root/radiance/ray/doc/man/man1/rlam.1
Revision: 1.12
Committed: Sat Jul 20 00:57:43 2019 UTC (5 years, 11 months ago) by greg
CVS Tags: rad5R4, rad5R3, HEAD
Added mention of rsplit(1)
1 .\" RCSid "$Id: rlam.1,v 1.11 2019/07/16 15:59:49 greg Exp $"
2 .TH RLAM 1 7/8/97 RADIANCE
3 .SH NAME
4 rlam - laminate records from multiple files
5 .SH SYNOPSIS
6 .B rlam
7 [
8 .B \-tS
9 ][
10 .B \-u
11 ][
12 .B \-iaN
13 |
14 .B \-ifN
15 |
16 .B \-idN
17 |
18 .B \-iiN
19 |
20 .B \-iwN
21 |
22 .B \-ibN
23 ][
24 .B "\-in M"
25 ]
26 input1 [options] input2 ..
27 .SH DESCRIPTION
28 .I Rlam
29 simply joins records (or lines) from multiple inputs, separating them with
30 the given string (TAB by default).
31 Different separators may be given for different files by specifying
32 additional
33 .I \-t
34 options in between each file name.
35 Note that there is no space between this option and its argument.
36 If no argument is given, then a newline is assumed.
37 If none of the input files uses an ASCII separator, then no end-of-line
38 character will be printed, either.
39 .PP
40 An input is either a file or a command.
41 Commands are given in quotes, and begin with an exclamantion point ('!').
42 If the inputs do not have the same number of records, then
43 shorter files will stop contributing to the output as they
44 run out.
45 .PP
46 The
47 .I \-ia
48 option may be used to specify ASCII input (the default), or the
49 .I \-if
50 option may be used to indicated binary IEEE 32-bit floats on input.
51 Similarly, the
52 .I \-id
53 and
54 .I \-ii
55 options may be used to indicate binary 64-bit doubles or integer words,
56 respectively.
57 The
58 .I \-iw
59 option specifies 2-byte short words, and the
60 .I \-ib
61 option specifies bytes.
62 If a number immediately follows any of these options, then it
63 indicates that multiple such values are expected for each record.
64 For example,
65 .I \-if3
66 indicates three floats per input record for the next named input.
67 In the case of the
68 .I \-ia
69 option, no number reads one line per record, and numbers
70 greater than zero take multiple lines at a time from the same stream.
71 For binary input formts, no number implies one value per record.
72 For anything other than EOL-separated input, the default tab separator
73 is reset to the empty string.
74 .PP
75 These options may be interspersed with input specifications,
76 indicating different data to draw from the different files.
77 .PP
78 If a
79 .I \-in
80 option is given with a positive integer argument, this will be the
81 maximum number of records that will be read or produced by
82 .I rlam.
83 .PP
84 A hyphen ('-') by itself can be used to indicate the standard
85 input, and may appear multiple times.
86 The
87 .I \-u
88 option forces output after each record (i.e., one run through inputs).
89 .SH EXAMPLES
90 To join files output1 and output2, separated by a comma:
91 .IP "" .2i
92 rlam \-t, output1 output2
93 .PP
94 To join a file with line numbers (starting at 0) and its reverse:
95 .IP "" .2i
96 cnt `wc \-l < lam.c` | rlam \- \-t: lam.c \-t\| '!tail \-r lam.c'
97 .PP
98 To join four data files, each having three doubles per record:
99 .IP "" .2i
100 rlam \-id3 file1.dbl file2.dbl file3.dbl file4.dbl > combined.dbl
101 .PP
102 To join two data files, the first having two words per
103 record and the second having one:
104 .IP "" .2i
105 rlam \-iw2 file1.hi2 \-iw file2.hi1 > combined.hi3
106 .SH AUTHOR
107 Greg Ward
108 .SH "SEE ALSO"
109 cnt(1), histo(1), neaten(1), rcalc(1), rsplit(1), tabfunc(1), total(1)
