root/radiance/ray/doc/man/man1/rhcopy.1
Revision: 1.6
Committed: Wed Nov 16 00:12:49 2022 UTC (2 years, 8 months ago) by greg
CVS Tags: rad5R4, rad6R0, HEAD
Changes since 1.5: +53 -9 lines
feat(rhcopy): Added -i* and -o* options for reading and writing rays
1 .\" RCSid "$Id: rhcopy.1,v 1.5 2019/02/12 23:36:33 greg Exp $"
2 .TH RHCOPY 1 1/15/99 RADIANCE
3 .SH NAME
4 rhcopy - copy ray information to/from a holodeck
5 .SH SYNOPSIS
6 .B rhcopy
7 .B dest_holo
8 [
9 .B \-u
10 ][
11 .B \-d
12 ]
13 .B "\-h src_holo .."
14 .br
15 or
16 .br
17 .B rhcopy
18 .B dest_holo
19 [
20 .B \-u
21 ][
22 .B \-d
23 ]
24 .B "\-p src_hdr src_dpt .."
25 .br
26 or
27 .br
28 .B rhcopy
29 .B dest_holo
30 [
31 .B \-f{a|f|d}
32 ][
33 .B \-u
34 ][
35 .B \-d
36 ]
37 .B "\-i[odplLv]
38 .br
39 or
40 .br
41 .B rhcopy
42 .B src_holo
43 [
44 .B \-f{a|f|d}
45 ]
46 .B "\-o[odplLv]
47 .SH DESCRIPTION
48 .I Rhcopy
49 typically adds ray sample data to an existing holodeck.
50 In the first form, the ray samples are taken from one or more holodeck files
51 given after the
52 .I \-h
53 option.
54 In the second form, the ray samples are taken from one or more RADIANCE
55 picture files and their corresponding
56 depth buffers, which must be paired on the command line after the
57 .I \-p
58 option.
59 In the third form, ray samples are read from the standard input
60 based on parameters specified by the
61 .I \-i
62 option, which should match (for example) the corresponding
63 .I \-o
64 option of an
65 .I rtrace(1)
66 command.
67 Note that a header is not expected on input, and some parameters
68 are required for correct operation.
69 A
70 .I \-f
71 option may be used to specify raw rather than ASCII data.
72 .PP
73 The final form reads rays from the given holodeck and writes
74 them to the standard output according to the
75 .I \-o
76 specification.
77 .PP
78 The
79 .I \-u
80 option turns on duplicate ray checking.
81 In some cases, the same ray may already exist in the destination holodeck,
82 and it would be redundant to add it.
83 By default,
84 .I rhcopy
85 does not check for duplicates, because it takes extra time, and in many
86 invocations is not necessary, as when copying into an empty holodeck.
87 .PP
88 The
89 .I \-d
90 option turns off depth checking.
91 Normally,
92 .I rhcopy
93 checks the OBSTRUCTIONS variable of the destination holodeck, and if it is
94 set to True, makes sure that all contributing rays start outside each
95 section.
96 If OBSTRUCTIONS is set to False, then
97 .I rhcopy
98 makes sure that any contributing rays end outside each section.
99 If OBSTRUCTIONS is not set, then this option has no effect.
100 (See the
101 .I rholo(1)
102 man page for a definition of the OBSTRUCTIONS variable.)\0
103 .PP
104 .I Rcopy
105 cannot be used to create a holodeck -- use
106 .I rholo
107 for this purpose.
108 For example, to create an empty holodeck, run
109 .I rholo
110 without either the
111 .I \-n
112 or
113 .I \-o
114 option.
115 Whatever variables are set by
116 .I rholo
117 when the new holodeck is created
118 are the ones that will affect later rendering or viewing.
119 Since the ray sample data may be taken from any source,
120 .I rholo
121 and
122 .I rhcopy
123 may be used together to change certain unalterable holodeck parameters,
124 such as the section grid geometry.
125 .SH EXAMPLE
126 To take data from an existing holodeck after changing the section grid:
127 .IP "" .2i
128 rholo new.hdk new.hif
129 .br
130 rhcopy new.hdk \-h old.hdk
131 .PP
132 A much less efficient way to copy the same data:
133 .IP "" .2i
134 rhcopy old.hdk -oodlv | rhcopy new.hdk -iodlv
135 .PP
136 To add ray samples from two pictures to the new holodeck:
137 .IP "" .2i
138 rhcopy new.hdk \-p view1.hdr view1.zbf view2.hdr view2.zbf
139 .SH NOTES
140 .I Rhcopy
141 attempts to place the beams in the holodeck in a good
142 order for quick access, but if the data comes from multiple sources,
143 the results may not be optimal.
144 For large holodecks, it is sometimes useful to run the
145 .I rhoptimize(1)
146 program once all runs of
147 .I rhcopy
148 are through.
149 .SH AUTHOR
150 Greg Ward
151 .SH ACKNOWLEDGMENT
152 This work was supported by Silicon Graphics, Inc.
153 .SH "SEE ALSO"
154 getinfo(1), pfilt(1), rcode_depth(1), rcontrib(1),
155 rhinfo(1), rholo(1), rhoptimize(1), rpict(1), rtrace(1),
