1 |
.\" RCSid "$Id: rmtxop.1,v 1.35 2025/03/27 01:26:55 greg Exp $" |
2 |
.TH RMTXOP 1 5/31/2014 RADIANCE |
3 |
.SH NAME |
4 |
rmtxop - concatenate, add, multiply, divide, transpose, scale, and convert matrices |
5 |
.SH SYNOPSIS |
6 |
.B rmtxop |
7 |
8 |
.B \-v |
9 |
10 |
.B \-f[afdc] |
11 |
12 |
.B "\-C {symbols|file}" |
13 |
14 |
.B "\-c ce .." |
15 |
16 |
.B "\-s sf .." |
17 |
18 |
.B \-t |
19 |
20 |
.B "\-rf|\-rb" |
21 |
22 |
.B m1 |
23 |
24 |
.B ".+*/" |
25 |
26 |
.B ".." |
27 |
.SH DESCRIPTION |
28 |
.I Rmtxop |
29 |
loads and concatenates or adds/multiplies/divides |
30 |
together component matrix files given on the command line. |
31 |
Each file must have a header containing the following metadata: |
32 |
.sp |
33 |
.nf |
34 |
NROWS={number of rows} |
35 |
NCOLS={number of columns} |
36 |
NCOMP={number of components} |
37 |
FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_xyze|Radiance_spectra} |
38 |
.fi |
39 |
.sp |
40 |
The number of components indicates that each matrix element is actually |
41 |
composed of multiple channels, most commonly an RGB triple. |
42 |
This is essentially dividing the matrix into planes, where each component |
43 |
participates in a separate calculation. |
44 |
If an appropriate header is not present, it may be added with a call to |
45 |
.I rcollate(1). |
46 |
A matrix may be read from the standard input using a hyphen by itself ('-') |
47 |
in the appropriate place on the command line. |
48 |
Similarly, any of the inputs may be read from a command |
49 |
instead of a file by |
50 |
using quotes and a beginning exclamation point ('!'). |
51 |
.PP |
52 |
Two special cases are handled for component matrices that are either |
53 |
XML files containing BSDF data, or Radiance picture files. |
54 |
In the first case, the BSDF library loads and interprets the |
55 |
transmission matrix by default. |
56 |
Alternatively, the front (normal-side) reflectance is selected if the |
57 |
.I \-rf |
58 |
option precedes the file name, or the backside reflectance if |
59 |
.I \-rb |
60 |
is specified. |
61 |
(XML files cannot be read from the standard input or from a command.)\0 |
62 |
In the second case, the RGBE or XYZE values are loaded in a 3-component |
63 |
matrix where the number of columns match the X-dimension of the picture, and |
64 |
the number of rows match the Y-dimension. |
65 |
The picture must be in standard pixel ordering, and the first row |
66 |
is at the top with the first column on the left. |
67 |
Any exposure changes that were applied to the pictures before |
68 |
.I rmtxop |
69 |
will be undone, similar to the |
70 |
.I pcomb(1) |
71 |
.I \-o |
72 |
option. |
73 |
Radiance spectral pictures with more than 3 components are also supported. |
74 |
These are typically produced by |
75 |
.I rtrace(1) |
76 |
or |
77 |
.I rfluxmtx(1). |
78 |
.PP |
79 |
Before each input, the |
80 |
.I \-t |
81 |
and |
82 |
.I \-c |
83 |
and/or |
84 |
.I \-s |
85 |
options may be used to modify the matrix. |
86 |
The |
87 |
.I \-t |
88 |
option transposes the matrix, swapping rows and columns. |
89 |
The |
90 |
.I \-c |
91 |
option can "transform" the element values, possibly changing |
92 |
the number of components in the matrix. |
93 |
For example, a 3-component matrix can be transformed into a single-component |
94 |
matrix by using |
95 |
.I \-c |
96 |
with three coefficients. |
97 |
A four-component matrix can be turned into a two-component matrix using 8 |
98 |
coefficients, where the first four coefficients will be used to compute |
99 |
the first new component, and the second four coefficients |
100 |
yield the second new component. |
101 |
Note that the number of coefficients must be an even multiple of the number |
102 |
of original components. |
103 |
.PP |
104 |
Alternatively, a set of symbolic output components may be given to the |
105 |
.I \-c |
106 |
option, with the following definitions: |
107 |
.sp |
108 |
.nf |
109 |
R - red channel |
110 |
G - green channel |
111 |
B - blue channel |
112 |
X - CIE X channel |
113 |
Y - CIE Y channel (aka., luminance or illuminance) |
114 |
Z - CIE Z channel |
115 |
S - scotopic luminance or illuminance |
116 |
M - melanopic luminance or illuminance |
117 |
A - average component value |
118 |
.fi |
119 |
.sp |
120 |
These letters may be given in any order as a single string, and if |
121 |
.I "-c RGB" |
122 |
or |
123 |
.I "-c XYZ" |
124 |
is specified for an input picture or the |
125 |
.I "-fc" |
126 |
option is given, the output will be written as a RGBE or XYZE picture. |
127 |
Note that conversion from a float or RGBE color space applies a conversion |
128 |
of 179 lumens/watt (for CIE or melanopic output) or 412 (for scotopic output), |
129 |
and the reverse happens for conversion from XYZE input to RGB or RGBE output. |
130 |
Lower case versions of all these components are also supported, the only |
131 |
difference is that the aforementioned efficacy factors |
132 |
will be left out of the conversion. |
133 |
.PP |
134 |
If a matrix or picture file path is given to the |
135 |
.I \-c |
136 |
option, then the color space of that file will be used, instead. |
137 |
.PP |
138 |
The |
139 |
.I \-C |
140 |
option takes either a symbolic color space or an input file, and will be |
141 |
applied to all subsequent matrices that do not have their own associated |
142 |
.I \-c |
143 |
option. |
144 |
.PP |
145 |
Additionally, the |
146 |
.I \-s |
147 |
option applies the given scalar factor(s) to the elements of the matrix. |
148 |
If only one factor is provided, |
149 |
it will be used for all components. |
150 |
If multiple factors are given, their number must match the number of matrix |
151 |
components |
152 |
.I after |
153 |
application of any |
154 |
.I \-c |
155 |
option for this input matrix or picture, even if the |
156 |
.I \-s |
157 |
option appears first. |
158 |
.PP |
159 |
If present, the second and subsequent matrices on the command |
160 |
line are concatenated together, unless separated by a plus ('+'), |
161 |
asterisk ('*'), or forward slash ('/') symbol, |
162 |
in which case the individual matrix elements are added, |
163 |
multiplied, or divided, respectively. |
164 |
The concatenation operator ('.') is the default and need not be specified. |
165 |
Note also that the asterisk must be quoted or escaped in most shells. |
166 |
In the case of addition, the two matrices involved must have the same number |
167 |
of components. |
168 |
If subtraction is desired, use addition ('+') with a scaling parameter of -1 |
169 |
for the second matrix (the |
170 |
.I \-s |
171 |
option). |
172 |
For element-wise multiplication and division, the second matrix is |
173 |
permitted to have a single component per element, which will be |
174 |
applied equally to all components of the first matrix. |
175 |
If element-wise division is specified, any zero elements in the second |
176 |
matrix will result in a warning and the corresponding component(s) in the |
177 |
first matrix will be set to zero. |
178 |
.PP |
179 |
Evaluation proceeds from left to right, and all operations have |
180 |
the same precedence. |
181 |
If a different evaluation order is desired, pipe the result of one |
182 |
.I rmtxop |
183 |
command into another, as shown in one of the examples below. |
184 |
.PP |
185 |
The number of components in the next matrix after applying any |
186 |
.I -c |
187 |
transform must agree with the prior result. |
188 |
For concatenation (matrix multiplication), the number of columns |
189 |
in the prior result must equal the number of rows in the next matrix, and |
190 |
the result will have the number of rows of the previous and the number |
191 |
of columns of the next matrix. |
192 |
In the case of addition, multiplication, and division, |
193 |
the number of rows and columns of the prior result and the |
194 |
next matrix must match, and will not be changed by the operation. |
195 |
.PP |
196 |
A final transpose or transform/scaling operation may be applied to |
197 |
the results by appending the |
198 |
.I \-t |
199 |
and |
200 |
.I \-c |
201 |
and/or |
202 |
.I \-s |
203 |
options after the last matrix on the command line. |
204 |
.PP |
205 |
Results are sent to the standard output. |
206 |
By default, the values will be written in the lowest precision format |
207 |
among the inputs, but the |
208 |
.I \-f[adfc] |
209 |
option may be used to explicitly output components |
210 |
as ASCII (-fa), binary doubles (-fd), floats (-ff), or common-exponent |
211 |
colors/spectra (-fc). |
212 |
In the latter case, the actual matrix dimensions are written in |
213 |
the resolution string rather than the header. |
214 |
Also, matrix results will be written as standard |
215 |
Radiance pictures if they have either one |
216 |
or three components. |
217 |
In the one-component case, the output is written as grayscale. |
218 |
If more than 3 components are in the final matrix and |
219 |
.I -fc |
220 |
is specified, the output will be a Radiance spectral picture. |
221 |
.PP |
222 |
The |
223 |
.I \-v |
224 |
option turns on verbose reporting, which announces each operation. |
225 |
.SH EXAMPLES |
226 |
To concatenate two matrix files with a BTDF between them and write |
227 |
the result as binary float: |
228 |
.IP "" .2i |
229 |
rmtxop -ff view.vmx blinds.xml exterior.dmx > dcoef.dmx |
230 |
.PP |
231 |
To convert a BTDF matrix into a Radiance picture: |
232 |
.IP "" .2i |
233 |
rmtxop -fc blinds.xml > blinds.hdr |
234 |
.PP |
235 |
To extract the luminance values from a picture as an ASCII matrix: |
236 |
.IP "" .2i |
237 |
rmtxop -fa -c .265 .670 .065 image.hdr > image_lum.mtx |
238 |
.PP |
239 |
To render a melanopic illuminance image with |
240 |
.I rtrace\: |
241 |
.IP "" .2i |
242 |
vwrays -ff -x 1024 -y 1024 -vf myview.vf | |
243 |
rtrace -fff -cs 18 -co+ -i+ `vwrays -x 1024 -y 1024 -vf myview.vf -d` scene.oct | |
244 |
rmtxop -fc -c M - > scene_meli.hdr |
245 |
.PP |
246 |
To scale a matrix by 4 and add it to the transpose of another matrix: |
247 |
.IP "" .2i |
248 |
rmtxop -s 4 first.mtx + -t second.mtx > result.mtx |
249 |
.PP |
250 |
To multiply elements of two matrices, then concatenate with a third, |
251 |
applying a final transpose to the result: |
252 |
.IP "" .2i |
253 |
rmtxop first.mtx \\* second.mtx . third.mtx -t > result.mtx |
254 |
.PP |
255 |
To left-multiply the element-wise division of two matrices: |
256 |
.IP "" .2i |
257 |
rmtxop -fd numerator.mtx / denominator.mtx | rmtxop left.mtx - > result.mtx |
258 |
.PP |
259 |
To send the elements of a binary matrix to |
260 |
.I rcalc(1) |
261 |
for further processing: |
262 |
.IP "" .2i |
263 |
rmtxop -fa orig.mtx | rcollate -ho -oc 1 | rcalc [operations] |
264 |
.SH NOTES |
265 |
Matrix concatenation is associative but not commutative, so order |
266 |
matters to the result. |
267 |
.I Rmtxop |
268 |
takes advantage of this associative property to concatenate |
269 |
from right to left when it reduces the number of basic operations. |
270 |
If the rightmost matrix is a column vector for example, it is |
271 |
much faster to concatenate from the right, and the result will |
272 |
be the same. |
273 |
Note that this only applies to concatenation; |
274 |
element-wise addition, multiplication, and division are always |
275 |
evaluated from left to right. |
276 |
.PP |
277 |
All calculations are peformed internally using 32-bit floating-point, |
278 |
so there is little benefit in either reading or writing 64-bit double |
279 |
data. |
280 |
This may be overridden at compile time using the macro |
281 |
"-DDTrmx_native=DTdouble". |
282 |
.SH BUGS |
283 |
The |
284 |
.I rmtxop |
285 |
command currently ignores the "PRIMARIES" setting in input |
286 |
headers, and does not produce any on output, even in |
287 |
circumstances where it would make sense to. |
288 |
.SH AUTHOR |
289 |
Greg Ward |
290 |
.SH "SEE ALSO" |
291 |
cnt(1), dctimestep(1), getinfo(1), pcomb(1), pfilt(1), |
292 |
pvsum(1), ra_xyze(1), rcalc(1), |
293 |
rcollate(1), rcomb(1), rcontrib(1), rcrop(1), rfluxmtx(1), |
294 |
rtpict(1), rtrace(1), vwrays(1), wrapBSDF(1) |
