--- ray/doc/man/man1/rlam.1 2007/09/04 17:36:41 1.5 +++ ray/doc/man/man1/rlam.1 2019/07/20 00:57:43 1.12 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rlam.1,v 1.5 2007/09/04 17:36:41 greg Exp $" +.\" RCSid "$Id: rlam.1,v 1.12 2019/07/20 00:57:43 greg Exp $" .TH RLAM 1 7/8/97 RADIANCE .SH NAME rlam - laminate records from multiple files @@ -7,15 +7,23 @@ rlam - laminate records from multiple files [ .B \-tS ][ +.B \-u +][ .B \-iaN | .B \-ifN | .B \-idN | +.B \-iiN +| .B \-iwN +| +.B \-ibN +][ +.B "\-in M" ] -input1 input2 .. +input1 [options] input2 .. .SH DESCRIPTION .I Rlam simply joins records (or lines) from multiple inputs, separating them with @@ -25,12 +33,13 @@ additional .I \-t options in between each file name. Note that there is no space between this option and its argument. +If no argument is given, then a newline is assumed. If none of the input files uses an ASCII separator, then no end-of-line character will be printed, either. .PP -An input is either a stream or a command. +An input is either a file or a command. Commands are given in quotes, and begin with an exclamantion point ('!'). -If the inputs do not have the same number of lines, then +If the inputs do not have the same number of records, then shorter files will stop contributing to the output as they run out. .PP @@ -42,25 +51,42 @@ option may be used to indicated binary IEEE 32-bit flo Similarly, the .I \-id and -.I \-iw +.I \-ii options may be used to indicate binary 64-bit doubles or integer words, respectively. -If an number is immediately follows any of these options, then it +The +.I \-iw +option specifies 2-byte short words, and the +.I \-ib +option specifies bytes. +If a number immediately follows any of these options, then it indicates that multiple such values are expected for each record. For example, .I \-if3 indicates three floats per input record for the next named input. In the case of the .I \-ia -option, no number indicates one line per input record, and numbers -greater than zero indicate that many characters exactly per record. +option, no number reads one line per record, and numbers +greater than zero take multiple lines at a time from the same stream. For binary input formts, no number implies one value per record. For anything other than EOL-separated input, the default tab separator is reset to the empty string. .PP +These options may be interspersed with input specifications, +indicating different data to draw from the different files. +.PP +If a +.I \-in +option is given with a positive integer argument, this will be the +maximum number of records that will be read or produced by +.I rlam. +.PP A hyphen ('-') by itself can be used to indicate the standard input, and may appear multiple times. -.SH EXAMPLE +The +.I \-u +option forces output after each record (i.e., one run through inputs). +.SH EXAMPLES To join files output1 and output2, separated by a comma: .IP "" .2i rlam \-t, output1 output2 @@ -72,7 +98,12 @@ cnt `wc \-l < lam.c` | rlam \- \-t: lam.c \-t\| '!tail To join four data files, each having three doubles per record: .IP "" .2i rlam \-id3 file1.dbl file2.dbl file3.dbl file4.dbl > combined.dbl +.PP +To join two data files, the first having two words per +record and the second having one: +.IP "" .2i +rlam \-iw2 file1.hi2 \-iw file2.hi1 > combined.hi3 .SH AUTHOR Greg Ward .SH "SEE ALSO" -cnt(1), histo(1), neaten(1), rcalc(1), tabfunc(1), total(1) +cnt(1), histo(1), neaten(1), rcalc(1), rsplit(1), tabfunc(1), total(1)
