1 |
.\" RCSid "$Id$" |
2 |
.TH RLAM 1 7/8/97 RADIANCE |
3 |
.SH NAME |
4 |
rlam - laminate lines (records) from multiple files |
5 |
.SH SYNOPSIS |
6 |
.B rlam |
7 |
8 |
.B \-tC |
9 |
10 |
input1 input2 .. |
11 |
.SH DESCRIPTION |
12 |
.I Rlam |
13 |
simply joins lines from multiple inputs, separating them with |
14 |
the given tab character (TAB by default). |
15 |
An input is either a stream or a command. |
16 |
Commands are given in quotes, and begin with an exclamantion point ('!'). |
17 |
If the inputs do not have the same number of lines, then |
18 |
shorter files will stop contributing to the output as they |
19 |
run out. |
20 |
.PP |
21 |
A hyphen ('-') by itself can be used to indicate the standard |
22 |
input. |
23 |
.SH EXAMPLE |
24 |
To join files output1 and output2, separated by a comma: |
25 |
.IP "" .2i |
26 |
rlam -t, output1 output2 |
27 |
.PP |
28 |
To join a file with line numbers (starting at 0) and its reverse: |
29 |
.IP "" .2i |
30 |
cnt `wc -l < lam.c` | rlam - -t: lam.c -t\| '\!tail -r lam.c' |
31 |
.SH AUTHOR |
32 |
Greg Ward |
33 |
.SH "SEE ALSO" |
34 |
cnt(1), neaten(1), rcalc(1), tabfunc(1), total(1) |
