| 1 |
.\" RCSid "$Id: rmtxcomb.1,v 1.5 2023/12/11 19:21:43 greg Exp $"
| 2 |
.TH RMTXCOMB 12/5/2023 RADIANCE
| 3 |
.SH NAME
| 4 |
rmtxcomb - combine and convert matrices a row at a time
| 5 |
.SH SYNOPSIS
| 6 |
.B rmtxcomb
| 7 |
| 8 |
.B \-h
| 9 |
| 10 |
.B \-w
| 11 |
| 12 |
.B \-f[afdc]
| 13 |
| 14 |
.B "\-f file"
| 15 |
| 16 |
.B "\-e expr"
| 17 |
| 18 |
.B "\-C {symbols|file}"
| 19 |
| 20 |
.B "\-c ce .."
| 21 |
| 22 |
.B "\-s sf .."
| 23 |
| 24 |
.B "m1 .."
| 25 |
| 26 |
.B "\-m mcat"
| 27 |
| 28 |
.SH DESCRIPTION
| 29 |
.I Rmtxcomb
| 30 |
combines inputs given on the command line,
| 31 |
one matrix row or picture scanline at a time.
| 32 |
By default, the result is a linear combination of
| 33 |
the matrix elements or pixels transformed by
| 34 |
.I \-c
| 35 |
specifications and scaled by
| 36 |
.I \-s
| 37 |
coefficients, but an arbitrary mapping can be assigned with the
| 38 |
.I \-e
| 39 |
and
| 40 |
.I \-f
| 41 |
options, similar to the
| 42 |
.I pcomb(1)
| 43 |
and
| 44 |
.I rcalc(1)
| 45 |
commands.
| 46 |
(The definitions in each
| 47 |
.I \-f source
| 48 |
file are read and compiled from the RADIANCE library where it is found.)\0
| 49 |
.PP
| 50 |
If any
| 51 |
.I \-c
| 52 |
or
| 53 |
.I \-s
| 54 |
options follow the last input matrix, output results will be transformed
| 55 |
and/or scaled accordingly.
| 56 |
These operations are discussed in greater detail further on.
| 57 |
A single concatenation matrix may be applied after element operations
| 58 |
using the
| 59 |
.I \-m
| 60 |
option.
| 61 |
Matrix concatenation will happen before or after any trailing
| 62 |
operations, depending on relative command line placement.
| 63 |
.PP
| 64 |
Each input file must have a header containing the following metadata:
| 65 |
.sp
| 66 |
.nf
| 67 |
NROWS={number of rows}
| 68 |
NCOLS={number of columns}
| 69 |
NCOMP={number of components}
| 70 |
FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_xyze|Radiance_spectra}
| 71 |
.fi
| 72 |
.sp
| 73 |
The number of components indicates that each matrix element is actually
| 74 |
composed of multiple elements, most commonly an RGB triple.
| 75 |
This is essentially dividing the matrix into planes, where each component
| 76 |
participates in a separate calculation.
| 77 |
If an appropriate header is not present, it may be added with a call to
| 78 |
.I rcollate(1).
| 79 |
A matrix may be read from the standard input using a hyphen by itself ('-')
| 80 |
in the appropriate place on the command line.
| 81 |
Similarly, any of the inputs may be read from a command
| 82 |
instead of a file by
| 83 |
using quotes and a beginning exclamation point ('!').
| 84 |
.PP
| 85 |
In the case of Radiance picture files,
| 86 |
the number of columns is the X-dimension of the picture, and
| 87 |
the number of rows is the Y-dimension.
| 88 |
The picture must be in standard pixel ordering, and the zeroeth row
| 89 |
is at the top with the zeroeth column on the left.
| 90 |
Any exposure changes that were applied to the pictures before
| 91 |
.I rmtxcomb
| 92 |
will be undone, similar to the
| 93 |
.I "pcomb \-o"
| 94 |
option.
| 95 |
Radiance spectral pictures with more than 3 components are also supported.
| 96 |
These are typically produced by
| 97 |
.I rtrace(1)
| 98 |
or
| 99 |
.I rfluxmtx(1).
| 100 |
.PP
| 101 |
Before each input, the
| 102 |
.I \-c
| 103 |
and/or
| 104 |
.I \-s
| 105 |
options may be used to modify the matrix elements.
| 106 |
The
| 107 |
.I \-c
| 108 |
option can "transform" the element values, possibly changing
| 109 |
the number of components in the matrix.
| 110 |
For example, a 3-component matrix can be transformed into a single-component
| 111 |
matrix by using
| 112 |
.I \-c
| 113 |
with three coefficients.
| 114 |
A four-component matrix can be turned into a two-component matrix using 8
| 115 |
coefficients, where the first four coefficients will be used to compute
| 116 |
the first new component, and the second four coefficients
| 117 |
yield the second new component.
| 118 |
Note that the number of coefficients must be an even multiple of the number
| 119 |
of original components.
| 120 |
.PP
| 121 |
Alternatively, a set of symbolic output components may be given to the
| 122 |
.I \-c
| 123 |
option, with the following definitions:
| 124 |
.sp
| 125 |
.nf
| 126 |
R - red channel
| 127 |
G - green channel
| 128 |
B - blue channel
| 129 |
X - CIE X channel
| 130 |
Y - CIE Y channel (aka., luminance or illuminance)
| 131 |
Z - CIE Z channel
| 132 |
S - scotopic luminance or illuminance
| 133 |
M - melanopic luminance or illuminance
| 134 |
A - average component value
| 135 |
.fi
| 136 |
.sp
| 137 |
These letters may be given in any order as a single string, and if
| 138 |
.I "-c RGB"
| 139 |
or
| 140 |
.I "-c XYZ"
| 141 |
is specified for an input picture or the
| 142 |
.I "-fc"
| 143 |
option is given, the output will be written as a RGBE or XYZE picture.
| 144 |
Note that conversion from a float or RGBE color space applies a conversion
| 145 |
of 179 lumens/watt (for CIE or melanopic output) or 412 (for scotopic output),
| 146 |
and the reverse happens for conversion from XYZE input to RGB or RGBE output.
| 147 |
.PP
| 148 |
If a matrix or picture file path is given to the
| 149 |
.I \-c
| 150 |
option, then the color space of that file will be used, instead.
| 151 |
.PP
| 152 |
The
| 153 |
.I \-C
| 154 |
option takes either a symbolic color space or an input file, and will be
| 155 |
applied to all subsequent matrices that do not have their own associated
| 156 |
.I \-c
| 157 |
option.
| 158 |
.PP
| 159 |
Additionally, the
| 160 |
.I \-s
| 161 |
option applies the given scalar factor(s) to the elements of the matrix.
| 162 |
If only one factor is provided,
| 163 |
it will be used for all components.
| 164 |
If multiple factors are given, their number must match the number of matrix
| 165 |
components
| 166 |
.I after
| 167 |
application of any
| 168 |
.I \-c
| 169 |
option for this input matrix or picture, even if the
| 170 |
.I \-s
| 171 |
option appears first.
| 172 |
.PP
| 173 |
The number of components in all input
| 174 |
matrices after applying any
| 175 |
.I -c
| 176 |
transform must agree.
| 177 |
Similarly, the number of rows and columns of all results must match
| 178 |
exactly.
| 179 |
(The
| 180 |
.I rcrop(1)
| 181 |
utility may be used to trim inputs if necessary.)\0
| 182 |
.PP
| 183 |
If the
| 184 |
.I \-e
| 185 |
or
| 186 |
.I \-f
| 187 |
options are used to define a "co" variable or "co(p)" function,
| 188 |
this will be evaluated at each output
| 189 |
component for the current element.
| 190 |
The "co" variable defines identical operations for all components,
| 191 |
whereas "co(p)" may specify different operations for each component.
| 192 |
The element position is defined
| 193 |
by the "r" and "c" variables, where
| 194 |
.I r
| 195 |
goes from 0 to "nrows" minus one, and
| 196 |
.I c
| 197 |
goes from 0 to "ncols" minus one.
| 198 |
Component p from input i is accessed with the "ci(i,p)" function,
| 199 |
and the number of components is defined by the "ncomp" constant.
| 200 |
If given as "ci(i)", the function returns the current component
| 201 |
being evaluated by
| 202 |
.I rmtxcomb.
| 203 |
A different component may be referenced using th second argument.
| 204 |
For example, "ci(1,2)" accesses
| 205 |
the second component from the first input.
| 206 |
If the input is a picture, the the constants "R", "G", and "B"
| 207 |
are conveniently defined as the channel numbers 1, 2, and 3,
| 208 |
respectively.
| 209 |
For color or spectral inputs, the function "wl(p)" gives the
| 210 |
central wavelength for channel
| 211 |
.I p
| 212 |
in nanometers.
| 213 |
For convenience and compatibility with
| 214 |
.I pcomb,
| 215 |
the functions "ri(i)", "gi(i)", and "bi(i)" are predefined as
| 216 |
"ci(i,R)", "ci(i,G)", and "ci(i,B)", respectively.
| 217 |
Accordingly, the "ro", "go", and "bo"
| 218 |
variables may be used in place of "co(R)", "co(G)", and "co(B)".
| 219 |
Finally, the total number of input files is set in the constant "nfiles".
| 220 |
.PP
| 221 |
Results are sent to the standard output.
| 222 |
By default, the values will be written in the lowest precision format
| 223 |
among the inputs, but the
| 224 |
.I \-f[adfc]
| 225 |
option may be used to explicitly output components
| 226 |
as ASCII (-fa), binary doubles (-fd), floats (-ff), or common-exponent
| 227 |
colors/spectra (-fc).
| 228 |
In the latter case, the actual matrix dimensions are written in the resolution string rather than the header.
| 229 |
Also, matrix results will be written as standard
| 230 |
Radiance pictures if they have either one
| 231 |
or three components.
| 232 |
In the one-component case, the output is written as grayscale.
| 233 |
If more than 3 components are in the final matrix and
| 234 |
.I -fc
| 235 |
is specified, the output will be a Radiance spectral picture.
| 236 |
.PP
| 237 |
The
| 238 |
.I \-h
| 239 |
option may be used to reduce the information header size, which
| 240 |
can grow disproportionately, otherwise.
| 241 |
The
| 242 |
.I \-w
| 243 |
option turns off warnings about divide-by-zero and other non-fatal
| 244 |
calculation errors.
| 245 |
.SH EXAMPLES
| 246 |
To convert two hyperspectral inputs to RGB color space,
| 247 |
average them together, and write them out as a RADIANCE picture:
| 248 |
.IP "" .2i
| 249 |
rmtxcomb -C RGB -s .5 img1.spc -s .5 img2.spc > avg.hdr
| 250 |
.PP
| 251 |
Divide one set of matrix elements by the Euclidean sum of two others:
| 252 |
.IP "" .2i
| 253 |
rmtxcomb -e "co=ci(1)/sqrt(ci(2)^2+ci(3)^2)" inp1.mtx
| 254 |
inp2.mtx inp3.mtx > out.mtx
| 255 |
.PP
| 256 |
Compute the absolute and relative differences between melanopic and photopic values
| 257 |
in a spectral image:
| 258 |
.IP "" .2i
| 259 |
rmtxcomb -fa -C MY -e "abs(x):if(x,x,-x)"
| 260 |
-e "co(p)=select(p,abs(ci(1,1)-ci(1,2)),(ci(1,1)-ci(1,2))/ci(1,2))"
| 261 |
input_spec.hsr > compare.mtx
| 262 |
.PP
| 263 |
Concatenate a spectral flux coefficient matrix with a spectral sky
| 264 |
matrix to compute a set of melanopic lux values:
| 265 |
.IP "" .2i
| 266 |
rmtxcomb view_spec.mtx -m sky_spec.mtx -c M > melux.mtx
| 267 |
.SH NOTES
| 268 |
The
| 269 |
.I rmtxcomb
| 270 |
tool was created to overcome some limitations of
| 271 |
.I rmtxop
| 272 |
and
| 273 |
.I pcomb,
| 274 |
whose capabilities somewhat overlap.
| 275 |
The former loads each matrix into memory before operations,
| 276 |
and element components take 8 bytes apiece, adding up quickly.
| 277 |
Very large matrices therefore present a problem with that tool.
| 278 |
Furthermore,
| 279 |
.I rmtxop
| 280 |
does not allow arbitrary expressions, limiting
| 281 |
what can be accomplished easily on the command-line.
| 282 |
In contrast,
| 283 |
.I pcomb
| 284 |
is fully programmable and operates on its input using a
| 285 |
scanline window, so it can handle much larger input dimensions.
| 286 |
It also handles single- and three-component float matrices on
| 287 |
input and output, but unlike
| 288 |
.I rmtxop,
| 289 |
.I pcomb
| 290 |
has not been extended to handle RADIANCE hyperspectral images
| 291 |
or more general matrix data.
| 292 |
.PP
| 293 |
The
| 294 |
.I rmtxcomb
| 295 |
tool is a compromise that exceeds the capabilities of either of
| 296 |
its predecessors in certain circumstances.
| 297 |
In particular, very large matrices may be combined using
| 298 |
arbitrary, user-defined operations, and the convenient
| 299 |
color conversions of
| 300 |
.I rmtxop
| 301 |
are supported for both input and output.
| 302 |
Finally, a single matrix may be concatenated after operations,
| 303 |
permitting a flux transfer matrix with millions of rows to
| 304 |
pass through.
| 305 |
Generally speaking,
| 306 |
.I rmtxcomb
| 307 |
should be preferred over
| 308 |
.I rmtxop
| 309 |
for any operations in can handle, which is everything except
| 310 |
multiple matrix concatenations and transpose
| 311 |
operations, which are handled more efficiently by
| 312 |
.I rcollate(1)
| 313 |
in any case.
| 314 |
That said, there is no significant difference for
| 315 |
simple operations on smallish matrices, and note that only
| 316 |
.I rmtxop
| 317 |
and
| 318 |
.I dctimestep(1)
| 319 |
currently accept XML files as inputs.
| 320 |
Also, the resizing function of
| 321 |
.I pcomb
| 322 |
is not supported in
| 323 |
.I rmtxcomb,
| 324 |
and should instead be handled by
| 325 |
.I pfilt(1).
| 326 |
.SH AUTHOR
| 327 |
Greg Ward
| 328 |
.SH "SEE ALSO"
| 329 |
dctimestep(1), icalc(1), getinfo(1), pcomb(1), pfilt(1),
| 330 |
ra_xyze(1), rcalc(1),
| 331 |
rcollate(1), rcontrib(1), rcrop(1), rfluxmtx(1),
| 332 |
rmtxop(1), rtpict(1), rtrace(1), vwrays(1)
