root/Development/ray/doc/man/man1/rfluxmtx.1
Revision: 1.17
Committed: Fri Nov 14 23:51:42 2025 UTC (6 weeks, 4 days ago) by greg
Changes since 1.16: +9 -1 lines
feat(rfluxmtx,rxfluxmtx): Added bin sample jittering for smoother visual results
# User Rev Content
1 greg 1.17 .\" RCSid "$Id: rfluxmtx.1,v 1.16 2025/10/23 23:34:59 greg Exp $"
2 greg 1.1 .TH RFLUXMTX 1 07/22/14 RADIANCE
3     .SH NAME
4     rfluxmtx - compute flux transfer matrix(es) for RADIANCE scene
5     .SH SYNOPSIS
6     .B rfluxmtx
7     [
8     .B \-v
9     ][
10 greg 1.17 .B "-bj frac"
11     ][
12 greg 1.1 .B "rcontrib options"
13     ]
14     .B "{ sender.rad | - }"
15     .B receivers.rad
16 greg 1.4 .B "[ -i system.oct ]"
17     .B "[ system.rad .. ]"
18 greg 1.1 .SH DESCRIPTION
19     .I Rfluxmtx
20     samples rays uniformly over the surface given in
21     .I sender.rad
22     and records rays arriving at surfaces in the file
23     .I receivers.rad,
24     producing a flux transfer matrix per receiver.
25 greg 1.4 A system octree to which the receivers will be appended may be given with a
26     .I \-i
27     option following the receiver file.
28     Additional system surfaces may be given in one or more
29     .I system.rad
30     files, which are compiled before the receiver file into an octree sent to the
31 greg 1.1 .I rcontrib(1)
32     program to do the actual work.
33     If a single hyphen ('-') is given in place of the sender file, then
34     .I rfluxmtx
35     passes ray samples from its standard input directly to
36     .I rcontrib
37     without interpretation.
38     By default, all resulting matrix data are interleaved and sent to the standard output
39     in ASCII format, but this behavior is typically overridden using inline options
40     as described below.
41     .PP
42     The
43     .I \-v
44     option turns on verbose reporting for the number of samples and the executed
45     .I rcontrib
46     command.
47 greg 1.17 The
48     .I \-bj
49     option sets the amount of bin jittering, which blurs the boundaries of
50     receiver bins and is generally recommended when creating a view that may
51     include direct visibility of the receiver surface(s).
52     (The default jitter is 0, leaving sharp bin boundaries.)\0
53 greg 1.1 All other supported options are passed on to
54     .I rcontrib(1).
55     However, the
56 greg 1.16 .I \-fo,
57 greg 1.1 .I \-p,
58     .I \-b,
59     .I \-bn,
60     .I \-m,
61     and
62     .I \-M
63     options are controlled by
64     .I rfluxmtx
65     and may not be set by the user.
66 greg 1.16 (Recovery mode is not supported, and existing output is always overwritten.)\0
67     Further, the
68 greg 1.1 .I \-x,
69     .I \-y,
70     and
71     .I \-ld
72     options are ignored unless
73     .I rfluxmtx
74     is invoked in the pass-through mode,
75     in which case they may be needed to generate RADIANCE views from
76     .I vwrays(1).
77     The sample count, unless set by the
78     .I \-c
79 greg 1.2 option, defaults to 10000 when a sender file is given, or to 1 for pass-through mode.
80 greg 1.1 .SH VARIABLES
81     The sender and receiver scene files given to
82     .I rfluxmtx
83 greg 1.3 contain controlling parameters in special comments of the form:
84 greg 1.1 .nf
85
86     #@rfluxmtx variable=value ..
87
88     .fi
89     At minimum, both sender and receiver must specify one of the
90     hemisphere sampling types, and there must be at least
91     one surface in each file.
92     .TP 10n
93     .BI h =u
94     Set hemisphere sampling to "uniform," meaning a single bin
95     of (cosine-distributed) samples.
96 greg 1.3 In the case of distant "source" primitives, this is the only
97 greg 1.1 sampling method that supports arbitrary receiver sizes.
98     The other methods below require a full hemispherical source.
99     .TP
100     .BI h =kf
101     Divide the hemisphere using the LBNL/Klems "full" sampling basis.
102 greg 1.8 (Use "h=-kf" for left-handed coordinates.)
103 greg 1.1 .TP
104     .BI h =kh
105     Divide the hemisphere using the LBNL/Klems "half" sampling basis.
106 greg 1.8 (Use "h=-kh" for left-handed coordinates.)
107 greg 1.1 .TP
108     .BI h =kq
109     Divide the hemisphere using the LBNL/Klems "quarter" sampling basis.
110 greg 1.8 (Use "h=-kq" for left-handed coordinates.)
111 greg 1.1 .TP
112     .BI h =rN
113     Divide the hemisphere using Reinhart's substructuring of the Tregenza
114     sky pattern with
115     .I N
116     divisions in each dimension.
117     If it is not given,
118     .I N
119     defaults to 1, which is just the Tregenza sky.
120 greg 1.8 (Use "h=-rN" for left-handed coordinates.)
121 greg 1.1 .TP
122 greg 1.14 .BI h =cie
123     Divide the hemisphere into CIE sky scanner directions, which is
124     similar to Tregenza but with different starting azimuths and
125     reversing row direction at each new altitude.
126     (Use "h=-cie" for left-handed coordinates.)
127     .TP
128 greg 1.1 .BI h =scN
129     Subdivide the hemisphere using the Shirley-Chiu square-to-disk mapping with an
130     .I NxN
131     grid over the square.
132 greg 1.8 (Use "h=-scN" for left-handed coordinates.)
133 greg 1.1 .TP
134     .BI u =[-]{X|Y|Z|ux,uy,uz}
135     Orient the "up" direction for the hemisphere using the indicated axis or direction
136     vector.
137     .TP
138 greg 1.10 .BI o =output_spec
139     Send the matrix data for this receiver to the indicated file or command.
140     Single or double quotes may be used to contain strings with spaces, and
141     commands must begin with an exclamation mark ('!').
142 greg 1.1 The file format will be determined by the command-line
143     .I \-fio
144     option and will include an information header unless the
145     .I \-h
146     option was used to turn headers off.
147 greg 1.16 (The input format specification is ignored for senders.)\0
148 greg 1.1 .PP
149     In normal execution, only a single sender surface is sampled, but it may be
150     comprised of any number of subsurfaces, as in a triangle mesh or similar.
151     The surface normal will be computed as the average of all the constituent
152     subsurfaces.
153 greg 1.2 The subsurfaces themselves must be planar, thus only
154 greg 1.1 .I polygon
155     and
156     .I ring
157     surface primitives are supported.
158     Other primitives will be silently ignored and will have no effect on the calculation.
159     .PP
160     In the receiver file, the
161     .I source
162     primitive is supported as well, and multiple receivers (and multiple output
163 greg 1.7 matrices) may be identified by different modifier names.
164 greg 1.9 (Make sure that surfaces using the same modifier are grouped together,
165     and that the modifiers are unique and not used elsewhere in the
166     scene description.)\0
167 greg 1.1 Though it may be counter-intuitive, receivers are often light sources,
168     since samples end up there in a backwards ray-tracing system such as RADIANCE.
169 greg 1.2 When using local geometry, the overall aperture shape should be close to flat.
170     Large displacements may give rise to errors due to a convex receiver's
171     larger profile at low angles of incidence.
172 greg 1.1 .PP
173 greg 1.3 Rays always emanate from the back side of the sender surface and arrive at the
174 greg 1.1 front side of receiver surfaces.
175     In this way, a receiver surface may be reused as a sender in a subsequent
176     .I rfluxmtx
177     calculation and the resulting matrices will concatenate properly.
178     (Note that it is important to keep receiver surfaces together, otherwise a
179     "duplicate modifier" error will result.)\0
180     .SH EXAMPLES
181     To generate a flux transfer matrix connecting input and output apertures
182     on a light pipe:
183 greg 1.16 .IP "" .2i
184 greg 1.5 rfluxmtx int_aperture.rad ext_aperture.rad lpipe.rad > lpipe.mtx
185 greg 1.1 .SH AUTHOR
186     Greg Ward
187     .SH "SEE ALSO"
188 greg 1.15 genBSDF(1), getinfo(1), pvsum(1), rcalc(1), rcollate(1), rcomb(1), rcontrib(1),
189 greg 1.16 rcrop(1), rmtxop(1), rxfluxmtx(1), vwrays(1), wrapBSDF(1)
