root/radiance/ray/doc/man/man1/rfluxmtx.1
Revision: 1.8
Committed: Fri Mar 27 18:58:06 2015 UTC (10 years, 1 month ago) by greg
1 .\" RCSid "$Id: rfluxmtx.1,v 1.7 2015/03/12 18:24:11 greg Exp $"
2 .TH RFLUXMTX 1 07/22/14 RADIANCE
3 .SH NAME
4 rfluxmtx - compute flux transfer matrix(es) for RADIANCE scene
5 .SH SYNOPSIS
6 .B rfluxmtx
7 [
8 .B \-v
9 ][
10 .B "rcontrib options"
11 ]
12 .B "{ sender.rad | - }"
13 .B receivers.rad
14 .B "[ -i system.oct ]"
15 .B "[ system.rad .. ]"
16 .SH DESCRIPTION
17 .I Rfluxmtx
18 samples rays uniformly over the surface given in
19 .I sender.rad
20 and records rays arriving at surfaces in the file
21 .I receivers.rad,
22 producing a flux transfer matrix per receiver.
23 A system octree to which the receivers will be appended may be given with a
24 .I \-i
25 option following the receiver file.
26 Additional system surfaces may be given in one or more
27 .I system.rad
28 files, which are compiled before the receiver file into an octree sent to the
29 .I rcontrib(1)
30 program to do the actual work.
31 If a single hyphen ('-') is given in place of the sender file, then
32 .I rfluxmtx
33 passes ray samples from its standard input directly to
34 .I rcontrib
35 without interpretation.
36 By default, all resulting matrix data are interleaved and sent to the standard output
37 in ASCII format, but this behavior is typically overridden using inline options
38 as described below.
39 .PP
40 The
41 .I \-v
42 option turns on verbose reporting for the number of samples and the executed
43 .I rcontrib
44 command.
45 All other supported options are passed on to
46 .I rcontrib(1).
47 However, the
48 .I \-f,
49 .I \-e,
50 .I \-p,
51 .I \-b,
52 .I \-bn,
53 .I \-m,
54 and
55 .I \-M
56 options are controlled by
57 .I rfluxmtx
58 and may not be set by the user.
59 Also, the
60 .I \-x,
61 .I \-y,
62 and
63 .I \-ld
64 options are ignored unless
65 .I rfluxmtx
66 is invoked in the pass-through mode,
67 in which case they may be needed to generate RADIANCE views from
68 .I vwrays(1).
69 The sample count, unless set by the
70 .I \-c
71 option, defaults to 10000 when a sender file is given, or to 1 for pass-through mode.
72 .SH VARIABLES
73 The sender and receiver scene files given to
74 .I rfluxmtx
75 contain controlling parameters in special comments of the form:
76 .nf
77
78 #@rfluxmtx variable=value ..
79
80 .fi
81 At minimum, both sender and receiver must specify one of the
82 hemisphere sampling types, and there must be at least
83 one surface in each file.
84 .TP 10n
85 .BI h =u
86 Set hemisphere sampling to "uniform," meaning a single bin
87 of (cosine-distributed) samples.
88 In the case of distant "source" primitives, this is the only
89 sampling method that supports arbitrary receiver sizes.
90 The other methods below require a full hemispherical source.
91 .TP
92 .BI h =kf
93 Divide the hemisphere using the LBNL/Klems "full" sampling basis.
94 (Use "h=-kf" for left-handed coordinates.)
95 .TP
96 .BI h =kh
97 Divide the hemisphere using the LBNL/Klems "half" sampling basis.
98 (Use "h=-kh" for left-handed coordinates.)
99 .TP
100 .BI h =kq
101 Divide the hemisphere using the LBNL/Klems "quarter" sampling basis.
102 (Use "h=-kq" for left-handed coordinates.)
103 .TP
104 .BI h =rN
105 Divide the hemisphere using Reinhart's substructuring of the Tregenza
106 sky pattern with
107 .I N
108 divisions in each dimension.
109 If it is not given,
110 .I N
111 defaults to 1, which is just the Tregenza sky.
112 (Use "h=-rN" for left-handed coordinates.)
113 .TP
114 .BI h =scN
115 Subdivide the hemisphere using the Shirley-Chiu square-to-disk mapping with an
116 .I NxN
117 grid over the square.
118 (Use "h=-scN" for left-handed coordinates.)
119 .TP
120 .BI u =[-]{X|Y|Z|ux,uy,uz}
121 Orient the "up" direction for the hemisphere using the indicated axis or direction
122 vector.
123 .TP
124 .BI o =output.mtx
125 Send the matrix data for this receiver to the indicated output file.
126 The file format will be determined by the command-line
127 .I \-fio
128 option and will include an information header unless the
129 .I \-h
130 option was used to turn headers off.
131 (The output file specification is ignored for senders.)\0
132 .PP
133 In normal execution, only a single sender surface is sampled, but it may be
134 comprised of any number of subsurfaces, as in a triangle mesh or similar.
135 The surface normal will be computed as the average of all the constituent
136 subsurfaces.
137 The subsurfaces themselves must be planar, thus only
138 .I polygon
139 and
140 .I ring
141 surface primitives are supported.
142 Other primitives will be silently ignored and will have no effect on the calculation.
143 .PP
144 In the receiver file, the
145 .I source
146 primitive is supported as well, and multiple receivers (and multiple output
147 matrices) may be identified by different modifier names.
148 (Make sure that surfaces using the same modifier are grouped together.)\0
149 Though it may be counter-intuitive, receivers are often light sources,
150 since samples end up there in a backwards ray-tracing system such as RADIANCE.
151 When using local geometry, the overall aperture shape should be close to flat.
152 Large displacements may give rise to errors due to a convex receiver's
153 larger profile at low angles of incidence.
154 .PP
155 Rays always emanate from the back side of the sender surface and arrive at the
156 front side of receiver surfaces.
157 In this way, a receiver surface may be reused as a sender in a subsequent
158 .I rfluxmtx
159 calculation and the resulting matrices will concatenate properly.
160 (Note that it is important to keep receiver surfaces together, otherwise a
161 "duplicate modifier" error will result.)\0
162 .SH EXAMPLES
163 To generate a flux transfer matrix connecting input and output apertures
164 on a light pipe:
165 .IP "" .3i
166 rfluxmtx int_aperture.rad ext_aperture.rad lpipe.rad > lpipe.mtx
167 .SH AUTHOR
168 Greg Ward
169 .SH "SEE ALSO"
170 genBSDF(1), getinfo(1), rcalc(1), rcollate(1), rcontrib(1), rmtxop(1),
171 vwrays(1), wrapBSDF(1)
