root/radiance/ray/doc/man/man1/rfluxmtx.1
Revision 1.15 - (view) (download) (annotate) - [selected]
Thu Mar 27 01:26:55 2025 UTC (6 weeks, 4 days ago) by greg
Changes since 1.14: +2 -2 lines
Diff to previous 1.14
feat(pvsum): Added new pvsum tool for spectral data, similar to dctimestep
Thu Feb 8 02:26:01 2024 UTC (15 months ago) by greg
Changes since 1.13: +7 -1 lines
Diff to previous 1.13 , to selected 1.15
Tue Dec 12 16:31:45 2023 UTC (16 months, 4 weeks ago) by greg
Diff to previous 1.12 , to selected 1.15
Wed Dec 6 01:27:00 2023 UTC (17 months ago) by greg
Diff to previous 1.11 , to selected 1.15
docs(rmtxcomb): Added man page for new rmtxcomb tool
Tue Mar 15 00:25:50 2022 UTC (3 years, 1 month ago) by greg
Changes since 1.10: +3 -3 lines
Diff to previous 1.10 , to selected 1.15
feat(rcrop): Created simple cropping utility for matrices and pictures
Fri Dec 4 22:16:18 2015 UTC (9 years, 5 months ago) by greg
Changes since 1.9: +5 -3 lines
Diff to previous 1.9 , to selected 1.15
Added support for (quoted) output commands in rfluxmtx
Wed Sep 23 22:36:28 2015 UTC (9 years, 7 months ago) by greg
Changes since 1.8: +4 -2 lines
Diff to previous 1.8 , to selected 1.15
Added caveat about not re-using receiver modifier names
Fri Mar 27 18:58:06 2015 UTC (10 years, 1 month ago) by greg
Diff to previous 1.7 , to selected 1.15
Thu Mar 12 18:24:11 2015 UTC (10 years, 2 months ago) by greg
Diff to previous 1.6 , to selected 1.15
Added comment about grouping modifiers together in receiver files
Fri Feb 20 18:26:08 2015 UTC (10 years, 2 months ago) by greg
Diff to previous 1.5 , to selected 1.15
Fri Aug 29 08:33:34 2014 UTC (10 years, 8 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Diff to previous 1.4 , to selected 1.15
Fixed typos
Wed Aug 6 00:59:53 2014 UTC (10 years, 9 months ago) by greg
Changes since 1.3: +9 -5 lines
Diff to previous 1.3 , to selected 1.15
Mon Jul 28 21:03:22 2014 UTC (10 years, 9 months ago) by greg
CVS Tags: rad4R2
Changes since 1.2: +4 -4 lines
Diff to previous 1.2 , to selected 1.15
Word fixes (thanks, Rob)
Mon Jul 28 18:35:40 2014 UTC (10 years, 9 months ago) by greg
Changes since 1.1: +6 -3 lines
Diff to previous 1.1 , to selected 1.15
Added remark about errors caused by convex receiver surfaces
Tue Jul 22 21:55:31 2014 UTC (10 years, 9 months ago) by greg
Diff to selected 1.15
