1 |
.\" RCSid "$Id: rlam.1,v 1.4 2005/10/05 05:20:50 greg Exp $" |
2 |
.TH RLAM 1 7/8/97 RADIANCE |
3 |
.SH NAME |
4 |
rlam - laminate records from multiple files |
5 |
.SH SYNOPSIS |
6 |
.B rlam |
7 |
8 |
.B \-tS |
9 |
10 |
.B \-iaN |
11 |
12 |
.B \-ifN |
13 |
14 |
.B \-idN |
15 |
16 |
.B \-iwN |
17 |
18 |
input1 input2 .. |
19 |
.SH DESCRIPTION |
20 |
.I Rlam |
21 |
simply joins records (or lines) from multiple inputs, separating them with |
22 |
the given string (TAB by default). |
23 |
Different separators may be given for different files by specifying |
24 |
additional |
25 |
.I \-t |
26 |
options in between each file name. |
27 |
Note that there is no space between this option and its argument. |
28 |
If none of the input files uses an ASCII separator, then no end-of-line |
29 |
character will be printed, either. |
30 |
.PP |
31 |
An input is either a stream or a command. |
32 |
Commands are given in quotes, and begin with an exclamantion point ('!'). |
33 |
If the inputs do not have the same number of lines, then |
34 |
shorter files will stop contributing to the output as they |
35 |
run out. |
36 |
.PP |
37 |
The |
38 |
.I \-ia |
39 |
option may be used to specify ASCII input (the default), or the |
40 |
.I \-if |
41 |
option may be used to indicated binary IEEE 32-bit floats on input. |
42 |
Similarly, the |
43 |
.I \-id |
44 |
and |
45 |
.I \-iw |
46 |
options may be used to indicate binary 64-bit doubles or integer words, |
47 |
respectively. |
48 |
If an number is immediately follows any of these options, then it |
49 |
indicates that multiple such values are expected for each record. |
50 |
For example, |
51 |
.I \-if3 |
52 |
indicates three floats per input record for the next named input. |
53 |
In the case of the |
54 |
.I \-ia |
55 |
option, no number indicates one line per input record, and numbers |
56 |
greater than zero indicate that many characters exactly per record. |
57 |
For binary input formts, no number implies one value per record. |
58 |
For anything other than EOL-separated input, the default tab separator |
59 |
is reset to the empty string. |
60 |
.PP |
61 |
A hyphen ('-') by itself can be used to indicate the standard |
62 |
input, and may appear multiple times. |
63 |
.SH EXAMPLE |
64 |
To join files output1 and output2, separated by a comma: |
65 |
.IP "" .2i |
66 |
rlam \-t, output1 output2 |
67 |
.PP |
68 |
To join a file with line numbers (starting at 0) and its reverse: |
69 |
.IP "" .2i |
70 |
cnt `wc \-l < lam.c` | rlam \- \-t: lam.c \-t\| '!tail \-r lam.c' |
71 |
.PP |
72 |
To join four data files, each having three doubles per record: |
73 |
.IP "" .2i |
74 |
rlam \-id3 file1.dbl file2.dbl file3.dbl file4.dbl > combined.dbl |
75 |
.SH AUTHOR |
76 |
Greg Ward |
77 |
.SH "SEE ALSO" |
78 |
cnt(1), histo(1), neaten(1), rcalc(1), tabfunc(1), total(1) |
