| 1 |
.\" RCSid "$Id: rholo.1,v 1.3 2004/01/01 19:31:45 greg Exp $"
| 2 |
.TH RHOLO 1 1/14/99 RADIANCE
| 3 |
.SH NAME
| 4 |
rholo - generate/view a RADIANCE holodeck
| 5 |
.SH SYNOPSIS
| 6 |
.B rholo
| 7 |
| 8 |
.B "\-n npr"
| 9 |
| 10 |
.B "\-o dev"
| 11 |
| 12 |
.B \-w
| 13 |
| 14 |
.B \-i
| 15 |
| 16 |
.B \-f
| 17 |
| 18 |
.B \-r
| 19 |
| 20 |
.B hdkfile
| 21 |
| 22 |
.B "varfile | + | -"
| 23 |
| 24 |
.B "VAR\=value .."
| 25 |
| 26 |
| 27 |
.SH DESCRIPTION
| 28 |
.I Rholo
| 29 |
is a program for generating and viewing holodeck files.
| 30 |
Similar to
| 31 |
.I rvu(1),
| 32 |
.I rholo
| 33 |
can compute views interactively, but unlike
| 34 |
.I rvu,
| 35 |
it reuses any and all information that was previously computed in
| 36 |
this or earlier runs using the given holodeck file,
| 37 |
.I hdkfile.
| 38 |
.PP
| 39 |
The
| 40 |
.I \-n
| 41 |
option sets the number of
| 42 |
.I rtrace(1)
| 43 |
processes to start for the calculation.
| 44 |
It defaults to zero, which means that no new rays will be calculated.
| 45 |
In general, it is unwise to start more processes than there are
| 46 |
processors on the system.
| 47 |
On a multiprocessing system with 4 or more processors, a value one
| 48 |
less than the total should yield optimal interactive rates on a
| 49 |
lightly loaded system.
| 50 |
.PP
| 51 |
The \-o
| 52 |
option sets the output device to use for display.
| 53 |
Currently, there are at least two display drivers available,
| 54 |
.I x11
| 55 |
and
| 56 |
.I glx.
| 57 |
If no output device is specified, then
| 58 |
.I rholo
| 59 |
will start a global calculation of the holodeck, filling it
| 60 |
in as time goes by.
| 61 |
The quality of the final holodeck will depend on how long
| 62 |
.I rholo
| 63 |
runs before it is interrupted or runs out of file space or time,
| 64 |
according to the variable settings described in the control variable
| 65 |
section, below.
| 66 |
If no output device and no processes are specified,
| 67 |
.I rholo
| 68 |
creates an empty holodeck using the given
| 69 |
.I varfile,
| 70 |
if present.
| 71 |
.PP
| 72 |
The
| 73 |
.I \-i
| 74 |
option provides for reading from the standard input.
| 75 |
Without a display driver, the input should consist only of views,
| 76 |
which will be used to limit which parts of the holodeck are rendered
| 77 |
in a batch calculation.
| 78 |
With a display driver, most of the commands understood by the driver
| 79 |
can be issued either from the operating window or the standard input.
| 80 |
These commands are described together with their window equivalents in
| 81 |
the display driver section following the control variable section.
| 82 |
.PP
| 83 |
The
| 84 |
.I \-f
| 85 |
option permits the given holodeck to be clobbered.
| 86 |
Without this option, giving both the holodeck file and a variable file (or "-")
| 87 |
will result in an error message if the holodeck exists, since giving
| 88 |
both implies that a new holodeck is being created.
| 89 |
(When reusing an existing holodeck, the variable values are taken
| 90 |
from the holodeck header, though some may be overriden by giving a "+"
| 91 |
in place of the variable file.)\0
| 92 |
Also, attempts to clear the holodeck using the interactive
| 93 |
"clobber" command will be permitted only if the
| 94 |
.I \-f
| 95 |
option is given on the initial command line.
| 96 |
.PP
| 97 |
The
| 98 |
.I \-r
| 99 |
option tells
| 100 |
.I rholo
| 101 |
to open the holodeck file read-only, which is the default if there
| 102 |
are no ray calculation processes.
| 103 |
If one or more
| 104 |
.I rtrace
| 105 |
processes are started with the
| 106 |
.I \-n
| 107 |
option and the
| 108 |
.I \-r
| 109 |
option is given or the specified holodeck is not writable by the user,
| 110 |
then any additional rays computed during the session will be discarded
| 111 |
rather than saved to the holodeck file.
| 112 |
.PP
| 113 |
One or more holodeck section boundaries are defined along with other
| 114 |
parameters in the holodeck file or,
| 115 |
if the holodeck is being created, the
| 116 |
.I rholo
| 117 |
control variable file,
| 118 |
.I varfile.
| 119 |
These section boundaries define where you may move, or at least,
| 120 |
where you will be able to see, since they determine where computed
| 121 |
rays are stored.
| 122 |
Additional variable settings may be added or overridden on the
| 123 |
command line following
| 124 |
.I varfile.
| 125 |
If no
| 126 |
.I varfile
| 127 |
is needed, a holodeck may still be created by giving a "-" on the
| 128 |
command line in place of the variable file.
| 129 |
If you wish to override some of the variable settings in an existing
| 130 |
holodeck, use a "+", followed by the new settings on the command line.
| 131 |
Upper case variables specified more than once will result in
| 132 |
a warning message (unless the
| 133 |
.I \-w
| 134 |
option is present),
| 135 |
and the last value given will be the one used, unless it would conflict
| 136 |
with something in an existing holodeck that cannot be changed, such as
| 137 |
the section boundaries.
| 138 |
Changing section boundaries requires creating a new holodeck using
| 139 |
.I rholo
| 140 |
without a
| 141 |
.I \-n
| 142 |
or
| 143 |
.I \-o
| 144 |
option, then running
| 145 |
.I rhcopy(1)
| 146 |
to fill the new holodeck with the old holodeck's contents.
| 147 |
.PP
| 148 |
The
| 149 |
.I \-w
| 150 |
option turns off warnings about multiply and misassigned variables.
| 151 |
.PP
| 152 |
Rendering variable assignments appear one per line in
| 153 |
.I varfile.
| 154 |
The name of the variable is followed by an equals sign
| 155 |
('=') and its value(s).
| 156 |
The end of line may be escaped with a backslash ('\\'), though it is
| 157 |
not usually necessary.
| 158 |
Variables that should have only one value are given in upper case.
| 159 |
Variables that may have multiple values are given in lower case.
| 160 |
Variables may be abbreviated by their first three letters.
| 161 |
Comments in
| 162 |
.I varfile
| 163 |
start with a pound sign ('#') and proceed to the end of line.
| 164 |
.SH "CONTROL VARIABLES"
| 165 |
The control variables, their interpretations and default values
| 166 |
are given below.
| 167 |
.TP 10n
| 168 |
.BR OCTREE
| 169 |
The name of the octree file.
| 170 |
The default name is the same as
| 171 |
.I hdkfile
| 172 |
but with any suffix replaced by ".oct".
| 173 |
This variable may also be read from
| 174 |
.I rad(1)
| 175 |
if the "RIF" variable is set.
| 176 |
(See below.)\0
| 177 |
.TP
| 178 |
.BR RIF
| 179 |
This variable specifies a
| 180 |
.I rad
| 181 |
input file to use as a source of rendering options and other
| 182 |
variable settings.
| 183 |
If given,
| 184 |
.I rholo
| 185 |
will execute
| 186 |
.I rad
| 187 |
and get the rendering options to later pass to
| 188 |
.I rtrace.
| 189 |
Besides prepending the
| 190 |
.I render
| 191 |
variable,
| 192 |
.I rholo
| 193 |
will also extract default settings for the common "OCTREE" variable,
| 194 |
and the "EYESEP" variable.
| 195 |
Following the file name, overriding variable settings may be given,
| 196 |
which will be passed to
| 197 |
.I rad
| 198 |
| 199 |
Settings with spaces in them should be enclosed in quotes.
| 200 |
The execution of
| 201 |
.I rad
| 202 |
will also update the contents of the octree, if necessary.
| 203 |
There is no default value for this variable.
| 204 |
.TP
| 205 |
.BR EYESEP
| 206 |
The interocular spacing for stereo viewing.
| 207 |
I.e., the world distance between the pupils of the left and right eyes.
| 208 |
| 209 |
.TP
| 210 |
.BR section
| 211 |
A section is a 6-sided parallel prism given by an origin and three axis
| 212 |
vectors (i.e., 12 floating point values in world coordinates).
| 213 |
The axis vectors define the three edges attached to the origin vertex,
| 214 |
and the other edges and vertices are determined by the parallel wall
| 215 |
constraint.
| 216 |
A holodeck section is a region in which the user may freely move about
| 217 |
to obtain a view of what is outside that region.
| 218 |
In object rendering mode, a section may instead contain a detailed
| 219 |
object to be viewed from the outside.
| 220 |
The grid dimensions for each axis may also be given by three additional
| 221 |
integer arguments following the prism axes.
| 222 |
Otherwise, if the grid dimensions are left out or any are unspecified
| 223 |
or zero, the "GRID" variable will be used to determine them from the
| 224 |
section axis lengths.
| 225 |
(See below.)\0
| 226 |
There is no default value for this variable, and it is required.
| 227 |
If multiple values are given, they will be used for multiple rendering
| 228 |
sections, which may or may not be connected, but should generally not
| 229 |
overlap.
| 230 |
The starting view for interactive display will be the center
| 231 |
of the first section facing the positive X direction unless
| 232 |
"OBSTRUCTIONS" is set to True, when the view will be placed
| 233 |
outside the first section.
| 234 |
(See below for this variable's definition.)\0
| 235 |
The third axis of the first section is also
| 236 |
used as the default "view up" vector.
| 237 |
.TP
| 238 |
.BR geometry
| 239 |
This variable is used to associate geometry from an
| 240 |
octree file with one or more sections.
| 241 |
The specified octree will be used by certain drivers (e.g., the "ogl" driver)
| 242 |
to display simplified geometry using hardware lighting during motion.
| 243 |
If this variable is not set, such drivers will use the main octree file,
| 244 |
which contains all the scene geometry.
| 245 |
This can be slow if the scene is complex, so use simplified geometry
| 246 |
with portals (described below) or specify a non-existent file to turn
| 247 |
geometry rendering off.
| 248 |
If there is just one setting of this variable, it will be used for all
| 249 |
sections.
| 250 |
If there are multiple settings, they will correspond to multiple sections.
| 251 |
.TP
| 252 |
.BR portals
| 253 |
This variable is used to associate portal geometry with one or more
| 254 |
sections, as required for simplified geometry in some drivers (e.g., "ogl").
| 255 |
The portal geometry itself is given in one or more RADIANCE scene files or
| 256 |
quoted commands beginning with an exclamation mark ('!'),
| 257 |
and the input may or may not include material definitons.
| 258 |
(I.e., the surfaces may be modified by "void" if there are no materials.)
| 259 |
A portal is an imaginary surface that intervenes between a view and
| 260 |
some detailed geometry not included in the current section.
| 261 |
(See the "geometry" variable definition, above.)
| 262 |
Portals are often placed in doorways, windows and in front of mirrors.
| 263 |
Portal geometry may also be placed around local geometry that has been
| 264 |
culled due to its complexity.
| 265 |
This specification is necessary in order that the detail geometry be
| 266 |
drawn correctly, and that mirrors will work with virtual distances.
| 267 |
(See the definition of "VDISTANCE," below.)
| 268 |
The orientation of the portal surface geometry is ignored, so they
| 269 |
have effect no matter which way they are facing.
| 270 |
| 271 |
sections.
| 272 |
| 273 |
.TP
| 274 |
.BR GRID
| 275 |
The default section grid size in world distance units.
| 276 |
If any section axis grid is unspecified, the length of the axis
| 277 |
will be divided by this number and rounded up to the next larger integer.
| 278 |
The grid size is a very important determiner of holodeck performance,
| 279 |
since the holodeck beam index is proportional to average axis grid dimension
| 280 |
to the fourth power!
| 281 |
If the beam index is too large, poor file and memory performance will
| 282 |
result.
| 283 |
If the beam index is too small, the holodeck resolution will suffer and
| 284 |
objects will tend to break up.
| 285 |
In general, the grid size should divide each section wall
| 286 |
into 64 or fewer cells for optimal performance.
| 287 |
The default value for this variable is the maximum section axis length
| 288 |
divided by 8.
| 289 |
.TP
| 290 |
.BR OBSTRUCTIONS
| 291 |
This boolean variable tells
| 292 |
.I rholo
| 293 |
whether or not to compute intersections with objects inside holodeck
| 294 |
sections.
| 295 |
If it is set to "False", then only objects outside the holodeck sections
| 296 |
will be visible.
| 297 |
This is appropriate when you know all sections to be devoid of geometry,
| 298 |
or when some secondary method is available for rendering geometry inside
| 299 |
each section.
| 300 |
If it is set to "True," all inside geometry will be visible.
| 301 |
There is no default for this variable, which means that rays will be
| 302 |
started at random points within each holodeck section, allowing interior
| 303 |
geometry to be partially sampled.
| 304 |
.TP
| 305 |
.BR VDISTANCE
| 306 |
This boolean variable determines whether the actual distance to objects
| 307 |
is computed, or the virtual distance.
| 308 |
If it is set to "True," the virtual distance will be used, which will
| 309 |
make reflections and refractions through smooth, flat objects clear,
| 310 |
but will blur the boundaries of those objects.
| 311 |
Note that some drivers cannot render virtual samples without the proper
| 312 |
placement of "portals" in the scene.
| 313 |
(See above for the definition of the "portals" variable.)
| 314 |
If it is set to "False," the reflections and refractions will be blurred,
| 315 |
but object boundaries will remain sharp.
| 316 |
The default value for this variable is "False."
| 317 |
.TP
| 318 |
.BR CACHE
| 319 |
The memory cache size to use for ray samples
| 320 |
during interactive rendering, in Megabytes.
| 321 |
This tuning parameter determines the tradeoff between memory use and
| 322 |
disk access time for interactive display.
| 323 |
This value will not affect memory use or performance for global
| 324 |
holodeck rendering if there is no display process.
| 325 |
The default cache is effectively set to 16 Megabytes.
| 326 |
If this variable is set to zero, no limit will be placed on memory
| 327 |
use and the process will grow to accommodate all the beams that
| 328 |
have been accessed.
| 329 |
.TP
| 330 |
.BR DISKSPACE
| 331 |
Specifies the maximum holodeck file size, in Megabytes.
| 332 |
Once the holodeck file reaches this size,
| 333 |
.I rtrace
| 334 |
will exit.
| 335 |
If there is no display process,
| 336 |
.I rholo
| 337 |
will also exit.
| 338 |
The default value for this variable is 0, which is interpreted as no
| 339 |
size limit.
| 340 |
.TP
| 341 |
.BR TIME
| 342 |
Sets the maximum time to run rtrace, in decimal hours.
| 343 |
After this length of time,
| 344 |
.I rtrace
| 345 |
will exit.
| 346 |
| 347 |
.I rholo
| 348 |
will also exit.
| 349 |
If there is a display process, and
| 350 |
.I rtrace
| 351 |
is restarted with the "restart" command, then the time clock will
| 352 |
be restarted as well.
| 353 |
| 354 |
time limit.
| 355 |
.TP
| 356 |
.BR REPORT
| 357 |
This variable may be used to specify a interval for
| 358 |
progress reports in minutes.
| 359 |
If this value is zero, then progress reports will not be given
| 360 |
in intervals, but a final report of the file size and fragmentation
| 361 |
will be issued when the program terminates, along with the number
| 362 |
of rays and packets computed.
| 363 |
If a filename is given after the interval, it will be used as the
| 364 |
error file for reports and error messages instead of the standard error.
| 365 |
| 366 |
.TP
| 367 |
.BR render
| 368 |
This variable may be used to specify additional options to
| 369 |
.I rtrace.
| 370 |
These options will appear after the options set automatically by
| 371 |
.I rad,
| 372 |
and thus will override the default values.
| 373 |
.SH "DISPLAY DRIVER"
| 374 |
.I Rholo
| 375 |
may be started in interactive mode using the
| 376 |
.I \-o
| 377 |
option to specify an output display driver.
| 378 |
Currently, three drivers are supported on most machines,
| 379 |
.I glx,
| 380 |
.I ogl
| 381 |
and
| 382 |
.I x11.
| 383 |
(In addition, there are variations on the first two drivers for
| 384 |
stereo displays, local objects and human tone mapping.
| 385 |
These are accessed with some combination of the 's', 'o' and 'h' suffixes,
| 386 |
always in that order.
| 387 |
E.g., the OpenGL stereo driver with human tone mapping would be "oglsh".)
| 388 |
Each driver accepts simple one-character commands and mouse
| 389 |
view control in its operating window.
| 390 |
If the
| 391 |
.I \-i
| 392 |
option is also given, then the driver will also listen for commands entered
| 393 |
on the standard input.
| 394 |
(It is unwise to use the
| 395 |
.I \-i
| 396 |
option when rholo is run in the background, because it will occassionally
| 397 |
stop the process when input is available on the controlling terminal.)\0
| 398 |
The commands and their single-key window equivalents are given below.
| 399 |
.TP 10n
| 400 |
.BR "VIEW= (mouse)"
| 401 |
Modify the current view with the specified parameters.
| 402 |
(See the
| 403 |
.I \-v*
| 404 |
view options in the
| 405 |
.I rpict(1)
| 406 |
manual page for parameter details.)\0
| 407 |
There is no one-character equivalent for this command in the display window.
| 408 |
Instead, the mouse is used to control the current view in the following ways:
| 409 |
.sp
| 410 |
.nf
| 411 |
CONTROL MOUSE ACTION
| 412 |
(none) left Move forward towards cursor position
| 413 |
(none) middle Rotate in place (usually safe)
| 414 |
(none) right Move backward away from cursor position
| 415 |
shift left Orbit left around cursor position
| 416 |
shift middle Orbit skyward
| 417 |
cntl middle Orbit earthward
| 418 |
shift right Orbit right around cursor position
| 419 |
cntl+shift any Frame focus by dragging rectangle
| 420 |
.fi
| 421 |
.sp
| 422 |
For all movements but rotating in place, the cursor must be placed over some
| 423 |
bit of visible geometry, otherwise the driver has no reference point from
| 424 |
which to work.
| 425 |
It is best to just experiment with these controls until you learn to fly
| 426 |
safely in your model.
| 427 |
And if you run into trouble, the "last" command is very useful.
| 428 |
(See below.)\0
| 429 |
.TP
| 430 |
.BR "last 'l'"
| 431 |
Return to the previous view.
| 432 |
Some drivers will save up multiple views in a history, but you are
| 433 |
guaranteed at least one.
| 434 |
.TP
| 435 |
.BR "where 'v'"
| 436 |
Print the current view parameters to the standard output.
| 437 |
This is useful for finding out where you are, or for saving specific
| 438 |
views in a keyframe file for animations or returning to later.
| 439 |
.TP
| 440 |
.BR "frame 'f'"
| 441 |
Change the calculation focus.
| 442 |
If the "frame" command is given with no arguments on the standard input,
| 443 |
it is equivalent to the interactive 'F' command, which releases
| 444 |
the current calculation focus.
| 445 |
If the "frame" command is followed by a relative horizontal and vertical
| 446 |
position (specified as floating point values between 0 and 1), then the
| 447 |
new focus is about this position on the screen (where 0 0 is at the lower
| 448 |
left of the display).
| 449 |
This is equivalent to the interactive 'f' command, which sets the focus
| 450 |
about the current window cursor position.
| 451 |
If four relative coordinates are given, they are assumed to mean the
| 452 |
minimum horizontal and vertical positon, and the maximum horizontal and
| 453 |
vertical position, in that order.
| 454 |
This is equivalent to dragging the mouse over a rectangular area
| 455 |
with the 'cntl+shift' keys held down.
| 456 |
.TP
| 457 |
.BR "pause 'p'"
| 458 |
Pause the ray calculation temporarily.
| 459 |
.TP
| 460 |
.BR "resume <cr>"
| 461 |
Resume the ray calculation.
| 462 |
.TP
| 463 |
.BR "redraw ^L"
| 464 |
Redraw the current view from values calculated and stored in the holodeck.
| 465 |
When executed from the display window via '^L', the effect may be slightly
| 466 |
different, since all stored information will be flushed.
| 467 |
.TP
| 468 |
.BR "kill 'K'"
| 469 |
Terminate the ray calculation process.
| 470 |
This is usually unnecessary, but is provided for special purpose applications.
| 471 |
.TP
| 472 |
.BR "restart 'R'"
| 473 |
Restart the ray calculation process.
| 474 |
If the "RIF" variable has been set,
| 475 |
.I rad
| 476 |
will be run first to assure that the octree is up to date.
| 477 |
.TP
| 478 |
.BR "clobber 'C'"
| 479 |
Clobber the holodeck contents, deleting all that has been calculated before.
| 480 |
To get an interactive dissolve of changes to the scene description,
| 481 |
use the sequence "kill," "clobber," "restart."
| 482 |
This command will be honored by
| 483 |
.I rholo
| 484 |
only if it was started with the
| 485 |
.I \-f
| 486 |
option.
| 487 |
.TP
| 488 |
.BR "quit 'q'"
| 489 |
Quit
| 490 |
.I rholo.
| 491 |
The ray tracing calculation is terminated and all values are flushed to
| 492 |
the holodeck file.
| 493 |
This is the normal way to exit the program.
| 494 |
.PP
| 495 |
In addition to these standard commands, all
| 496 |
drivers offer the following supplimentary controls.
| 497 |
.TP 10n
| 498 |
.BR "'h'"
| 499 |
Fix the head height.
| 500 |
All mouse-controlled view motions will be adjusted so that the head height
| 501 |
does not change (where vertical is determined by the current
| 502 |
view up vector).
| 503 |
.TP
| 504 |
.BR "'H'"
| 505 |
Release the head height, allowing it to change again during mouse-controlled
| 506 |
movements.
| 507 |
.TP
| 508 |
.BR "^R"
| 509 |
Redraw the current view, recomputing the tone mapping in the process.
| 510 |
This is useful if the current view is too light or too dark.
| 511 |
(On an 8-bit display, it may be necessary to redraw the
| 512 |
screen a couple of times to get the best image.)\0
| 513 |
The "^L" command is a stronger type of redraw, since it will use
| 514 |
only rays in the current view to determine the tone mapping, rather
| 515 |
than a history of rays drawn from the
| 516 |
.I rholo
| 517 |
server.
| 518 |
.SH EXAMPLES
| 519 |
The following shows a minimal holodeck control variable file:
| 520 |
.IP "" .3i
| 521 |
.nf
| 522 |
RIF= sample.rif # rad input file
| 523 |
section= 2 2 4 5 0 0 0 7 0 0 0 3 # section prism boundaries
| 524 |
.fi
| 525 |
.PP
| 526 |
Technically, the "RIF" setting is not necessary, but the results are
| 527 |
much better when
| 528 |
.I rholo
| 529 |
is used in association with
| 530 |
.I rad
| 531 |
to control the rendering parameters.
| 532 |
.PP
| 533 |
Here is a slightly more sophisticated example:
| 534 |
.IP "" .3i
| 535 |
.nf
| 536 |
RIF=electric.rif
| 537 |
section= 7 4 3.5 15 0 0 0 10 0 0 0 5
| 538 |
GRID= .75
| 539 |
CACHE= 20 # cache size in megabytes
| 540 |
TIME= 120 # maximum time in hours
| 541 |
DISK= 200 # maximum file size in megabytes
| 542 |
REPORT= 60 elect.her
| 543 |
OBST= False
| 544 |
VDIST= False
| 545 |
.fi
| 546 |
.PP
| 547 |
We can invoke
| 548 |
.I rholo
| 549 |
on the above file to compute a hologram overnight in batch mode:
| 550 |
.IP "" .2i
| 551 |
rholo \-n 1 elect.hdk elect.hif TIME=12 &
| 552 |
.PP
| 553 |
This will report progress every hour to "elect.her".
| 554 |
.PP
| 555 |
The next morning, we can look at the holodeck interactively:
| 556 |
.IP "" .2i
| 557 |
rholo\-n 1 \-o x11 elect.hdk &
| 558 |
.PP
| 559 |
If the previous command were still running, the above command would
| 560 |
fail because the permissions on the holodeck would not grant access.
| 561 |
To terminate
| 562 |
.I rholo
| 563 |
without losing any computed information, use the
| 564 |
.I kill(1)
| 565 |
command to send an interrupt or terminate signal to the
| 566 |
.I rholo
| 567 |
process listed by
| 568 |
.I ps(1).
| 569 |
If the system goes down or something dire happens to
| 570 |
.I rholo,
| 571 |
it may be necessary to restore read/write permission on the holodeck using
| 572 |
.I chmod(1).
| 573 |
Do not do this, however, unless you are absolutely sure that
| 574 |
.I rholo
| 575 |
is no longer running on the holodeck.
| 576 |
(See the
| 577 |
.I ps
| 578 |
man page on how to check for running processes.
| 579 |
The file modification date as reported by
| 580 |
.I ls(1)
| 581 |
is another clue.)\0
| 582 |
.PP
| 583 |
To view the holodeck without invoking a new ray calculation, leave off the
| 584 |
.I \-n
| 585 |
option.
| 586 |
To compute the holodeck with multiple processes on a multiprocessing system,
| 587 |
use a higher number for the
| 588 |
.I \-n
| 589 |
option.
| 590 |
(Don't use more processes than you have processors, though, because
| 591 |
you'll only slow things down.)\0
| 592 |
.PP
| 593 |
To allow interactive control of
| 594 |
.I rholo
| 595 |
from another process, the following invocation will override
| 596 |
the file size limit and permit the holodeck
| 597 |
to be clobbered by a command entered on the standard input:
| 598 |
.IP "" .2i
| 599 |
rholo \-n 1 \-o x11 \-i \-f elect.hdk + DISK=0
| 600 |
.PP
| 601 |
To create an empty holodeck from settings on the command line:
| 602 |
.IP "" .2i
| 603 |
rholo new.hdk - RIF=sample.rif "section=2 2 4 8 0 0 0 10 0 0 0 3"
| 604 |
.SH NOTES
| 605 |
Each time rays are added to a beam, that beam's position in the holodeck
| 606 |
file is released and a new position is found.
| 607 |
After substantial computation on a holodeck, especially over several runs,
| 608 |
the holodeck file may become fragmented, leaving holes that take up space
| 609 |
without contributing useful information.
| 610 |
The percentage fragmentation is reported when the REPORT variable is set
| 611 |
and some calculation has taken place.
| 612 |
When this percentage gets high on a large holodeck (above 15% or so),
| 613 |
it is a good idea to run the
| 614 |
.I rhoptimize(1)
| 615 |
program once batch rendering is complete to close the gaps and collect
| 616 |
beams into groups for quicker rendering access.
| 617 |
Rholo will print periodic warnings when the fragmentation exceeds 20%.
| 618 |
.SH AUTHOR
| 619 |
Greg Ward Larson
| 620 |
.SH ACKNOWLEDGMENT
| 621 |
This work was supported by Silicon Graphics, Inc.
| 622 |
.SH BUGS
| 623 |
Global participating media are not handled correctly, though local
| 624 |
participating media will usually work.
| 625 |
.SH "SEE ALSO"
| 626 |
chmod(1), ls(1), ps(1), rad(1), ranimate(1), rhcopy(1), rhinfo(1),
| 627 |
rhoptimize(1), rhpict(1), rpict(1), rtrace(1), rvu(1)
