root/radiance/ray/doc/man/man1/rlam.1
Fri Jun 18 21:22:49 2010 UTC (14 years, 10 months ago) by greg
Changes since 1.6: +6 -1 lines
Diff to previous 1.6
Added -u option to rlam
Fri Jun 18 01:12:57 2010 UTC (14 years, 10 months ago) by greg
Changes since 1.5: +12 -3 lines
Diff to previous 1.5
Modified rlam to use -iw option for 2-byte words and added -ii and -ib options
Tue Sep 4 17:36:41 2007 UTC (17 years, 8 months ago) by greg
CVS Tags: rad3R9, rad4R0
Changes since 1.4: +4 -4 lines
Diff to previous 1.4
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
Wed Oct 5 05:20:50 2005 UTC (19 years, 7 months ago) by greg
Changes since 1.3: +6 -3 lines
Diff to previous 1.3
Made empty string default separator for binary input
Sun Sep 25 20:36:01 2005 UTC (19 years, 7 months ago) by greg
Changes since 1.2: +42 -5 lines
Diff to previous 1.2
Added -i option to allow rlam to work with binary input records
Mon Jun 13 22:40:46 2005 UTC (19 years, 10 months ago) by greg
Changes since 1.1: +8 -4 lines
Diff to previous 1.1
Changed rlam -t option to accept strings as well as tab characters
Thu Jan 1 19:31:45 2004 UTC (21 years, 4 months ago) by greg
