root/radiance/ray/doc/man/man1/rhcopy.1
Revision: 1.6
Committed: Wed Nov 16 00:12:49 2022 UTC (2 years, 8 months ago) by greg
CVS Tags: rad5R4, rad6R0, HEAD
Changes since 1.5: +53 -9 lines
feat(rhcopy): Added -i* and -o* options for reading and writing rays
# User Rev Content
1 greg 1.6 .\" RCSid "$Id: rhcopy.1,v 1.5 2019/02/12 23:36:33 greg Exp $"
2 greg 1.1 .TH RHCOPY 1 1/15/99 RADIANCE
3     .SH NAME
4 greg 1.6 rhcopy - copy ray information to/from a holodeck
5 greg 1.1 .SH SYNOPSIS
6     .B rhcopy
7     .B dest_holo
8     [
9     .B \-u
10     ][
11     .B \-d
12     ]
13     .B "\-h src_holo .."
14     .br
15     or
16     .br
17     .B rhcopy
18     .B dest_holo
19     [
20     .B \-u
21     ][
22     .B \-d
23     ]
24 greg 1.6 .B "\-p src_hdr src_dpt .."
25     .br
26     or
27     .br
28     .B rhcopy
29     .B dest_holo
30     [
31     .B \-f{a|f|d}
32     ][
33     .B \-u
34     ][
35     .B \-d
36     ]
37     .B "\-i[odplLv]
38     .br
39     or
40     .br
41     .B rhcopy
42     .B src_holo
43     [
44     .B \-f{a|f|d}
45     ]
46     .B "\-o[odplLv]
47 greg 1.1 .SH DESCRIPTION
48     .I Rhcopy
49 greg 1.6 typically adds ray sample data to an existing holodeck.
50 greg 1.1 In the first form, the ray samples are taken from one or more holodeck files
51     given after the
52     .I \-h
53     option.
54     In the second form, the ray samples are taken from one or more RADIANCE
55 greg 1.6 picture files and their corresponding
56     depth buffers, which must be paired on the command line after the
57 greg 1.1 .I \-p
58     option.
59 greg 1.6 In the third form, ray samples are read from the standard input
60     based on parameters specified by the
61     .I \-i
62     option, which should match (for example) the corresponding
63     .I \-o
64     option of an
65     .I rtrace(1)
66     command.
67     Note that a header is not expected on input, and some parameters
68     are required for correct operation.
69     A
70     .I \-f
71     option may be used to specify raw rather than ASCII data.
72     .PP
73     The final form reads rays from the given holodeck and writes
74     them to the standard output according to the
75     .I \-o
76     specification.
77 greg 1.1 .PP
78     The
79     .I \-u
80     option turns on duplicate ray checking.
81     In some cases, the same ray may already exist in the destination holodeck,
82     and it would be redundant to add it.
83     By default,
84     .I rhcopy
85     does not check for duplicates, because it takes extra time, and in many
86     invocations is not necessary, as when copying into an empty holodeck.
87     .PP
88     The
89     .I \-d
90     option turns off depth checking.
91     Normally,
92     .I rhcopy
93     checks the OBSTRUCTIONS variable of the destination holodeck, and if it is
94     set to True, makes sure that all contributing rays start outside each
95     section.
96     If OBSTRUCTIONS is set to False, then
97     .I rhcopy
98     makes sure that any contributing rays end outside each section.
99     If OBSTRUCTIONS is not set, then this option has no effect.
100     (See the
101     .I rholo(1)
102     man page for a definition of the OBSTRUCTIONS variable.)\0
103     .PP
104     .I Rcopy
105     cannot be used to create a holodeck -- use
106     .I rholo
107     for this purpose.
108     For example, to create an empty holodeck, run
109     .I rholo
110     without either the
111     .I \-n
112     or
113     .I \-o
114     option.
115     Whatever variables are set by
116     .I rholo
117     when the new holodeck is created
118 greg 1.5 are the ones that will affect later rendering or viewing.
119 greg 1.1 Since the ray sample data may be taken from any source,
120     .I rholo
121     and
122     .I rhcopy
123     may be used together to change certain unalterable holodeck parameters,
124     such as the section grid geometry.
125     .SH EXAMPLE
126     To take data from an existing holodeck after changing the section grid:
127     .IP "" .2i
128     rholo new.hdk new.hif
129     .br
130 greg 1.3 rhcopy new.hdk \-h old.hdk
131 greg 1.1 .PP
132 greg 1.6 A much less efficient way to copy the same data:
133     .IP "" .2i
134     rhcopy old.hdk -oodlv | rhcopy new.hdk -iodlv
135     .PP
136 greg 1.1 To add ray samples from two pictures to the new holodeck:
137     .IP "" .2i
138 greg 1.4 rhcopy new.hdk \-p view1.hdr view1.zbf view2.hdr view2.zbf
139 greg 1.1 .SH NOTES
140     .I Rhcopy
141     attempts to place the beams in the holodeck in a good
142     order for quick access, but if the data comes from multiple sources,
143     the results may not be optimal.
144     For large holodecks, it is sometimes useful to run the
145     .I rhoptimize(1)
146     program once all runs of
147     .I rhcopy
148     are through.
149     .SH AUTHOR
150 greg 1.6 Greg Ward
151 greg 1.1 .SH ACKNOWLEDGMENT
152     This work was supported by Silicon Graphics, Inc.
153     .SH "SEE ALSO"
154 greg 1.6 getinfo(1), pfilt(1), rcode_depth(1), rcontrib(1),
155     rhinfo(1), rholo(1), rhoptimize(1), rpict(1), rtrace(1),
