1 |
.\" RCSid "$Id: rmtxop.1,v 1.9 2015/05/04 20:53:21 greg Exp $" |
2 |
.TH RMTXOP 1 7/8/97 RADIANCE |
3 |
.SH NAME |
4 |
rmtxop - concatenate, add, multiply, divide, transpose, scale, and convert matrices |
5 |
.SH SYNOPSIS |
6 |
.B rmtxop |
7 |
8 |
.B \-v |
9 |
10 |
.B \-f[afdc] |
11 |
12 |
.B \-t |
13 |
14 |
.B "\-s sf .." |
15 |
16 |
.B "\-c ce .." |
17 |
18 |
.B m1 |
19 |
20 |
.B "+*/" |
21 |
22 |
.B ".." |
23 |
.SH DESCRIPTION |
24 |
.I Rmtxop |
25 |
loads and concatenates or adds/multiplies/divides |
26 |
together component matrix files given on the command line. |
27 |
Each file must have a header containing the following variables: |
28 |
.sp |
29 |
.nf |
30 |
NROWS={number of rows} |
31 |
NCOLS={number of columns} |
32 |
NCOMP={number of components} |
33 |
FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_xyze} |
34 |
.sp |
35 |
.fi |
36 |
The number of components indicates that each matrix element is actually |
37 |
composed of multiple elements, most commonly an RGB triple. |
38 |
This is essentially dividing the matrix into planes, where each component |
39 |
participates in a separate calculation. |
40 |
If an appropriate header is not present, it may be added with a call to |
41 |
.I rcollate(1). |
42 |
A matrix may be read from the standard input using a hyphen by itself ('-') |
43 |
in the appropriate place on the command line. |
44 |
.PP |
45 |
Any of the matrix inputs may be read from a command |
46 |
instead of a file by |
47 |
using quotes and a beginning exclamation point ('!'). |
48 |
.PP |
49 |
Two special cases are handled for component matrices that are either |
50 |
XML files containing BTDF data, or Radiance picture files. |
51 |
In the first case, a BSDF library is used to load and interpret the |
52 |
transmission matrix. |
53 |
(XML files cannot be read from the standard input or from a command.)\0 |
54 |
In the second case, the RGBE or XYZE values are loaded in a 3-component |
55 |
matrix where the number of columns match the X-dimension of the picture, and |
56 |
the number of rows match the Y-dimension. |
57 |
The picture must be in standard pixel ordering, and the first row |
58 |
is at the top with the first column on the left. |
59 |
.PP |
60 |
Before each file, the |
61 |
.I \-t |
62 |
and |
63 |
.I \-s |
64 |
or |
65 |
.I \-c |
66 |
options may be used to modify the matrix. |
67 |
The |
68 |
.I \-t |
69 |
option transposes the matrix, swapping rows and columns. |
70 |
The |
71 |
.I \-s |
72 |
option applies the given scalar factor(s) to the elements of the matrix. |
73 |
If only one factor is provided, |
74 |
it will be used for all components. |
75 |
If multiple factors are given, their number must match the number of matrix |
76 |
components. |
77 |
Alternatively, the |
78 |
.I \-c |
79 |
option may be used to "transform" the element values, possibly changing |
80 |
the number of components in the matrix. |
81 |
For example, a 3-component matrix can be transformed into a single-component |
82 |
matrix by using |
83 |
.I \-c |
84 |
with three coefficients. |
85 |
A four-component matrix can be turned into a two-component matrix using 8 |
86 |
coefficients, where the first four coefficients will be used to compute |
87 |
the first new component, and the second four coefficients |
88 |
yield the second new component. |
89 |
Note that the number of coefficients must be an even multiple of the number |
90 |
of original components. |
91 |
The |
92 |
.I \-s |
93 |
and |
94 |
.I \-c |
95 |
options are mutually exclusive, insofar as they cannot be applied together |
96 |
to the same input matrix. |
97 |
.PP |
98 |
If present, the second and subsequent matrices on the command |
99 |
line are concatenated to the result unless separated by a plus ('+'), |
100 |
asterisk ('*'), or forward slash ('/') symbol, |
101 |
in which case the matrix elements are added, multiplied, or divided together, |
102 |
respectively. |
103 |
(Note that the asterisk must be quoted or escaped in most shells.)\0 |
104 |
In the case of addition, the two matrices involved must have the same number |
105 |
of components. |
106 |
For element-wise multiplication and division, the second matrix may have |
107 |
only a single component per element, which will be applied equally to all |
108 |
components of the first matrix. |
109 |
If element-wise division is specified, any zero elements in the second |
110 |
matrix will result in a warning and the corresponding component(s) in the |
111 |
first matrix will be set to zero. |
112 |
.PP |
113 |
The number of components in the new matrix after applying any |
114 |
.I -c |
115 |
transform must agree with the prior result. |
116 |
For concatenation (matrix multiplication), the number of columns |
117 |
in the prior result must equal the number of rows in the new matrix, and |
118 |
the result will have the number of rows of the previous and the number |
119 |
of columns of the new matrix. |
120 |
In the case of addition, multiplication, and division, |
121 |
the number of rows and columns of the prior result and the |
122 |
new matrix must match, and will not be changed by the operation. |
123 |
.PP |
124 |
Results are sent to the standard output. |
125 |
By default, the values will be written in the lowest resolution format |
126 |
among the inputs, but the |
127 |
.I \-f |
128 |
option may be used to explicitly output components |
129 |
as ASCII (-fa), binary doubles (-fd), floats (-ff), or RGBE colors (-fc). |
130 |
In the latter case, the actual matrix dimensions are written in the resolution |
131 |
string rather than the header. |
132 |
Also, matrix results written as Radiance pictures must have either one |
133 |
or three components. |
134 |
In the one-component case, the output is written as grayscale. |
135 |
.PP |
136 |
The |
137 |
.I \-v |
138 |
option turns on verbose reporting, which announces each operation. |
139 |
.SH EXAMPLES |
140 |
To concatenate two matrix files with a BTDF between them and write |
141 |
the result as binary double: |
142 |
.IP "" .2i |
143 |
rmtxop -fd view.vmx blinds.xml exterior.dmx > dcoef.dmx |
144 |
.PP |
145 |
To convert a BTDF matrix into a Radiance picture: |
146 |
.IP "" .2i |
147 |
rmtxop -fc blinds.xml > blinds.hdr |
148 |
.PP |
149 |
To scale a matrix by 4 and add it to the transpose of another matrix: |
150 |
.IP "" .2i |
151 |
rmtxop -s 4 left.mtx + -t right.mtx > result.mtx |
152 |
.PP |
153 |
To send the elements of a binary matrix to |
154 |
.I rcalc(1) |
155 |
for further processing: |
156 |
.IP "" .2i |
157 |
rmtxop -fa orig.mtx | rcollate -ho -oc 1 | rcalc [operations] |
158 |
.SH AUTHOR |
159 |
Greg Ward |
160 |
.SH "SEE ALSO" |
161 |
cnt(1), getinfo(1), histo(1), neaten(1), rcalc(1), rcollate(1), |
162 |
rcontrib(1), rfluxmtx(1), rlam(1), tabfunc(1), total(1), wrapBSDF(1) |
