1 |
.\" RCSid "$Id" |
2 |
.TH RHOPTIMIZE 1 1/25/99 RADIANCE |
3 |
.SH NAME |
4 |
rhoptimize - optimize beam locations in holodeck file |
5 |
.SH SYNOPSIS |
6 |
.B rhoptimize |
7 |
8 |
.B \-u |
9 |
10 |
.B src_holo |
11 |
12 |
.B dest_holo |
13 |
14 |
.SH DESCRIPTION |
15 |
.I Rhoptimize |
16 |
optimizes beam positions and eliminates fragment waste in the holodeck file |
17 |
.I src_holo, |
18 |
writing the result to |
19 |
.I dest_holo, |
20 |
or back into |
21 |
.I src_holo |
22 |
if only one argument is given. |
23 |
This may improve rendering speed on large holodecks, which tend to have |
24 |
widely dispersed beam positions that cause delays due to long file seeks. |
25 |
It may also reduce the size of the file, since large holodecks become |
26 |
fragmented as they fill up with new ray samples. |
27 |
(Use the |
28 |
.I rhinfo(1) |
29 |
program to determine holodeck file fragmentation.) |
30 |
The |
31 |
.I \-u |
32 |
option adds a check to make sure that each ray sample is unique, i.e., the same sample |
33 |
is never given twice. |
34 |
This check is usually unnecessary, but may eliminate redundant samples from some |
35 |
holodeck files. |
36 |
.SH EXAMPLE |
37 |
To optimize the beam order in old.hdk and write the results to new.hdk: |
38 |
.IP "" .2i |
39 |
rhoptimize old.hdk new.hdk |
40 |
.PP |
41 |
To optimize beam order in scene.hdk: |
42 |
.IP "" .2i |
43 |
rhoptimize scene.hdk |
44 |
.SH NOTES |
45 |
If |
46 |
.I rhoptimize |
47 |
is given only one file argument, |
48 |
it creates a temporary file in the same directory, and moves it onto |
49 |
the original file once it has successfully completed its operation. |
50 |
If the operation fails for some reason, the temporary file is removed |
51 |
and the original holodeck is left unchanged. |
52 |
.PP |
53 |
This program generally takes several minutes to run and offers no progress |
54 |
reports. |
55 |
.SH FILES |
56 |
rho????.hdk temporary file to hold new holodeck |
57 |
.SH AUTHOR |
58 |
Greg Ward Larson |
59 |
.SH ACKNOWLEDGMENT |
60 |
This work was supported by Silicon Graphics, Inc. |
61 |
.SH "SEE ALSO" |
62 |
getinfo(1), pfilt(1), psign(1), rhcopy(1), rhinfo(1), rholo(1), rpict(1) |
