root/radiance/ray/doc/man/man1/rmtxop.1
Fri Apr 4 18:06:48 2025 UTC (4 weeks, 3 days ago) by greg
Changes since 1.35: +9 -3 lines
Diff to previous 1.35
Thu Mar 27 01:26:55 2025 UTC (5 weeks, 5 days ago) by greg
Changes since 1.34: +2 -2 lines
Diff to previous 1.34
feat(pvsum): Added new pvsum tool for spectral data, similar to dctimestep
Tue May 7 17:15:31 2024 UTC (11 months, 4 weeks ago) by greg
Changes since 1.33: +2 -2 lines
Diff to previous 1.33
docs: Minor wording fixes
Mon Dec 25 16:29:56 2023 UTC (16 months, 1 week ago) by greg
Changes since 1.32: +7 -1 lines
Diff to previous 1.32
docs(rcomb,rmtxop): Added BUGS section
Tue Dec 19 00:39:03 2023 UTC (16 months, 2 weeks ago) by greg
Changes since 1.31: +4 -1 lines
Diff to previous 1.31
feat(rmtxop,rcomb): Added lower-case versions of component outputs w/o efficacy conversions
Tue Dec 12 16:31:45 2023 UTC (16 months, 3 weeks ago) by greg
Changes since 1.30: +3 -3 lines
Diff to previous 1.30
Mon Dec 11 19:21:43 2023 UTC (16 months, 3 weeks ago) by greg
Changes since 1.29: +2 -2 lines
Diff to previous 1.29
feat(rtpict): Added -co+ option support for hyperspectral image output
Fri Dec 8 17:56:26 2023 UTC (16 months, 4 weeks ago) by greg
Changes since 1.28: +3 -2 lines
Diff to previous 1.28
feat(pfilt): Added support for hyperspectral image filtering
Wed Dec 6 01:27:00 2023 UTC (17 months ago) by greg
Changes since 1.27: +17 -18 lines
Diff to previous 1.27
docs(rmtxcomb): Added man page for new rmtxcomb tool
Sat Dec 2 00:42:21 2023 UTC (17 months ago) by greg
Changes since 1.26: +20 -5 lines
Diff to previous 1.26
feat(rmtxop): Added -c _file_ and -C options for specifying color spaces
Wed Nov 29 18:56:28 2023 UTC (17 months ago) by greg
Changes since 1.25: +2 -1 lines
Diff to previous 1.25
feat(rmtxop): Added 'A' symbolic component for average of all channels
Mon Nov 27 22:04:45 2023 UTC (17 months, 1 week ago) by greg
Changes since 1.24: +57 -24 lines
Diff to previous 1.24
feat(rmtxop): Added symbolic transforms to -c option and made -s apply after any such transform, so both may be used simultaneously
Tue Nov 21 02:16:59 2023 UTC (17 months, 2 weeks ago) by greg
Changes since 1.23: +14 -5 lines
Diff to previous 1.23
docs: Added mention of Radiance spectral picture support
Tue Mar 15 00:25:50 2022 UTC (3 years, 1 month ago) by greg
Changes since 1.22: +3 -3 lines
Diff to previous 1.22
feat(rcrop): Created simple cropping utility for matrices and pictures
Thu Jan 21 17:47:07 2021 UTC (4 years, 3 months ago) by greg
Diff to previous 1.21
docs: formatting of option reminder
Thu Jan 21 17:30:20 2021 UTC (4 years, 3 months ago) by greg
Changes since 1.20: +2 -2 lines
Diff to previous 1.20
docs: typo
Tue Jan 19 23:32:00 2021 UTC (4 years, 3 months ago) by greg
Changes since 1.19: +11 -4 lines
Diff to previous 1.19
Mon Aug 31 22:17:56 2020 UTC (4 years, 8 months ago) by greg
Diff to previous 1.18
docs: formatting fix
Wed Mar 25 01:51:09 2020 UTC (5 years, 1 month ago) by greg
Changes since 1.17: +9 -3 lines
Diff to previous 1.17
Tue Sep 10 17:58:20 2019 UTC (5 years, 7 months ago) by greg
Changes since 1.16: +5 -5 lines
Diff to previous 1.16
Replaced confusing use of "new" with "next" when talking about matrix ops
Mon Aug 12 17:14:40 2019 UTC (5 years, 8 months ago) by greg
Changes since 1.15: +27 -12 lines
Diff to previous 1.15
Further clarifications and examples
Mon Aug 12 16:55:24 2019 UTC (5 years, 8 months ago) by greg
Changes since 1.14: +13 -5 lines
Diff to previous 1.14
Fixed argument parsing issue and added further explanations to man page
Mon Aug 12 02:26:46 2019 UTC (5 years, 8 months ago) by greg
Changes since 1.13: +10 -1 lines
Diff to previous 1.13
Mon Aug 12 01:20:25 2019 UTC (5 years, 8 months ago) by greg
Changes since 1.12: +15 -2 lines
Diff to previous 1.12
Sat Jul 20 00:57:43 2019 UTC (5 years, 9 months ago) by greg
Diff to previous 1.11
Added mention of rsplit(1)
Tue Sep 5 22:48:04 2017 UTC (7 years, 8 months ago) by greg
Changes since 1.10: +4 -4 lines
Diff to previous 1.10
Clarification
Mon Aug 28 15:59:46 2017 UTC (7 years, 8 months ago) by greg
Changes since 1.9: +22 -10 lines
Diff to previous 1.9
Mon May 4 20:53:21 2015 UTC (10 years ago) by greg
CVS Tags: rad5R0, rad5R1
Changes since 1.8: +6 -2 lines
Diff to previous 1.8
Fri Feb 20 18:26:09 2015 UTC (10 years, 2 months ago) by greg
Diff to previous 1.7
Fri Jan 23 01:03:17 2015 UTC (10 years, 3 months ago) by greg
Diff to previous 1.6
Minor fix
Tue Dec 16 17:42:24 2014 UTC (10 years, 4 months ago) by greg
Diff to previous 1.5
typo
Fri Aug 29 08:33:34 2014 UTC (10 years, 8 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Changes since 1.4: +3 -3 lines
Diff to previous 1.4
Fixed typos
Sat Aug 2 17:10:43 2014 UTC (10 years, 9 months ago) by greg
Changes since 1.3: +5 -4 lines
Fri Aug 1 22:58:03 2014 UTC (10 years, 9 months ago) by greg
Added missing -fc option in usage line
Tue Jul 22 21:55:31 2014 UTC (10 years, 9 months ago) by greg
CVS Tags: rad4R2
Sat May 31 21:33:21 2014 UTC (10 years, 11 months ago) by greg
Added rmtxop command for manipulating component matrices
