root/radiance/ray/doc/man/man1/rhcopy.1
Revision: 1.3
Committed: Tue Sep 4 17:36:41 2007 UTC (16 years, 9 months ago) by greg
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
1 .\" RCSid "$Id: rhcopy.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 .TH RHCOPY 1 1/15/99 RADIANCE
3 .SH NAME
4 rhcopy - copy ray information into a holodeck
5 .SH SYNOPSIS
6 .B rhcopy
7 .B dest_holo
8 [
9 .B \-u
10 ][
11 .B \-d
12 ]
13 .B "\-h src_holo .."
14 .br
15 or
16 .br
17 .B rhcopy
18 .B dest_holo
19 [
20 .B \-u
21 ][
22 .B \-d
23 ]
24 .B "\-p src_pic src_zbf .."
25 .SH DESCRIPTION
26 .I Rhcopy
27 adds ray sample data to the existing holodeck
28 .I dest_holo.
29 In the first form, the ray samples are taken from one or more holodeck files
30 given after the
31 .I \-h
32 option.
33 In the second form, the ray samples are taken from one or more RADIANCE
34 picture files and their depth buffers, which must be paired on the
35 command line after the
36 .I \-p
37 option.
38 .PP
39 The
40 .I \-u
41 option turns on duplicate ray checking.
42 In some cases, the same ray may already exist in the destination holodeck,
43 and it would be redundant to add it.
44 By default,
45 .I rhcopy
46 does not check for duplicates, because it takes extra time, and in many
47 invocations is not necessary, as when copying into an empty holodeck.
48 .PP
49 The
50 .I \-d
51 option turns off depth checking.
52 Normally,
53 .I rhcopy
54 checks the OBSTRUCTIONS variable of the destination holodeck, and if it is
55 set to True, makes sure that all contributing rays start outside each
56 section.
57 If OBSTRUCTIONS is set to False, then
58 .I rhcopy
59 makes sure that any contributing rays end outside each section.
60 If OBSTRUCTIONS is not set, then this option has no effect.
61 (See the
62 .I rholo(1)
63 man page for a definition of the OBSTRUCTIONS variable.)\0
64 .PP
65 .I Rcopy
66 cannot be used to create a holodeck -- use
67 .I rholo
68 for this purpose.
69 For example, to create an empty holodeck, run
70 .I rholo
71 without either the
72 .I \-n
73 or
74 .I \-o
75 option.
76 Whatever variables are set by
77 .I rholo
78 when the new holodeck is created
79 are the ones that will have effect when later rendering or viewing.
80 Since the ray sample data may be taken from any source,
81 .I rholo
82 and
83 .I rhcopy
84 may be used together to change certain unalterable holodeck parameters,
85 such as the section grid geometry.
86 .SH EXAMPLE
87 To take data from an existing holodeck after changing the section grid:
88 .IP "" .2i
89 rholo new.hdk new.hif
90 .br
91 rhcopy new.hdk \-h old.hdk
92 .PP
93 To add ray samples from two pictures to the new holodeck:
94 .IP "" .2i
95 rhcopy new.hdk \-p view1.pic view1.zbf view2.pic view2.zbf
96 .SH NOTES
97 .I Rhcopy
98 attempts to place the beams in the holodeck in a good
99 order for quick access, but if the data comes from multiple sources,
100 the results may not be optimal.
101 For large holodecks, it is sometimes useful to run the
102 .I rhoptimize(1)
103 program once all runs of
104 .I rhcopy
105 are through.
106 .SH AUTHOR
107 Greg Ward Larson
108 .SH ACKNOWLEDGMENT
109 This work was supported by Silicon Graphics, Inc.
110 .SH "SEE ALSO"
111 getinfo(1), pfilt(1), psign(1), rhinfo(1), rholo(1), rhoptimize(1), rpict(1)
