--- ray/doc/man/man1/rhcopy.1 2007/09/04 17:36:41 1.3 +++ ray/doc/man/man1/rhcopy.1 2022/11/16 00:12:49 1.6 @@ -1,7 +1,7 @@ -.\" RCSid "$Id: rhcopy.1,v 1.3 2007/09/04 17:36:41 greg Exp $" +.\" RCSid "$Id: rhcopy.1,v 1.6 2022/11/16 00:12:49 greg Exp $" .TH RHCOPY 1 1/15/99 RADIANCE .SH NAME -rhcopy - copy ray information into a holodeck +rhcopy - copy ray information to/from a holodeck .SH SYNOPSIS .B rhcopy .B dest_holo @@ -21,21 +21,60 @@ or ][ .B \-d ] -.B "\-p src_pic src_zbf .." +.B "\-p src_hdr src_dpt .." +.br +or +.br +.B rhcopy +.B dest_holo +[ +.B \-f{a|f|d} +][ +.B \-u +][ +.B \-d +] +.B "\-i[odplLv] +.br +or +.br +.B rhcopy +.B src_holo +[ +.B \-f{a|f|d} +] +.B "\-o[odplLv] .SH DESCRIPTION .I Rhcopy -adds ray sample data to the existing holodeck -.I dest_holo. +typically adds ray sample data to an existing holodeck. In the first form, the ray samples are taken from one or more holodeck files given after the .I \-h option. In the second form, the ray samples are taken from one or more RADIANCE -picture files and their depth buffers, which must be paired on the -command line after the +picture files and their corresponding +depth buffers, which must be paired on the command line after the .I \-p option. +In the third form, ray samples are read from the standard input +based on parameters specified by the +.I \-i +option, which should match (for example) the corresponding +.I \-o +option of an +.I rtrace(1) +command. +Note that a header is not expected on input, and some parameters +are required for correct operation. +A +.I \-f +option may be used to specify raw rather than ASCII data. .PP +The final form reads rays from the given holodeck and writes +them to the standard output according to the +.I \-o +specification. +.PP The .I \-u option turns on duplicate ray checking. @@ -76,7 +115,7 @@ option. Whatever variables are set by .I rholo when the new holodeck is created -are the ones that will have effect when later rendering or viewing. +are the ones that will affect later rendering or viewing. Since the ray sample data may be taken from any source, .I rholo and @@ -90,9 +129,13 @@ rholo new.hdk new.hif .br rhcopy new.hdk \-h old.hdk .PP +A much less efficient way to copy the same data: +.IP "" .2i +rhcopy old.hdk -oodlv | rhcopy new.hdk -iodlv +.PP To add ray samples from two pictures to the new holodeck: .IP "" .2i -rhcopy new.hdk \-p view1.pic view1.zbf view2.pic view2.zbf +rhcopy new.hdk \-p view1.hdr view1.zbf view2.hdr view2.zbf .SH NOTES .I Rhcopy attempts to place the beams in the holodeck in a good @@ -104,8 +147,9 @@ program once all runs of .I rhcopy are through. .SH AUTHOR -Greg Ward Larson +Greg Ward .SH ACKNOWLEDGMENT This work was supported by Silicon Graphics, Inc. .SH "SEE ALSO" -getinfo(1), pfilt(1), psign(1), rhinfo(1), rholo(1), rhoptimize(1), rpict(1) +getinfo(1), pfilt(1), rcode_depth(1), rcontrib(1), +rhinfo(1), rholo(1), rhoptimize(1), rpict(1), rtrace(1),
