root/radiance/ray/doc/man/man1/rhpict.1
Revision: 1.6
Committed: Mon Nov 10 19:08:17 2008 UTC (16 years, 9 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R1, rad4R0, rad4R2P1, rad4R2P2, HEAD
Changes since 1.5: +3 -3 lines
1 .\" RCSid "$Id: rhpict.1,v 1.5 2008/03/11 02:21:45 greg Exp $"
2 .TH RHPICT 1 3/10/99 RADIANCE
3 .SH NAME
4 rhpict - render a RADIANCE picture from a holodeck file
5 .SH SYNOPSIS
6 .B rhpict
7 [
8 .B options
9 ]
10 .B holodeck
11 .SH DESCRIPTION
12 .I Rhpict
13 generates one or more pictures from the RADIANCE holodeck file
14 .I holodeck
15 and sends them to the standard output.
16 The
17 .I \-o
18 option may be used to specify an alternate output file.
19 Other options specify the viewing parameters and provide
20 some control over the calculation.
21 .PP
22 The view as well as some of the other controls
23 are shared in common with the
24 .I rpict(1)
25 command.
26 The options that are unique to
27 .I rhpict
28 are given first, followed by the more familiar ones.
29 .TP 10n
30 .BI -s
31 Use the smooth resampling algorithm, which amounts to linear interpolation
32 between ray samples with additional edge detection along color and object
33 boundaries.
34 This is the default.
35 .TP
36 .BI -r \ rf
37 Use random resampling, where
38 .I rf
39 is a fraction from 0 to 1 indicating the desired degree of randomness.
40 A random fraction of 0 is not the same as smooth resampling,
41 because there is no linear interpolation, just Voronoi regions.
42 Values greater than 1 produce interesting underwater effects.
43 .TP
44 .BI -x \ res
45 Set the maximum x resolution to
46 .I res.
47 .TP
48 .BI -y \ res
49 Set the maximum y resolution to
50 .I res.
51 .TP
52 .BI -pa \ rat
53 Set the pixel aspect ratio (height over width) to
54 .I rat.
55 Either the x or the y resolution will be reduced so that the pixels have
56 this ratio for the specified view.
57 If
58 .I rat
59 is zero, then the x and y resolutions will adhere to the given maxima.
60 .TP
61 .BI -pe \ expval
62 Set the exposure value for the output pictures to
63 .I expval.
64 Since filtering is performed by
65 .I rhpict,
66 there is little sense in passing the output through
67 .I pfilt(1),
68 other than changing the exposure.
69 This option eliminates that need.
70 The value may be specified either as a multiplier, or as a number
71 f-stops preceeded by a '+' or '-' character.
72 .TP
73 .BI -vt t
74 Set view type to
75 .I t.
76 If
77 .I t
78 is 'v', a perspective view is selected.
79 If
80 .I t
81 is 'l', a parallel view is used.
82 A cylindrical panorma may be selected by setting
83 .I t
84 to the letter 'c'.
85 This view is like a standard perspective vertically, but projected
86 on a cylinder horizontally (like a soupcan's-eye view).
87 Three fisheye views are provided as well; 'h' yields a hemispherical fisheye
88 view, 'a' results in angular fisheye distortion, and 's'
89 results in a planisphere (stereographic) projection.
90 A hemispherical fisheye is a projection of the hemisphere onto a circle.
91 The maximum view angle for this type is 180 degrees.
92 An angular fisheye view is defined such that distance from the center of
93 the image is proportional to the angle from the central view direction.
94 An angular fisheye can display a full 360 degrees.
95 A planisphere fisheye view maintains angular relationships between lines,
96 and is commonly used for sun path analysis.
97 This is more commonly known as a
98 "stereographic projection," but we avoid the term here so as not to
99 confuse it with a stereoscopic pair.
100 A planisphere fisheye can display up to (but not including) 360 degrees,
101 although distortion becomes extreme as this limit is approached.
102 Note that there is no space between the view type
103 option and its single letter argument.
104 .TP
105 .BI -vp " x y z"
106 Set the view point to
107 .I "x y z".
108 This is the focal point of a perspective view or the
109 center of a parallel projection.
110 .TP
111 .BI -vd " xd yd zd"
112 Set the view direction vector to
113 .I "xd yd zd".
114 .TP
115 .BI -vu " xd yd zd"
116 Set the view up vector (vertical direction) to
117 .I "xd yd zd".
118 .TP
119 .BI -vh \ val
120 Set the view horizontal size to
121 .I val.
122 For a perspective projection (including fisheye views),
123 .I val
124 is the horizontal field of view (in degrees).
125 For a parallel projection,
126 .I val
127 is the view width in world coordinates.
128 .TP
129 .BI -vv \ val
130 Set the view vertical size to
131 .I val.
132 .TP
133 .BI -vo \ val
134 Set the view fore clipping plane at a distance of
135 .I val
136 from the view point.
137 The plane will be perpendicular to the view direction for
138 perspective and parallel view types.
139 For fisheye view types, the clipping plane is actually a clipping
140 sphere, centered on the view point with radius
141 .I val.
142 Objects in front of this imaginary surface will not be visible.
143 This may be useful for seeing through walls (to get a longer
144 perspective from an exterior view point) or for incremental
145 rendering.
146 A value of zero implies no foreground clipping.
147 A negative value produces some interesting effects, since it creates an
148 inverted image for objects behind the viewpoint.
149 This possibility is provided mostly for the purpose of rendering
150 stereographic holograms.
151 .TP
152 .BI -va \ val
153 Set the view aft clipping plane at a distance of
154 .I val
155 from the view point.
156 Like the view fore plane, it will be perpendicular to the view
157 direction for perspective and parallel view types.
158 For fisheye view types, the clipping plane is actually a clipping
159 sphere, centered on the view point with radius
160 .I val.
161 Objects behind this imaginary surface will not be visible.
162 A value of zero means no aft clipping, and is the only way to see
163 infinitely distant objects such as the sky.
164 .TP
165 .BI -vs \ val
166 Set the view shift to
167 .I val.
168 This is the amount the actual image will be shifted to the right of
169 the specified view.
170 This is option is useful for generating skewed perspectives or
171 rendering an image a piece at a time.
172 A value of 1 means that the rendered image starts just to the right of
173 the normal view.
174 A value of \-1 would be to the left.
175 Larger or fractional values are permitted as well.
176 .TP
177 .BI -vl \ val
178 Set the view lift to
179 .I val.
180 This is the amount the actual image will be lifted up from the
181 specified view, similar to the
182 .I \-vs
183 option.
184 .TP
185 .BI -vf \ file
186 Get view parameters from
187 .I file,
188 which may be a picture or a file created by rvu (with the "view" command).
189 .TP
190 .BI -S \ seqstart
191 Instead of generating a single picture based only on the view
192 parameters given on the command line, this option causes
193 .I rhpict
194 to read view options from the standard input and for each line
195 containing a valid view specification, generate a corresponding
196 picture.
197 .I Seqstart
198 is a positive integer that will be associated with the first output
199 frame, and incremented for successive output frames.
200 By default, each frame is concatenated to the output stream, but it
201 is possible to change this action using the
202 .I \-o
203 option (described below).
204 Multiple frames may be later extracted from a single output stream using the
205 .I ra_rgbe(1)
206 command.
207 .TP
208 .BI -o \ fspec
209 Send the picture(s) to the file(s) given by
210 .I fspec
211 instead of the standard output.
212 If this option is used in combination with
213 .I \-S
214 and
215 .I fspec
216 contains an integer field for
217 .I printf(3)
218 (eg., "%03d") then the actual output file name will include
219 the current frame number.
220 .TP
221 .BR \-w
222 Turn off warning messages.
223 .SH EXAMPLE
224 rhpict \-vp 10 5 3 \-vd 1 \-.5 0 scene.hdk > scene.hdr
225 .PP
226 rpict \-S 1 \-o frame%02d.hdr scene.hdk < keyframes.vf
227 .SH AUTHOR
228 Greg Ward
229 .SH "SEE ALSO"
230 getinfo(1), pfilt(1), pinterp(1),
231 printf(3), ra_rgbe(1), rholo(1), rpict(1), rvu(1)
