg 1.25 .I "-fc"
126 greg 1.28 option is given, the output will be written as a RGBE or XYZE picture.
127 greg 1.25 Note that conversion from a float or RGBE color space applies a conversion
128     of 179 lumens/watt (for CIE or melanopic output) or 412 (for scotopic output),
129     and the reverse happens for conversion from XYZE input to RGB or RGBE output.
130 greg 1.32 Lower case versions of all these components are also supported, the only
131     difference is that the aforementioned efficacy factors
132     will be left out of the conversion.
133 greg 1.25 .PP
134 greg 1.28 If a matrix or picture file path is given to the
135 greg 1.27 .I \-c
136     option, then the color space of that file will be used, instead.
137     .PP
138     The
139     .I \-C
140     option takes either a symbolic color space or an input file, and will be
141     applied to all subsequent matrices that do not have their own associated
142     .I \-c
143     option.
144     .PP
145 greg 1.25 Additionally, the
146 greg 1.1 .I \-s
147 greg 1.25 option applies the given scalar factor(s) to the elements of the matrix.
148     If only one factor is provided,
149     it will be used for all components.
150     If multiple factors are given, their number must match the number of matrix
151     components
152     .I after
153     application of any
154 greg 1.1 .I \-c
155 greg 1.28 option for this input matrix or picture, even if the
156     .I \-s
157     option appears first.
158 greg 1.1 .PP
159     If present, the second and subsequent matrices on the command
160 greg 1.16 line are concatenated together, unless separated by a plus ('+'),
161 greg 1.10 asterisk ('*'), or forward slash ('/') symbol,
162 greg 1.15 in which case the individual matrix elements are added,
163 greg 1.16 multiplied, or divided, respectively.
164     The concatenation operator ('.') is the default and need not be specified.
165     Note also that the asterisk must be quoted or escaped in most shells.
166 greg 1.10 In the case of addition, the two matrices involved must have the same number
167     of components.
168 greg 1.15 If subtraction is desired, use addition ('+') with a scaling parameter of -1
169     for the second matrix (the
170     .I \-s
171     option).
172 greg 1.11 For element-wise multiplication and division, the second matrix is
173 greg 1.15 permitted to have a single component per element, which will be
174 greg 1.11 applied equally to all components of the first matrix.
175 greg 1.10 If element-wise division is specified, any zero elements in the second
176     matrix will result in a warning and the corresponding component(s) in the
177     first matrix will be set to zero.
178     .PP
179 greg 1.16 Evaluation proceeds from left to right, and all operations have
180     the same precedence.
181     If a different evaluation order is desired, pipe the result of one
182     .I rmtxop
183     command into another, as shown in one of the examples below.
184     .PP
185 greg 1.17 The number of components in the next matrix after applying any
186 greg 1.1 .I -c
187     transform must agree with the prior result.
188     For concatenation (matrix multiplication), the number of columns
189 greg 1.17 in the prior result must equal the number of rows in the next matrix, and
190 greg 1.1 the result will have the number of rows of the previous and the number
191 greg 1.17 of columns of the next matrix.
192 greg 1.10 In the case of addition, multiplication, and division,
193     the number of rows and columns of the prior result and the
194 greg 1.17 next matrix must match, and will not be changed by the operation.
195 greg 1.1 .PP
196 greg 1.25 A final transpose or transform/scaling operation may be applied to
197 greg 1.14 the results by appending the
198     .I \-t
199     and
200 greg 1.25 .I \-c
201     and/or
202 greg 1.14 .I \-s
203     options after the last matrix on the command line.
204     .PP
205 greg 1.1 Results are sent to the standard output.
206 greg 1.28 By default, the values will be written in the lowest precision format
207 greg 1.6 among the inputs, but the
208 greg 1.28 .I \-f[adfc]
209 greg 1.4 option may be used to explicitly output components
210 greg 1.25 as ASCII (-fa), binary doubles (-fd), floats (-ff), or common-exponent
211     colors/spectra (-fc).
212 greg 1.28 In the latter case, the actual matrix dimensions are written in
213     the resolution string rather than the header.
214 greg 1.24 Also, matrix results will be written as standard
215     Radiance pictures if they have either one
216 greg 1.1 or three components.
217     In the one-component case, the output is written as grayscale.
218 greg 1.24 If more than 3 components are in the final matrix and
219     .I -fc
220     is specified, the output will be a Radiance spectral picture.
221 greg 1.1 .PP
222     The
223     .I \-v
224     option turns on verbose reporting, which announces each operation.
225     .SH EXAMPLES
226     To concatenate two matrix files with a BTDF between them and write
227 greg 1.36 the result as binary float:
228 greg 1.1 .IP "" .2i
229 greg 1.36 rmtxop -ff view.vmx blinds.xml exterior.dmx > dcoef.dmx
230 greg 1.1 .PP
231     To convert a BTDF matrix into a Radiance picture:
232     .IP "" .2i
233     rmtxop -fc blinds.xml > blinds.hdr
234     .PP
235 greg 1.16 To extract the luminance values from a picture as an ASCII matrix:
236     .IP "" .2i
237     rmtxop -fa -c .265 .670 .065 image.hdr > image_lum.mtx
238     .PP
239 greg 1.25 To render a melanopic illuminance image with
240     .I rtrace\:
241     .IP "" .2i
242     vwrays -ff -x 1024 -y 1024 -vf myview.vf |
243     rtrace -fff -cs 18 -co+ -i+ `vwrays -x 1024 -y 1024 -vf myview.vf -d` scene.oct |
244     rmtxop -fc -c M - > scene_meli.hdr
245     .PP
246 greg 1.1 To scale a matrix by 4 and add it to the transpose of another matrix:
247     .IP "" .2i
248 greg 1.16 rmtxop -s 4 first.mtx + -t second.mtx > result.mtx
249     .PP
250     To multiply elements of two matrices, then concatenate with a third,
251     applying a final transpose to the result:
252     .IP "" .2i
253     rmtxop first.mtx \\* second.mtx . third.mtx -t > result.mtx
254 greg 1.1 .PP
255 greg 1.15 To left-multiply the element-wise division of two matrices:
256     .IP "" .2i
257     rmtxop -fd numerator.mtx / denominator.mtx | rmtxop left.mtx - > result.mtx
258     .PP
259 greg 1.1 To send the elements of a binary matrix to
260     .I rcalc(1)
261     for further processing:
262     .IP "" .2i
263 greg 1.5 rmtxop -fa orig.mtx | rcollate -ho -oc 1 | rcalc [operations]
264 greg 1.13 .SH NOTES
265 greg 1.16 Matrix concatenation is associative but not commutative, so order
266 greg 1.13 matters to the result.
267     .I Rmtxop
268 greg 1.16 takes advantage of this associative property to concatenate
269     from right to left when it reduces the number of basic operations.
270 greg 1.13 If the rightmost matrix is a column vector for example, it is
271 greg 1.16 much faster to concatenate from the right, and the result will
272 greg 1.13 be the same.
273 greg 1.16 Note that this only applies to concatenation;
274     element-wise addition, multiplication, and division are always
275 greg 1.13 evaluated from left to right.
276 greg 1.36 .PP
277     All calculations are peformed internally using 32-bit floating-point,
278     so there is little benefit in either reading or writing 64-bit double
279     data.
280     This may be overridden at compile time using the macro
281     "-DDTrmx_native=DTdouble".
282 greg 1.33 .SH BUGS
283     The
284     .I rmtxop
285     command currently ignores the "PRIMARIES" setting in input
286     headers, and does not produce any on output, even in
287     circumstances where it would make sense to.
288 greg 1.1 .SH AUTHOR
289     Greg Ward
290     .SH "SEE ALSO"
291 greg 1.29 cnt(1), dctimestep(1), getinfo(1), pcomb(1), pfilt(1),
292 greg 1.35 pvsum(1), ra_xyze(1), rcalc(1),
293 greg 1.31 rcollate(1), rcomb(1), rcontrib(1), rcrop(1), rfluxmtx(1),
294     rtpict(1), rtrace(1), vwrays(1), wrapBSDF(1)
