root/Development/ray/doc/man/man1/rfluxmtx.1
Revision: 1.17
Committed: Fri Nov 14 23:51:42 2025 UTC (9 days, 4 hours ago) by greg
Changes since 1.16: +9 -1 lines
feat(rfluxmtx,rxfluxmtx): Added bin sample jittering for smoother visual results
1 .\" RCSid "$Id: rfluxmtx.1,v 1.16 2025/10/23 23:34:59 greg Exp $"
2 .TH RFLUXMTX 1 07/22/14 RADIANCE
3 .SH NAME
4 rfluxmtx - compute flux transfer matrix(es) for RADIANCE scene
5 .SH SYNOPSIS
6 .B rfluxmtx
7 [
8 .B \-v
9 ][
10 .B "-bj frac"
11 ][
12 .B "rcontrib options"
13 ]
14 .B "{ sender.rad | - }"
15 .B receivers.rad
16 .B "[ -i system.oct ]"
17 .B "[ system.rad .. ]"
18 .SH DESCRIPTION
19 .I Rfluxmtx
20 samples rays uniformly over the surface given in
21 .I sender.rad
22 and records rays arriving at surfaces in the file
23 .I receivers.rad,
24 producing a flux transfer matrix per receiver.
25 A system octree to which the receivers will be appended may be given with a
26 .I \-i
27 option following the receiver file.
28 Additional system surfaces may be given in one or more
29 .I system.rad
30 files, which are compiled before the receiver file into an octree sent to the
31 .I rcontrib(1)
32 program to do the actual work.
33 If a single hyphen ('-') is given in place of the sender file, then
34 .I rfluxmtx
35 passes ray samples from its standard input directly to
36 .I rcontrib
37 without interpretation.
38 By default, all resulting matrix data are interleaved and sent to the standard output
39 in ASCII format, but this behavior is typically overridden using inline options
40 as described below.
41 .PP
42 The
43 .I \-v
44 option turns on verbose reporting for the number of samples and the executed
45 .I rcontrib
46 command.
47 The
48 .I \-bj
49 option sets the amount of bin jittering, which blurs the boundaries of
50 receiver bins and is generally recommended when creating a view that may
51 include direct visibility of the receiver surface(s).
52 (The default jitter is 0, leaving sharp bin boundaries.)\0
53 All other supported options are passed on to
54 .I rcontrib(1).
55 However, the
56 .I \-fo,
57 .I \-p,
58 .I \-b,
59 .I \-bn,
60 .I \-m,
61 and
62 .I \-M
63 options are controlled by
64 .I rfluxmtx
65 and may not be set by the user.
66 (Recovery mode is not supported, and existing output is always overwritten.)\0
67 Further, the
68 .I \-x,
69 .I \-y,
70 and
71 .I \-ld
72 options are ignored unless
73 .I rfluxmtx
74 is invoked in the pass-through mode,
75 in which case they may be needed to generate RADIANCE views from
76 .I vwrays(1).
77 The sample count, unless set by the
78 .I \-c
79 option, defaults to 10000 when a sender file is given, or to 1 for pass-through mode.
80 .SH VARIABLES
81 The sender and receiver scene files given to
82 .I rfluxmtx
83 contain controlling parameters in special comments of the form:
84 .nf
85
86 #@rfluxmtx variable=value ..
87
88 .fi
89 At minimum, both sender and receiver must specify one of the
90 hemisphere sampling types, and there must be at least
91 one surface in each file.
92 .TP 10n
93 .BI h =u
94 Set hemisphere sampling to "uniform," meaning a single bin
95 of (cosine-distributed) samples.
96 In the case of distant "source" primitives, this is the only
97 sampling method that supports arbitrary receiver sizes.
98 The other methods below require a full hemispherical source.
99 .TP
100 .BI h =kf
101 Divide the hemisphere using the LBNL/Klems "full" sampling basis.
102 (Use "h=-kf" for left-handed coordinates.)
103 .TP
104 .BI h =kh
105 Divide the hemisphere using the LBNL/Klems "half" sampling basis.
106 (Use "h=-kh" for left-handed coordinates.)
107 .TP
108 .BI h =kq
109 Divide the hemisphere using the LBNL/Klems "quarter" sampling basis.
110 (Use "h=-kq" for left-handed coordinates.)
111 .TP
112 .BI h =rN
113 Divide the hemisphere using Reinhart's substructuring of the Tregenza
114 sky pattern with
115 .I N
116 divisions in each dimension.
117 If it is not given,
118 .I N
119 defaults to 1, which is just the Tregenza sky.
120 (Use "h=-rN" for left-handed coordinates.)
121 .TP
122 .BI h =cie
123 Divide the hemisphere into CIE sky scanner directions, which is
124 similar to Tregenza but with different starting azimuths and
125 reversing row direction at each new altitude.
126 (Use "h=-cie" for left-handed coordinates.)
127 .TP
128 .BI h =scN
129 Subdivide the hemisphere using the Shirley-Chiu square-to-disk mapping with an
130 .I NxN
131 grid over the square.
132 (Use "h=-scN" for left-handed coordinates.)
133 .TP
134 .BI u =[-]{X|Y|Z|ux,uy,uz}
135 Orient the "up" direction for the hemisphere using the indicated axis or direction
136 vector.
137 .TP
138 .BI o =output_spec
139 Send the matrix data for this receiver to the indicated file or command.
140 Single or double quotes may be used to contain strings with spaces, and
141 commands must begin with an exclamation mark ('!').
142 The file format will be determined by the command-line
143 .I \-fio
144 option and will include an information header unless the
145 .I \-h
146 option was used to turn headers off.
147 (The input format specification is ignored for senders.)\0
148 .PP
149 In normal execution, only a single sender surface is sampled, but it may be
150 comprised of any number of subsurfaces, as in a triangle mesh or similar.
151 The surface normal will be computed as the average of all the constituent
152 subsurfaces.
153 The subsurfaces themselves must be planar, thus only
154 .I polygon
155 and
156 .I ring
157 surface primitives are supported.
158 Other primitives will be silently ignored and will have no effect on the calculation.
159 .PP
160 In the receiver file, the
161 .I source
162 primitive is supported as well, and multiple receivers (and multiple output
163 matrices) may be identified by different modifier names.
164 (Make sure that surfaces using the same modifier are grouped together,
165 and that the modifiers are unique and not used elsewhere in the
166 scene description.)\0
167 Though it may be counter-intuitive, receivers are often light sources,
168 since samples end up there in a backwards ray-tracing system such as RADIANCE.
169 When using local geometry, the overall aperture shape should be close to flat.
170 Large displacements may give rise to errors due to a convex receiver's
171 larger profile at low angles of incidence.
172 .PP
173 Rays always emanate from the back side of the sender surface and arrive at the
174 front side of receiver surfaces.
175 In this way, a receiver surface may be reused as a sender in a subsequent
176 .I rfluxmtx
177 calculation and the resulting matrices will concatenate properly.
178 (Note that it is important to keep receiver surfaces together, otherwise a
179 "duplicate modifier" error will result.)\0
180 .SH EXAMPLES
181 To generate a flux transfer matrix connecting input and output apertures
182 on a light pipe:
183 .IP "" .2i
184 rfluxmtx int_aperture.rad ext_aperture.rad lpipe.rad > lpipe.mtx
185 .SH AUTHOR
186 Greg Ward
187 .SH "SEE ALSO"
188 genBSDF(1), getinfo(1), pvsum(1), rcalc(1), rcollate(1), rcomb(1), rcontrib(1),
189 rcrop(1), rmtxop(1), rxfluxmtx(1), vwrays(1), wrapBSDF(1)
