| 1 |
.\" RCSid "$Id: rmtxop.1,v 1.36 2025/04/04 18:06:48 greg Exp $"
| 2 |
.TH RMTXOP 1 5/31/2014 RADIANCE
| 3 |
.SH NAME
| 4 |
rmtxop - concatenate, add, multiply, divide, transpose, scale, and convert matrices
| 5 |
.SH SYNOPSIS
| 6 |
.B rmtxop
| 7 |
| 8 |
.B \-v
| 9 |
| 10 |
.B \-f[afdc]
| 11 |
| 12 |
.B "\-C {symbols|file}"
| 13 |
| 14 |
.B "\-c ce .."
| 15 |
| 16 |
.B "\-s sf .."
| 17 |
| 18 |
.B \-t
| 19 |
| 20 |
.B "\-rf|\-rb"
| 21 |
| 22 |
.B m1
| 23 |
| 24 |
.B ".+*/"
| 25 |
| 26 |
.B ".."
| 27 |
.SH DESCRIPTION
| 28 |
.I Rmtxop
| 29 |
loads and concatenates or adds/multiplies/divides
| 30 |
together component matrix files given on the command line.
| 31 |
Each file must have a header containing the following metadata:
| 32 |
.sp
| 33 |
.nf
| 34 |
NROWS={number of rows}
| 35 |
NCOLS={number of columns}
| 36 |
NCOMP={number of components}
| 37 |
FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_xyze|Radiance_spectra}
| 38 |
.fi
| 39 |
.sp
| 40 |
The number of components indicates that each matrix element is actually
| 41 |
composed of multiple channels, most commonly an RGB triple.
| 42 |
This is essentially dividing the matrix into planes, where each component
| 43 |
participates in a separate calculation.
| 44 |
If an appropriate header is not present, it may be added with a call to
| 45 |
.I rcollate(1).
| 46 |
A matrix may be read from the standard input using a hyphen by itself ('-')
| 47 |
in the appropriate place on the command line.
| 48 |
Similarly, any of the inputs may be read from a command
| 49 |
instead of a file by
| 50 |
using quotes and a beginning exclamation point ('!').
| 51 |
.PP
| 52 |
Two special cases are handled for component matrices that are either
| 53 |
XML files containing BSDF data, or Radiance picture files.
| 54 |
In the first case, the BSDF library loads and interprets the
| 55 |
transmission matrix by default.
| 56 |
Alternatively, the front (normal-side) reflectance is selected if the
| 57 |
.I \-rf
| 58 |
option precedes the file name, or the backside reflectance if
| 59 |
.I \-rb
| 60 |
is specified.
| 61 |
(XML files cannot be read from the standard input or from a command.)\0
| 62 |
In the second case, the RGBE or XYZE values are loaded in a 3-component
| 63 |
matrix where the number of columns match the X-dimension of the picture, and
| 64 |
the number of rows match the Y-dimension.
| 65 |
The picture must be in standard pixel ordering, and the first row
| 66 |
is at the top with the first column on the left.
| 67 |
Any exposure changes that were applied to the pictures before
| 68 |
.I rmtxop
| 69 |
will be undone, similar to the
| 70 |
.I pcomb(1)
| 71 |
.I \-o
| 72 |
option.
| 73 |
Radiance spectral pictures with more than 3 components are also supported.
| 74 |
These are typically produced by
| 75 |
.I rtrace(1)
| 76 |
or
| 77 |
.I rfluxmtx(1).
| 78 |
.PP
| 79 |
Before each input, the
| 80 |
.I \-t
| 81 |
and
| 82 |
.I \-c
| 83 |
and/or
| 84 |
.I \-s
| 85 |
options may be used to modify the matrix.
| 86 |
The
| 87 |
.I \-t
| 88 |
option transposes the matrix, swapping rows and columns.
| 89 |
The
| 90 |
.I \-c
| 91 |
option can "transform" the element values, possibly changing
| 92 |
the number of components in the matrix.
| 93 |
For example, a 3-component matrix can be transformed into a single-component
| 94 |
matrix by using
| 95 |
.I \-c
| 96 |
with three coefficients.
| 97 |
A four-component matrix can be turned into a two-component matrix using 8
| 98 |
coefficients, where the first four coefficients will be used to compute
| 99 |
the first new component, and the second four coefficients
| 100 |
yield the second new component.
| 101 |
Note that the number of coefficients must be an even multiple of the number
| 102 |
of original components.
| 103 |
.PP
| 104 |
Alternatively, a set of symbolic output components may be given to the
| 105 |
.I \-c
| 106 |
option, with the following definitions:
| 107 |
.sp
| 108 |
.nf
| 109 |
R - red channel
| 110 |
G - green channel
| 111 |
B - blue channel
| 112 |
X - CIE X channel
| 113 |
Y - CIE Y channel (aka., luminance or illuminance)
| 114 |
Z - CIE Z channel
| 115 |
S - scotopic luminance or illuminance
| 116 |
M - melanopic luminance or illuminance
| 117 |
A - average component value
| 118 |
.fi
| 119 |
.sp
| 120 |
These letters may be given in any order as a single string, and if
| 121 |
.I "-c RGB"
| 122 |
or
| 123 |
.I "-c XYZ"
| 124 |
is specified for an input picture or the
| 125 |
.I "-fc"
| 126 |
option is given, the output will be written as a RGBE or XYZE picture.
| 127 |
Note that conversion from a float or RGBE color space applies a conversion
| 128 |
of 179 lumens/watt (for CIE or melanopic output) or 412 (for scotopic output),
| 129 |
and the reverse happens for conversion from XYZE input to RGB or RGBE output.
| 130 |
Lower case versions of all these components are also supported, the only
| 131 |
difference is that the aforementioned efficacy factors
| 132 |
will be left out of the conversion.
| 133 |
.PP
| 134 |
If a matrix or picture file path is given to the
| 135 |
.I \-c
| 136 |
option, then the color space of that file will be used, instead.
| 137 |
.PP
| 138 |
The
| 139 |
.I \-C
| 140 |
option takes either a symbolic color space or an input file, and will be
| 141 |
applied to all subsequent matrices that do not have their own associated
| 142 |
.I \-c
| 143 |
option.
| 144 |
.PP
| 145 |
Additionally, the
| 146 |
.I \-s
| 147 |
option applies the given scalar factor(s) to the elements of the matrix.
| 148 |
If only one factor is provided,
| 149 |
it will be used for all components.
| 150 |
If multiple factors are given, their number must match the number of matrix
| 151 |
components
| 152 |
.I after
| 153 |
application of any
| 154 |
.I \-c
| 155 |
option for this input matrix or picture, even if the
| 156 |
.I \-s
| 157 |
option appears first.
| 158 |
.PP
| 159 |
If present, the second and subsequent matrices on the command
| 160 |
line are concatenated together, unless separated by a plus ('+'),
| 161 |
asterisk ('*'), or forward slash ('/') symbol,
| 162 |
in which case the individual matrix elements are added,
| 163 |
multiplied, or divided, respectively.
| 164 |
The concatenation operator ('.') is the default and need not be specified.
| 165 |
Note also that the asterisk must be quoted or escaped in most shells.
| 166 |
In the case of addition, the two matrices involved must have the same number
| 167 |
of components.
| 168 |
If subtraction is desired, use addition ('+') with a scaling parameter of -1
| 169 |
for the second matrix (the
| 170 |
.I \-s
| 171 |
option).
| 172 |
For element-wise multiplication and division, the second matrix is
| 173 |
permitted to have a single component per element, which will be
| 174 |
applied equally to all components of the first matrix.
| 175 |
If element-wise division is specified, any zero elements in the second
| 176 |
matrix will result in a warning and the corresponding component(s) in the
| 177 |
first matrix will be set to zero.
| 178 |
.PP
| 179 |
Evaluation proceeds from left to right, and all operations have
| 180 |
the same precedence.
| 181 |
If a different evaluation order is desired, pipe the result of one
| 182 |
.I rmtxop
| 183 |
command into another, as shown in one of the examples below.
| 184 |
.PP
| 185 |
The number of components in the next matrix after applying any
| 186 |
.I -c
| 187 |
transform must agree with the prior result.
| 188 |
For concatenation (matrix multiplication), the number of columns
| 189 |
in the prior result must equal the number of rows in the next matrix, and
| 190 |
the result will have the number of rows of the previous and the number
| 191 |
of columns of the next matrix.
| 192 |
In the case of addition, multiplication, and division,
| 193 |
the number of rows and columns of the prior result and the
| 194 |
next matrix must match, and will not be changed by the operation.
| 195 |
.PP
| 196 |
A final transpose or transform/scaling operation may be applied to
| 197 |
the results by appending the
| 198 |
.I \-t
| 199 |
and
| 200 |
.I \-c
| 201 |
and/or
| 202 |
.I \-s
| 203 |
options after the last matrix on the command line.
| 204 |
.PP
| 205 |
Results are sent to the standard output.
| 206 |
By default, the values will be written in the lowest precision format
| 207 |
among the inputs, but the
| 208 |
.I \-f[adfc]
| 209 |
option may be used to explicitly output components
| 210 |
as ASCII (-fa), binary doubles (-fd), floats (-ff), or common-exponent
| 211 |
colors/spectra (-fc).
| 212 |
In the latter case, the actual matrix dimensions are written in
| 213 |
the resolution string rather than the header.
| 214 |
Also, matrix results will be written as standard
| 215 |
Radiance pictures if they have either one
| 216 |
or three components.
| 217 |
In the one-component case, the output is written as grayscale.
| 218 |
If more than 3 components are in the final matrix and
| 219 |
.I -fc
| 220 |
is specified, the output will be a Radiance spectral picture.
| 221 |
.PP
| 222 |
The
| 223 |
.I \-v
| 224 |
option turns on verbose reporting, which announces each operation.
| 225 |
.SH EXAMPLES
| 226 |
To concatenate two matrix files with a BTDF between them and write
| 227 |
the result as binary float:
| 228 |
.IP "" .2i
| 229 |
rmtxop -ff view.vmx blinds.xml exterior.dmx > dcoef.dmx
| 230 |
.PP
| 231 |
To convert a BTDF matrix into a Radiance picture:
| 232 |
.IP "" .2i
| 233 |
rmtxop -fc blinds.xml > blinds.hdr
| 234 |
.PP
| 235 |
To extract the luminance values from a picture as an ASCII matrix:
| 236 |
.IP "" .2i
| 237 |
rmtxop -fa -c .265 .670 .065 image.hdr > image_lum.mtx
| 238 |
.PP
| 239 |
To render a melanopic illuminance image with
| 240 |
.I rtrace\:
| 241 |
.IP "" .2i
| 242 |
vwrays -ff -x 1024 -y 1024 -vf myview.vf |
| 243 |
rtrace -fff -cs 18 -co+ -i+ `vwrays -x 1024 -y 1024 -vf myview.vf -d` scene.oct |
| 244 |
rmtxop -fc -c M - > scene_meli.hdr
| 245 |
.PP
| 246 |
To scale a matrix by 4 and add it to the transpose of another matrix:
| 247 |
.IP "" .2i
| 248 |
rmtxop -s 4 first.mtx + -t second.mtx > result.mtx
| 249 |
.PP
| 250 |
To multiply elements of two matrices, then concatenate with a third,
| 251 |
applying a final transpose to the result:
| 252 |
.IP "" .2i
| 253 |
rmtxop first.mtx \\* second.mtx . third.mtx -t > result.mtx
| 254 |
.PP
| 255 |
To left-multiply the element-wise division of two matrices:
| 256 |
.IP "" .2i
| 257 |
rmtxop -fd numerator.mtx / denominator.mtx | rmtxop left.mtx - > result.mtx
| 258 |
.PP
| 259 |
To send the elements of a binary matrix to
| 260 |
.I rcalc(1)
| 261 |
for further processing:
| 262 |
.IP "" .2i
| 263 |
rmtxop -fa orig.mtx | rcollate -ho -oc 1 | rcalc [operations]
| 264 |
.SH NOTES
| 265 |
Matrix concatenation is associative but not commutative, so order
| 266 |
matters to the result.
| 267 |
.I Rmtxop
| 268 |
takes advantage of this associative property to concatenate
| 269 |
from right to left when it reduces the number of basic operations.
| 270 |
If the rightmost matrix is a column vector for example, it is
| 271 |
much faster to concatenate from the right, and the result will
| 272 |
be the same.
| 273 |
Note that this only applies to concatenation;
| 274 |
element-wise addition, multiplication, and division are always
| 275 |
evaluated from left to right.
| 276 |
.PP
| 277 |
All calculations are peformed internally using 32-bit floating-point,
| 278 |
so there is little benefit in either reading or writing 64-bit double
| 279 |
data.
| 280 |
This may be overridden at compile time using the macro
| 281 |
"-DDTrmx_native=DTdouble".
| 282 |
.SH BUGS
| 283 |
The
| 284 |
.I rmtxop
| 285 |
command currently ignores the "PRIMARIES" setting in input
| 286 |
headers, and does not produce any on output, even in
| 287 |
circumstances where it would make sense to.
| 288 |
.SH AUTHOR
| 289 |
Greg Ward
| 290 |
.SH "SEE ALSO"
| 291 |
cnt(1), dctimestep(1), getinfo(1), pcomb(1), pfilt(1),
| 292 |
pvsum(1), ra_xyze(1), rcalc(1),
| 293 |
rcollate(1), rcomb(1), rcontrib(1), rcrop(1), rfluxmtx(1),
| 294 |
rtpict(1), rtrace(1), rxfluxmtx(1), vwrays(1), wrapBSDF(1)
