1 |
.\" RCSid "$Id: rhpict.1,v 1.3 2004/01/01 19:31:45 greg Exp $" |
2 |
.TH RHPICT 1 3/10/99 RADIANCE |
3 |
.SH NAME |
4 |
rhpict - render a RADIANCE picture from a holodeck file |
5 |
.SH SYNOPSIS |
6 |
.B rhpict |
7 |
8 |
.B options |
9 |
10 |
.B holodeck |
11 |
.SH DESCRIPTION |
12 |
.I Rhpict |
13 |
generates one or more pictures from the RADIANCE holodeck file |
14 |
.I holodeck |
15 |
and sends them to the standard output. |
16 |
The |
17 |
.I \-o |
18 |
option may be used to specify an alternate output file. |
19 |
Other options specify the viewing parameters and provide |
20 |
some control over the calculation. |
21 |
.PP |
22 |
The view as well as some of the other controls |
23 |
are shared in common with the |
24 |
.I rpict(1) |
25 |
command. |
26 |
The options that are unique to |
27 |
.I rhpict |
28 |
are given first, followed by the more familiar ones. |
29 |
.TP 10n |
30 |
.BI -s |
31 |
Use the smooth resampling algorithm, which amounts to linear interpolation |
32 |
between ray samples with additional edge detection along color and object |
33 |
boundaries. |
34 |
This is the default. |
35 |
.TP |
36 |
.BI -r \ rf |
37 |
Use random resampling, where |
38 |
.I rf |
39 |
is a fraction from 0 to 1 indicating the desired degree of randomness. |
40 |
A random fraction of 0 is not the same as smooth resampling, |
41 |
because there is no linear interpolation, just Voronoi regions. |
42 |
Values greater than 1 produce interesting underwater effects. |
43 |
.TP |
44 |
.BI -x \ res |
45 |
Set the maximum x resolution to |
46 |
.I res. |
47 |
.TP |
48 |
.BI -y \ res |
49 |
Set the maximum y resolution to |
50 |
.I res. |
51 |
.TP |
52 |
.BI -pa \ rat |
53 |
Set the pixel aspect ratio (height over width) to |
54 |
.I rat. |
55 |
Either the x or the y resolution will be reduced so that the pixels have |
56 |
this ratio for the specified view. |
57 |
If |
58 |
.I rat |
59 |
is zero, then the x and y resolutions will adhere to the given maxima. |
60 |
.TP |
61 |
.BI -pe \ expval |
62 |
Set the exposure value for the output pictures to |
63 |
.I expval. |
64 |
Since filtering is performed by |
65 |
.I rhpict, |
66 |
there is little sense in passing the output through |
67 |
.I pfilt(1), |
68 |
other than changing the exposure. |
69 |
This option eliminates that need. |
70 |
The value may be specified either as a multiplier, or as a number |
71 |
f-stops preceeded by a '+' or '-' character. |
72 |
.TP |
73 |
.BI -vt t |
74 |
Set view type to |
75 |
.I t. |
76 |
If |
77 |
.I t |
78 |
is 'v', a perspective view is selected. |
79 |
If |
80 |
.I t |
81 |
is 'l', a parallel view is used. |
82 |
A cylindrical panorma may be selected by setting |
83 |
.I t |
84 |
to the letter 'c'. |
85 |
This view is like a standard perspective vertically, but projected |
86 |
on a cylinder horizontally (like a soupcan's-eye view). |
87 |
Two fisheye views are provided as well; 'h' yields a hemispherical fisheye |
88 |
view and 'a' results in angular fisheye distortion. |
89 |
A hemispherical fisheye is a projection of the hemisphere onto a circle. |
90 |
The maximum view angle for this type is 180 degrees. |
91 |
An angular fisheye view is defined such that distance from the center of |
92 |
the image is proportional to the angle from the central view direction. |
93 |
An angular fisheye can display a full 360 degrees. |
94 |
Note that there is no space between the view type |
95 |
option and its single letter argument. |
96 |
.TP |
97 |
.BI -vp " x y z" |
98 |
Set the view point to |
99 |
.I "x y z". |
100 |
This is the focal point of a perspective view or the |
101 |
center of a parallel projection. |
102 |
.TP |
103 |
.BI -vd " xd yd zd" |
104 |
Set the view direction vector to |
105 |
.I "xd yd zd". |
106 |
.TP |
107 |
.BI -vu " xd yd zd" |
108 |
Set the view up vector (vertical direction) to |
109 |
.I "xd yd zd". |
110 |
.TP |
111 |
.BI -vh \ val |
112 |
Set the view horizontal size to |
113 |
.I val. |
114 |
For a perspective projection (including fisheye views), |
115 |
.I val |
116 |
is the horizontal field of view (in degrees). |
117 |
For a parallel projection, |
118 |
.I val |
119 |
is the view width in world coordinates. |
120 |
.TP |
121 |
.BI -vv \ val |
122 |
Set the view vertical size to |
123 |
.I val. |
124 |
.TP |
125 |
.BI -vo \ val |
126 |
Set the view fore clipping plane at a distance of |
127 |
.I val |
128 |
from the view point. |
129 |
The plane will be perpendicular to the view direction for |
130 |
perspective and parallel view types. |
131 |
For fisheye view types, the clipping plane is actually a clipping |
132 |
sphere, centered on the view point with radius |
133 |
.I val. |
134 |
Objects in front of this imaginary surface will not be visible. |
135 |
This may be useful for seeing through walls (to get a longer |
136 |
perspective from an exterior view point) or for incremental |
137 |
rendering. |
138 |
A value of zero implies no foreground clipping. |
139 |
A negative value produces some interesting effects, since it creates an |
140 |
inverted image for objects behind the viewpoint. |
141 |
This possibility is provided mostly for the purpose of rendering |
142 |
stereographic holograms. |
143 |
.TP |
144 |
.BI -va \ val |
145 |
Set the view aft clipping plane at a distance of |
146 |
.I val |
147 |
148 |
Like the view fore plane, it will be perpendicular to the view |
149 |
direction for perspective and parallel view types. |
150 |
151 |
152 |
.I val. |
153 |
Objects behind this imaginary surface will not be visible. |
154 |
A value of zero means no aft clipping, and is the only way to see |
155 |
infinitely distant objects such as the sky. |
156 |
.TP |
157 |
.BI -vs \ val |
158 |
Set the view shift to |
159 |
.I val. |
160 |
This is the amount the actual image will be shifted to the right of |
161 |
162 |
This is option is useful for generating skewed perspectives or |
163 |
rendering an image a piece at a time. |
164 |
A value of 1 means that the rendered image starts just to the right of |
165 |
the normal view. |
166 |
A value of \-1 would be to the left. |
167 |
Larger or fractional values are permitted as well. |
168 |
.TP |
169 |
.BI -vl \ val |
170 |
Set the view lift to |
171 |
.I val. |
172 |
This is the amount the actual image will be lifted up from the |
173 |
specified view, similar to the |
174 |
.I \-vs |
175 |
option. |
176 |
.TP |
177 |
.BI -vf \ file |
178 |
Get view parameters from |
179 |
.I file, |
180 |
which may be a picture or a file created by rvu (with the "view" command). |
181 |
.TP |
182 |
.BI -S \ seqstart |
183 |
Instead of generating a single picture based only on the view |
184 |
parameters given on the command line, this option causes |
185 |
.I rhpict |
186 |
to read view options from the standard input and for each line |
187 |
containing a valid view specification, generate a corresponding |
188 |
picture. |
189 |
.I Seqstart |
190 |
is a positive integer that will be associated with the first output |
191 |
frame, and incremented for successive output frames. |
192 |
By default, each frame is concatenated to the output stream, but it |
193 |
is possible to change this action using the |
194 |
.I \-o |
195 |
option (described below). |
196 |
Multiple frames may be later extracted from a single output stream using the |
197 |
.I ra_rgbe(1) |
198 |
command. |
199 |
.TP |
200 |
.BI -o \ fspec |
201 |
Send the picture(s) to the file(s) given by |
202 |
.I fspec |
203 |
instead of the standard output. |
204 |
If this option is used in combination with |
205 |
.I \-S |
206 |
and |
207 |
.I fspec |
208 |
contains an integer field for |
209 |
.I printf(3) |
210 |
(eg., "%03d") then the actual output file name will include |
211 |
the current frame number. |
212 |
.TP |
213 |
.BR \-w |
214 |
Turn off warning messages. |
215 |
.SH EXAMPLE |
216 |
rhpict \-vp 10 5 3 \-vd 1 \-.5 0 scene.hdk > scene.pic |
217 |
.PP |
218 |
rpict \-S 1 \-o frame%02d.pic scene.hdk < keyframes.vf |
219 |
.SH AUTHOR |
220 |
Greg Ward |
221 |
.SH "SEE ALSO" |
222 |
getinfo(1), pfilt(1), pinterp(1), |
223 |
printf(3), ra_rgbe(1), rholo(1), rpict(1), rvu(1) |
