root/radiance/ray/doc/man/man1/rfluxmtx.1
Revision: 1.2
Committed: Mon Jul 28 18:35:40 2014 UTC (10 years, 10 months ago) by greg
Changes since 1.1: +6 -3 lines
Added remark about errors caused by convex receiver surfaces
1 .\" RCSid "$Id: rfluxmtx.1,v 1.1 2014/07/22 21:55:31 greg Exp $"
2 .TH RFLUXMTX 1 07/22/14 RADIANCE
3 .SH NAME
4 rfluxmtx - compute flux transfer matrix(es) for RADIANCE scene
5 .SH SYNOPSIS
6 .B rfluxmtx
7 [
8 .B \-v
9 ][
10 .B "rcontrib options"
11 ]
12 .B "{ sender.rad | - }"
13 .B receivers.rad
14 .B "[ scene.rad .. ]"
15 .SH DESCRIPTION
16 .I Rfluxmtx
17 samples rays uniformly over the surface given in
18 .I sender.rad
19 and records rays arriving at surfaces in the file
20 .I receivers.rad,
21 producing a flux transfer matrix per receiver.
22 Additional scene surfaces are given in optional
23 .I scene.rad
24 files, which are compiled with the receivers into an octree sent to the
25 .I rcontrib(1)
26 program to do the actual work.
27 If a single hyphen ('-') is given in place of the sender file, then
28 .I rfluxmtx
29 passes ray samples from its standard input directly to
30 .I rcontrib
31 without interpretation.
32 By default, all resulting matrix data are interleaved and sent to the standard output
33 in ASCII format, but this behavior is typically overridden using inline options
34 as described below.
35 .PP
36 The
37 .I \-v
38 option turns on verbose reporting for the number of samples and the executed
39 .I rcontrib
40 command.
41 All other supported options are passed on to
42 .I rcontrib(1).
43 However, the
44 .I \-f,
45 .I \-e,
46 .I \-p,
47 .I \-b,
48 .I \-bn,
49 .I \-m,
50 and
51 .I \-M
52 options are controlled by
53 .I rfluxmtx
54 and may not be set by the user.
55 Also, the
56 .I \-x,
57 .I \-y,
58 and
59 .I \-ld
60 options are ignored unless
61 .I rfluxmtx
62 is invoked in the pass-through mode,
63 in which case they may be needed to generate RADIANCE views from
64 .I vwrays(1).
65 The sample count, unless set by the
66 .I \-c
67 option, defaults to 10000 when a sender file is given, or to 1 for pass-through mode.
68 .SH VARIABLES
69 The sender and receiver scene files given to
70 .I rfluxmtx
71 contain controlling parameters in specal comments of the form:
72 .nf
73
74 #@rfluxmtx variable=value ..
75
76 .fi
77 At minimum, both sender and receiver must specify one of the
78 hemisphere sampling types, and there must be at least
79 one surface in each file.
80 .TP 10n
81 .BI h =u
82 Set hemisphere sampling to "uniform," meaning a single bin
83 of (cosine-distributed) samples.
84 In the case of distant "source" primatives, this is the only
85 sampling method that supports arbitrary receiver sizes.
86 The other methods below require a full hemispherical source.
87 .TP
88 .BI h =kf
89 Divide the hemisphere using the LBNL/Klems "full" sampling basis.
90 .TP
91 .BI h =kh
92 Divide the hemisphere using the LBNL/Klems "half" sampling basis.
93 .TP
94 .BI h =kq
95 Divide the hemisphere using the LBNL/Klems "quarter" sampling basis.
96 .TP
97 .BI h =rN
98 Divide the hemisphere using Reinhart's substructuring of the Tregenza
99 sky pattern with
100 .I N
101 divisions in each dimension.
102 If it is not given,
103 .I N
104 defaults to 1, which is just the Tregenza sky.
105 .TP
106 .BI h =scN
107 Subdivide the hemisphere using the Shirley-Chiu square-to-disk mapping with an
108 .I NxN
109 grid over the square.
110 .TP
111 .BI u =[-]{X|Y|Z|ux,uy,uz}
112 Orient the "up" direction for the hemisphere using the indicated axis or direction
113 vector.
114 .TP
115 .BI o =output.mtx
116 Send the matrix data for this receiver to the indicated output file.
117 The file format will be determined by the command-line
118 .I \-fio
119 option and will include an information header unless the
120 .I \-h
121 option was used to turn headers off.
122 (The output file specification is ignored for senders.)\0
123 .PP
124 In normal execution, only a single sender surface is sampled, but it may be
125 comprised of any number of subsurfaces, as in a triangle mesh or similar.
126 The surface normal will be computed as the average of all the constituent
127 subsurfaces.
128 The subsurfaces themselves must be planar, thus only
129 .I polygon
130 and
131 .I ring
132 surface primitives are supported.
133 Other primitives will be silently ignored and will have no effect on the calculation.
134 .PP
135 In the receiver file, the
136 .I source
137 primitive is supported as well, and multiple receivers (and multiple output
138 matrices) are identified by different modifier names.
139 Though it may be counter-intuitive, receivers are often light sources,
140 since samples end up there in a backwards ray-tracing system such as RADIANCE.
141 When using local geometry, the overall aperture shape should be close to flat.
142 Large displacements may give rise to errors due to a convex receiver's
143 larger profile at low angles of incidence.
144 .PP
145 Rays always eminate from the back side of the sender surface and arrive at the
146 front side of receiver surfaces.
147 In this way, a receiver surface may be reused as a sender in a subsequent
148 .I rfluxmtx
149 calculation and the resulting matrices will concatenate properly.
150 (Note that it is important to keep receiver surfaces together, otherwise a
151 "duplicate modifier" error will result.)\0
152 .SH EXAMPLES
153 To generate a flux transfer matrix connecting input and output apertures
154 on a light pipe:
155 .IP "" .3i
156 rcontrib int_aperture.rad ext_aperture.rad lpipe.rad > lpipe.mtx
157 .SH AUTHOR
158 Greg Ward
159 .SH "SEE ALSO"
160 genBSDF(1), getinfo(1), rcalc(1), rcollate(1), rcontrib(1), rmtxop(1), vwrays(1)
