| 1 |
.\" RCSid "$Id: rhcopy.1,v 1.4 2008/11/10 19:08:17 greg Exp $"
| 2 |
.TH RHCOPY 1 1/15/99 RADIANCE
| 3 |
.SH NAME
| 4 |
rhcopy - copy ray information into a holodeck
| 5 |
.SH SYNOPSIS
| 6 |
.B rhcopy
| 7 |
.B dest_holo
| 8 |
| 9 |
.B \-u
| 10 |
| 11 |
.B \-d
| 12 |
| 13 |
.B "\-h src_holo .."
| 14 |
.br
| 15 |
or
| 16 |
.br
| 17 |
.B rhcopy
| 18 |
.B dest_holo
| 19 |
| 20 |
.B \-u
| 21 |
| 22 |
.B \-d
| 23 |
| 24 |
.B "\-p src_pic src_zbf .."
| 25 |
.SH DESCRIPTION
| 26 |
.I Rhcopy
| 27 |
adds ray sample data to the existing holodeck
| 28 |
.I dest_holo.
| 29 |
In the first form, the ray samples are taken from one or more holodeck files
| 30 |
given after the
| 31 |
.I \-h
| 32 |
option.
| 33 |
In the second form, the ray samples are taken from one or more RADIANCE
| 34 |
picture files and their depth buffers, which must be paired on the
| 35 |
command line after the
| 36 |
.I \-p
| 37 |
option.
| 38 |
.PP
| 39 |
The
| 40 |
.I \-u
| 41 |
option turns on duplicate ray checking.
| 42 |
In some cases, the same ray may already exist in the destination holodeck,
| 43 |
and it would be redundant to add it.
| 44 |
By default,
| 45 |
.I rhcopy
| 46 |
does not check for duplicates, because it takes extra time, and in many
| 47 |
invocations is not necessary, as when copying into an empty holodeck.
| 48 |
.PP
| 49 |
The
| 50 |
.I \-d
| 51 |
option turns off depth checking.
| 52 |
Normally,
| 53 |
.I rhcopy
| 54 |
checks the OBSTRUCTIONS variable of the destination holodeck, and if it is
| 55 |
set to True, makes sure that all contributing rays start outside each
| 56 |
section.
| 57 |
If OBSTRUCTIONS is set to False, then
| 58 |
.I rhcopy
| 59 |
makes sure that any contributing rays end outside each section.
| 60 |
If OBSTRUCTIONS is not set, then this option has no effect.
| 61 |
(See the
| 62 |
.I rholo(1)
| 63 |
man page for a definition of the OBSTRUCTIONS variable.)\0
| 64 |
.PP
| 65 |
.I Rcopy
| 66 |
cannot be used to create a holodeck -- use
| 67 |
.I rholo
| 68 |
for this purpose.
| 69 |
For example, to create an empty holodeck, run
| 70 |
.I rholo
| 71 |
without either the
| 72 |
.I \-n
| 73 |
or
| 74 |
.I \-o
| 75 |
option.
| 76 |
Whatever variables are set by
| 77 |
.I rholo
| 78 |
when the new holodeck is created
| 79 |
are the ones that will affect later rendering or viewing.
| 80 |
Since the ray sample data may be taken from any source,
| 81 |
.I rholo
| 82 |
and
| 83 |
.I rhcopy
| 84 |
may be used together to change certain unalterable holodeck parameters,
| 85 |
such as the section grid geometry.
| 86 |
.SH EXAMPLE
| 87 |
To take data from an existing holodeck after changing the section grid:
| 88 |
.IP "" .2i
| 89 |
rholo new.hdk new.hif
| 90 |
.br
| 91 |
rhcopy new.hdk \-h old.hdk
| 92 |
.PP
| 93 |
To add ray samples from two pictures to the new holodeck:
| 94 |
.IP "" .2i
| 95 |
rhcopy new.hdk \-p view1.hdr view1.zbf view2.hdr view2.zbf
| 96 |
.SH NOTES
| 97 |
.I Rhcopy
| 98 |
attempts to place the beams in the holodeck in a good
| 99 |
order for quick access, but if the data comes from multiple sources,
| 100 |
the results may not be optimal.
| 101 |
For large holodecks, it is sometimes useful to run the
| 102 |
.I rhoptimize(1)
| 103 |
program once all runs of
| 104 |
.I rhcopy
| 105 |
are through.
| 106 |
.SH AUTHOR
| 107 |
Greg Ward Larson
| 108 |
.SH ACKNOWLEDGMENT
| 109 |
This work was supported by Silicon Graphics, Inc.
| 110 |
.SH "SEE ALSO"
| 111 |
getinfo(1), pfilt(1), rhinfo(1), rholo(1), rhoptimize(1), rpict(1)
