--- ray/doc/man/man1/rlam.1 2004/01/01 19:31:45 1.1 +++ ray/doc/man/man1/rlam.1 2005/06/13 22:40:46 1.2 @@ -1,17 +1,21 @@ -.\" RCSid "$Id: rlam.1,v 1.1 2004/01/01 19:31:45 greg Exp $" +.\" RCSid "$Id: rlam.1,v 1.2 2005/06/13 22:40:46 greg Exp $" .TH RLAM 1 7/8/97 RADIANCE .SH NAME rlam - laminate lines (records) from multiple files .SH SYNOPSIS .B rlam [ -.B \-tC +.B \-tS ] input1 input2 .. .SH DESCRIPTION .I Rlam simply joins lines from multiple inputs, separating them with -the given tab character (TAB by default). +the given separator string (TAB by default). +Different separators may be given for different files by specifying +additional +.I \-t +options in between each file name. An input is either a stream or a command. Commands are given in quotes, and begin with an exclamantion point ('!'). If the inputs do not have the same number of lines, then @@ -27,7 +31,7 @@ rlam -t, output1 output2 .PP To join a file with line numbers (starting at 0) and its reverse: .IP "" .2i -cnt `wc -l < lam.c` | rlam - -t: lam.c -t\| '\!tail -r lam.c' +cnt `wc -l < lam.c` | rlam - -t: lam.c -t\| '!tail -r lam.c' .SH AUTHOR Greg Ward .SH "SEE ALSO"
