root/radiance/ray/doc/man/man1/rlam.1
Revision: 1.9
Committed: Thu Jul 4 17:36:04 2019 UTC (5 years, 10 months ago) by greg
Changes since 1.8: +14 -6 lines
Changed rlam -iaN behavior to read N lines rather than N characters
1 .\" RCSid "$Id: rlam.1,v 1.8 2016/03/24 18:48:28 greg Exp $"
2 .TH RLAM 1 7/8/97 RADIANCE
3 .SH NAME
4 rlam - laminate records from multiple files
5 .SH SYNOPSIS
6 .B rlam
7 [
8 .B \-tS
9 ][
10 .B \-u
11 ][
12 .B \-iaN
13 |
14 .B \-ifN
15 |
16 .B \-idN
17 |
18 .B \-iiN
19 |
20 .B \-iwN
21 |
22 .B \-ibN
23 ][
24 .B "\-in M"
25 ]
26 input1 [options] input2 ..
27 .SH DESCRIPTION
28 .I Rlam
29 simply joins records (or lines) from multiple inputs, separating them with
30 the given string (TAB by default).
31 Different separators may be given for different files by specifying
32 additional
33 .I \-t
34 options in between each file name.
35 Note that there is no space between this option and its argument.
36 If none of the input files uses an ASCII separator, then no end-of-line
37 character will be printed, either.
38 .PP
39 An input is either a stream or a command.
40 Commands are given in quotes, and begin with an exclamantion point ('!').
41 If the inputs do not have the same number of records, then
42 shorter files will stop contributing to the output as they
43 run out.
44 .PP
45 The
46 .I \-ia
47 option may be used to specify ASCII input (the default), or the
48 .I \-if
49 option may be used to indicated binary IEEE 32-bit floats on input.
50 Similarly, the
51 .I \-id
52 and
53 .I \-ii
54 options may be used to indicate binary 64-bit doubles or integer words,
55 respectively.
56 The
57 .I \-iw
58 option specifies 2-byte short words, and the
59 .I \-ib
60 option specifies bytes.
61 If a number is immediately follows any of these options, then it
62 indicates that multiple such values are expected for each record.
63 For example,
64 .I \-if3
65 indicates three floats per input record for the next named input.
66 In the case of the
67 .I \-ia
68 option, no number reads one line per record, and numbers
69 greater than zero take multiple lines at a time from the same stream.
70 For binary input formts, no number implies one value per record.
71 For anything other than EOL-separated input, the default tab separator
72 is reset to the empty string.
73 .PP
74 These options may be interspersed with input specifications,
75 indicating different data to draw from the different files.
76 .PP
77 If a
78 .I \-in
79 option is given with a positive integer argument, this will be the
80 maximum number of records that will be read or produced by
81 .I rlam.
82 .PP
83 A hyphen ('-') by itself can be used to indicate the standard
84 input, and may appear multiple times.
85 The
86 .I \-u
87 option forces output after each record (i.e., one run through inputs).
88 .SH EXAMPLE
89 To join files output1 and output2, separated by a comma:
90 .IP "" .2i
91 rlam \-t, output1 output2
92 .PP
93 To join a file with line numbers (starting at 0) and its reverse:
94 .IP "" .2i
95 cnt `wc \-l < lam.c` | rlam \- \-t: lam.c \-t\| '!tail \-r lam.c'
96 .PP
97 To join four data files, each having three doubles per record:
98 .IP "" .2i
99 rlam \-id3 file1.dbl file2.dbl file3.dbl file4.dbl > combined.dbl
100 .PP
101 To join two data files, the first having two words per
102 record and the second having one:
103 .IP "" .2i
104 rlam \-iw2 file1.hi2 \-iw file2.hi1 > combined.hi3
105 .SH AUTHOR
106 Greg Ward
107 .SH "SEE ALSO"
108 cnt(1), histo(1), neaten(1), rcalc(1), rsplit(1), tabfunc(1), total(1)
