root/Development/ray/doc/man/man1/rlam.1
Revision: 1.1
Committed: Thu Jan 1 19:31:45 2004 UTC (22 years ago) by greg
CVS Tags: rad3R6P1, rad3R6
1 .\" RCSid "$Id$"
2 .TH RLAM 1 7/8/97 RADIANCE
3 .SH NAME
4 rlam - laminate lines (records) from multiple files
5 .SH SYNOPSIS
6 .B rlam
7 [
8 .B \-tC
9 ]
10 input1 input2 ..
11 .SH DESCRIPTION
12 .I Rlam
13 simply joins lines from multiple inputs, separating them with
14 the given tab character (TAB by default).
15 An input is either a stream or a command.
16 Commands are given in quotes, and begin with an exclamantion point ('!').
17 If the inputs do not have the same number of lines, then
18 shorter files will stop contributing to the output as they
19 run out.
20 .PP
21 A hyphen ('-') by itself can be used to indicate the standard
22 input.
23 .SH EXAMPLE
24 To join files output1 and output2, separated by a comma:
25 .IP "" .2i
26 rlam -t, output1 output2
27 .PP
28 To join a file with line numbers (starting at 0) and its reverse:
29 .IP "" .2i
30 cnt `wc -l < lam.c` | rlam - -t: lam.c -t\| '\!tail -r lam.c'
31 .SH AUTHOR
32 Greg Ward
33 .SH "SEE ALSO"
34 cnt(1), neaten(1), rcalc(1), tabfunc(1), total(1)
