root/radiance/ray/doc/man/man1/rhpict.1
Revision: 1.2
Committed: Tue Dec 9 15:59:06 2003 UTC (21 years, 2 months ago) by greg
Fixed RCSid specification
1 .\" RCSid "$Id$"
2 .TH RHPICT 1 3/10/99 RADIANCE
3 .SH NAME
4 rhpict - render a RADIANCE picture from a holodeck file
5 .SH SYNOPSIS
6 .B rhpict
7 [
8 .B options
9 ]
10 .B holodeck
11 .SH DESCRIPTION
12 .I Rhpict
13 generates one or more pictures from the RADIANCE holodeck file
14 .I holodeck
15 and sends them to the standard output.
16 The
17 .I \-o
18 option may be used to specify an alternate output file.
19 Other options specify the viewing parameters and provide
20 some control over the calculation.
21 .PP
22 The view as well as some of the other controls
23 are shared in common with the
24 .I rpict(1)
25 command.
26 The options that are unique to
27 .I rhpict
28 are given first, followed by the more familiar ones.
29 .TP 10n
30 .BI -s
31 Use the smooth resampling algorithm, which amounts to linear interpolation
32 between ray samples with additional edge detection along color and object
33 boundaries.
34 This is the default.
35 .TP
36 .BI -r \ rf
37 Use random resampling, where
38 .I rf
39 is a fraction from 0 to 1 indicating the desired degree of randomness.
40 A random fraction of 0 is not the same as smooth resampling,
41 because there is no linear interpolation, just Voronoi regions.
42 Values greater than 1 produce interesting underwater effects.
43 .TP
44 .BI -x \ res
45 Set the maximum x resolution to
46 .I res.
47 .TP
48 .BI -y \ res
49 Set the maximum y resolution to
50 .I res.
51 .TP
52 .BI -pa \ rat
53 Set the pixel aspect ratio (height over width) to
54 .I rat.
55 Either the x or the y resolution will be reduced so that the pixels have
56 this ratio for the specified view.
57 If
58 .I rat
59 is zero, then the x and y resolutions will adhere to the given maxima.
60 .TP
61 .BI -pe \ expval
62 Set the exposure value for the output pictures to
63 .I expval.
64 Since filtering is performed by
65 .I rhpict,
66 there is little sense in passing the output through
67 .I pfilt(1),
68 other than changing the exposure.
69 This option eliminates that need.
70 The value may be specified either as a multiplier, or as a number
71 f-stops preceeded by a '+' or '-' character.
72 .TP
73 .BI -vt t
74 Set view type to
75 .I t.
76 If
77 .I t
78 is 'v', a perspective view is selected.
79 If
80 .I t
81 is 'l', a parallel view is used.
82 A cylindrical panorma may be selected by setting
83 .I t
84 to the letter 'c'.
85 This view is like a standard perspective vertically, but projected
86 on a cylinder horizontally (like a soupcan's-eye view).
87 Two fisheye views are provided as well; 'h' yields a hemispherical fisheye
88 view and 'a' results in angular fisheye distortion.
89 A hemispherical fisheye is a projection of the hemisphere onto a circle.
90 The maximum view angle for this type is 180 degrees.
91 An angular fisheye view is defined such that distance from the center of
92 the image is proportional to the angle from the central view direction.
93 An angular fisheye can display a full 360 degrees.
94 Note that there is no space between the view type
95 option and its single letter argument.
96 .TP
97 .BI -vp " x y z"
98 Set the view point to
99 .I "x y z".
100 This is the focal point of a perspective view or the
101 center of a parallel projection.
102 .TP
103 .BI -vd " xd yd zd"
104 Set the view direction vector to
105 .I "xd yd zd".
106 .TP
107 .BI -vu " xd yd zd"
108 Set the view up vector (vertical direction) to
109 .I "xd yd zd".
110 .TP
111 .BI -vh \ val
112 Set the view horizontal size to
113 .I val.
114 For a perspective projection (including fisheye views),
115 .I val
116 is the horizontal field of view (in degrees).
117 For a parallel projection,
118 .I val
119 is the view width in world coordinates.
120 .TP
121 .BI -vv \ val
122 Set the view vertical size to
123 .I val.
124 .TP
125 .BI -vo \ val
126 Set the view fore clipping plane at a distance of
127 .I val
128 from the view point.
129 The plane will be perpendicular to the view direction for
130 perspective and parallel view types.
131 For fisheye view types, the clipping plane is actually a clipping
132 sphere, centered on the view point with radius
133 .I val.
134 Objects in front of this imaginary surface will not be visible.
135 This may be useful for seeing through walls (to get a longer
136 perspective from an exterior view point) or for incremental
137 rendering.
138 A value of zero implies no foreground clipping.
139 A negative value produces some interesting effects, since it creates an
140 inverted image for objects behind the viewpoint.
141 This possibility is provided mostly for the purpose of rendering
142 stereographic holograms.
143 .TP
144 .BI -va \ val
145 Set the view aft clipping plane at a distance of
146 .I val
147 from the view point.
148 Like the view fore plane, it will be perpendicular to the view
149 direction for perspective and parallel view types.
150 For fisheye view types, the clipping plane is actually a clipping
151 sphere, centered on the view point with radius
152 .I val.
153 Objects behind this imaginary surface will not be visible.
154 A value of zero means no aft clipping, and is the only way to see
155 infinitely distant objects such as the sky.
156 .TP
157 .BI -vs \ val
158 Set the view shift to
159 .I val.
160 This is the amount the actual image will be shifted to the right of
161 the specified view.
162 This is option is useful for generating skewed perspectives or
163 rendering an image a piece at a time.
164 A value of 1 means that the rendered image starts just to the right of
165 the normal view.
166 A value of -1 would be to the left.
167 Larger or fractional values are permitted as well.
168 .TP
169 .BI -vl \ val
170 Set the view lift to
171 .I val.
172 This is the amount the actual image will be lifted up from the
173 specified view, similar to the
174 .I \-vs
175 option.
176 .TP
177 .BI -vf \ file
178 Get view parameters from
179 .I file,
180 which may be a picture or a file created by rview (with the "view" command).
181 .TP
182 .BI -S \ seqstart
183 Instead of generating a single picture based only on the view
184 parameters given on the command line, this option causes
185 .I rhpict
186 to read view options from the standard input and for each line
187 containing a valid view specification, generate a corresponding
188 picture.
189 .I Seqstart
190 is a positive integer that will be associated with the first output
191 frame, and incremented for successive output frames.
192 By default, each frame is concatenated to the output stream, but it
193 is possible to change this action using the
194 .I \-o
195 option (described below).
196 Multiple frames may be later extracted from a single output stream using the
197 .I ra_rgbe(1)
198 command.
199 .TP
200 .BI -o \ fspec
201 Send the picture(s) to the file(s) given by
202 .I fspec
203 instead of the standard output.
204 If this option is used in combination with
205 .I \-S
206 and
207 .I fspec
208 contains an integer field for
209 .I printf(3)
210 (eg., "%03d") then the actual output file name will include
211 the current frame number.
212 .TP
213 .BR \-w
214 Turn off warning messages.
215 .SH EXAMPLE
216 rhpict -vp 10 5 3 -vd 1 -.5 0 scene.hdk > scene.pic
217 .PP
218 rpict -S 1 -o frame%02d.pic scene.hdk < keyframes.vf
219 .SH AUTHOR
220 Greg Ward
221 .SH "SEE ALSO"
222 getinfo(1), pfilt(1), pinterp(1),
223 printf(3), ra_rgbe(1), rholo(1), rpict(1), rview(1)
