root/radiance/ray/doc/man/man1/rmtxop.1
Revision: 1.30
Committed: Mon Dec 11 19:21:43 2023 UTC (16 months, 3 weeks ago) by greg
Changes since 1.29: +2 -2 lines
feat(rtpict): Added -co+ option support for hyperspectral image output
1 .\" RCSid "$Id: rmtxop.1,v 1.29 2023/12/08 17:56:26 greg Exp $"
2 .TH RMTXOP 1 5/31/2014 RADIANCE
3 .SH NAME
4 rmtxop - concatenate, add, multiply, divide, transpose, scale, and convert matrices
5 .SH SYNOPSIS
6 .B rmtxop
7 [
8 .B \-v
9 ][
10 .B \-f[afdc]
11 ][
12 .B "\-C {symbols|file}"
13 ][
14 .B "\-c ce .."
15 ][
16 .B "\-s sf .."
17 ][
18 .B \-t
19 ][
20 .B "\-rf|\-rb"
21 ]
22 .B m1
23 [
24 .B ".+*/"
25 ]
26 .B ".."
27 .SH DESCRIPTION
28 .I Rmtxop
29 loads and concatenates or adds/multiplies/divides
30 together component matrix files given on the command line.
31 Each file must have a header containing the following metadata:
32 .sp
33 .nf
34 NROWS={number of rows}
35 NCOLS={number of columns}
36 NCOMP={number of components}
37 FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_xyze|Radiance_spectra}
38 .fi
39 .sp
40 The number of components indicates that each matrix element is actually
41 composed of multiple elements, most commonly an RGB triple.
42 This is essentially dividing the matrix into planes, where each component
43 participates in a separate calculation.
44 If an appropriate header is not present, it may be added with a call to
45 .I rcollate(1).
46 A matrix may be read from the standard input using a hyphen by itself ('-')
47 in the appropriate place on the command line.
48 Similarly, any of the inputs may be read from a command
49 instead of a file by
50 using quotes and a beginning exclamation point ('!').
51 .PP
52 Two special cases are handled for component matrices that are either
53 XML files containing BSDF data, or Radiance picture files.
54 In the first case, the BSDF library loads and interprets the
55 transmission matrix by default.
56 Alternatively, the front (normal-side) reflectance is selected if the
57 .I \-rf
58 option precedes the file name, or the backside reflectance if
59 .I \-rb
60 is specified.
61 (XML files cannot be read from the standard input or from a command.)\0
62 In the second case, the RGBE or XYZE values are loaded in a 3-component
63 matrix where the number of columns match the X-dimension of the picture, and
64 the number of rows match the Y-dimension.
65 The picture must be in standard pixel ordering, and the first row
66 is at the top with the first column on the left.
67 Any exposure changes that were applied to the pictures before
68 .I rmtxop
69 will be undone, similar to the
70 .I pcomb(1)
71 .I \-o
72 option.
73 Radiance spectral pictures with more than 3 components are also supported.
74 These are typically produced by
75 .I rtrace(1)
76 or
77 .I rfluxmtx(1).
78 .PP
79 Before each input, the
80 .I \-t
81 and
82 .I \-c
83 and/or
84 .I \-s
85 options may be used to modify the matrix.
86 The
87 .I \-t
88 option transposes the matrix, swapping rows and columns.
89 The
90 .I \-c
91 option can "transform" the element values, possibly changing
92 the number of components in the matrix.
93 For example, a 3-component matrix can be transformed into a single-component
94 matrix by using
95 .I \-c
96 with three coefficients.
97 A four-component matrix can be turned into a two-component matrix using 8
98 coefficients, where the first four coefficients will be used to compute
99 the first new component, and the second four coefficients
100 yield the second new component.
101 Note that the number of coefficients must be an even multiple of the number
102 of original components.
103 .PP
104 Alternatively, a set of symbolic output components may be given to the
105 .I \-c
106 option, with the following definitions:
107 .sp
108 .nf
109 R - red channel
110 G - green channel
111 B - blue channel
112 X - CIE X channel
113 Y - CIE Y channel (aka., luminance or illuminance)
114 Z - CIE Z channel
115 S - scotopic luminance or illuminance
116 M - melanopic luminance or illuminance
117 A - average component value
118 .fi
119 .sp
120 These letters may be given in any order as a single string, and if
121 .I "-c RGB"
122 or
123 .I "-c XYZ"
124 is specified for an input picture or the
125 .I "-fc"
126 option is given, the output will be written as a RGBE or XYZE picture.
127 Note that conversion from a float or RGBE color space applies a conversion
128 of 179 lumens/watt (for CIE or melanopic output) or 412 (for scotopic output),
129 and the reverse happens for conversion from XYZE input to RGB or RGBE output.
130 .PP
131 If a matrix or picture file path is given to the
132 .I \-c
133 option, then the color space of that file will be used, instead.
134 .PP
135 The
136 .I \-C
137 option takes either a symbolic color space or an input file, and will be
138 applied to all subsequent matrices that do not have their own associated
139 .I \-c
140 option.
141 .PP
142 Additionally, the
143 .I \-s
144 option applies the given scalar factor(s) to the elements of the matrix.
145 If only one factor is provided,
146 it will be used for all components.
147 If multiple factors are given, their number must match the number of matrix
148 components
149 .I after
150 application of any
151 .I \-c
152 option for this input matrix or picture, even if the
153 .I \-s
154 option appears first.
155 .PP
156 If present, the second and subsequent matrices on the command
157 line are concatenated together, unless separated by a plus ('+'),
158 asterisk ('*'), or forward slash ('/') symbol,
159 in which case the individual matrix elements are added,
160 multiplied, or divided, respectively.
161 The concatenation operator ('.') is the default and need not be specified.
162 Note also that the asterisk must be quoted or escaped in most shells.
163 In the case of addition, the two matrices involved must have the same number
164 of components.
165 If subtraction is desired, use addition ('+') with a scaling parameter of -1
166 for the second matrix (the
167 .I \-s
168 option).
169 For element-wise multiplication and division, the second matrix is
170 permitted to have a single component per element, which will be
171 applied equally to all components of the first matrix.
172 If element-wise division is specified, any zero elements in the second
173 matrix will result in a warning and the corresponding component(s) in the
174 first matrix will be set to zero.
175 .PP
176 Evaluation proceeds from left to right, and all operations have
177 the same precedence.
178 If a different evaluation order is desired, pipe the result of one
179 .I rmtxop
180 command into another, as shown in one of the examples below.
181 .PP
182 The number of components in the next matrix after applying any
183 .I -c
184 transform must agree with the prior result.
185 For concatenation (matrix multiplication), the number of columns
186 in the prior result must equal the number of rows in the next matrix, and
187 the result will have the number of rows of the previous and the number
188 of columns of the next matrix.
189 In the case of addition, multiplication, and division,
190 the number of rows and columns of the prior result and the
191 next matrix must match, and will not be changed by the operation.
192 .PP
193 A final transpose or transform/scaling operation may be applied to
194 the results by appending the
195 .I \-t
196 and
197 .I \-c
198 and/or
199 .I \-s
200 options after the last matrix on the command line.
201 .PP
202 Results are sent to the standard output.
203 By default, the values will be written in the lowest precision format
204 among the inputs, but the
205 .I \-f[adfc]
206 option may be used to explicitly output components
207 as ASCII (-fa), binary doubles (-fd), floats (-ff), or common-exponent
208 colors/spectra (-fc).
209 In the latter case, the actual matrix dimensions are written in
210 the resolution string rather than the header.
211 Also, matrix results will be written as standard
212 Radiance pictures if they have either one
213 or three components.
214 In the one-component case, the output is written as grayscale.
215 If more than 3 components are in the final matrix and
216 .I -fc
217 is specified, the output will be a Radiance spectral picture.
218 .PP
219 The
220 .I \-v
221 option turns on verbose reporting, which announces each operation.
222 .SH EXAMPLES
223 To concatenate two matrix files with a BTDF between them and write
224 the result as binary double:
225 .IP "" .2i
226 rmtxop -fd view.vmx blinds.xml exterior.dmx > dcoef.dmx
227 .PP
228 To convert a BTDF matrix into a Radiance picture:
229 .IP "" .2i
230 rmtxop -fc blinds.xml > blinds.hdr
231 .PP
232 To extract the luminance values from a picture as an ASCII matrix:
233 .IP "" .2i
234 rmtxop -fa -c .265 .670 .065 image.hdr > image_lum.mtx
235 .PP
236 To render a melanopic illuminance image with
237 .I rtrace\:
238 .IP "" .2i
239 vwrays -ff -x 1024 -y 1024 -vf myview.vf |
240 rtrace -fff -cs 18 -co+ -i+ `vwrays -x 1024 -y 1024 -vf myview.vf -d` scene.oct |
241 rmtxop -fc -c M - > scene_meli.hdr
242 .PP
243 To scale a matrix by 4 and add it to the transpose of another matrix:
244 .IP "" .2i
245 rmtxop -s 4 first.mtx + -t second.mtx > result.mtx
246 .PP
247 To multiply elements of two matrices, then concatenate with a third,
248 applying a final transpose to the result:
249 .IP "" .2i
250 rmtxop first.mtx \\* second.mtx . third.mtx -t > result.mtx
251 .PP
252 To left-multiply the element-wise division of two matrices:
253 .IP "" .2i
254 rmtxop -fd numerator.mtx / denominator.mtx | rmtxop left.mtx - > result.mtx
255 .PP
256 To send the elements of a binary matrix to
257 .I rcalc(1)
258 for further processing:
259 .IP "" .2i
260 rmtxop -fa orig.mtx | rcollate -ho -oc 1 | rcalc [operations]
261 .SH NOTES
262 Matrix concatenation is associative but not commutative, so order
263 matters to the result.
264 .I Rmtxop
265 takes advantage of this associative property to concatenate
266 from right to left when it reduces the number of basic operations.
267 If the rightmost matrix is a column vector for example, it is
268 much faster to concatenate from the right, and the result will
269 be the same.
270 Note that this only applies to concatenation;
271 element-wise addition, multiplication, and division are always
272 evaluated from left to right.
273 .SH AUTHOR
274 Greg Ward
275 .SH "SEE ALSO"
276 cnt(1), dctimestep(1), getinfo(1), pcomb(1), pfilt(1),
277 ra_xyze(1), rcalc(1),
278 rcollate(1), rcontrib(1), rcrop(1), rfluxmtx(1),
279 rmtxcomb(1), rtpict(1), rtrace(1), vwrays(1), wrapBSDF(1)
