| 1 |
.\" RCSid "$Id: mkillum.1,v 1.12 2013/08/11 02:57:49 greg Exp $"
| 2 |
.TH RFLUXMTX 1 07/22/14 RADIANCE
| 3 |
.SH NAME
| 4 |
rfluxmtx - compute flux transfer matrix(es) for RADIANCE scene
| 5 |
.SH SYNOPSIS
| 6 |
.B rfluxmtx
| 7 |
| 8 |
.B \-v
| 9 |
| 10 |
.B "rcontrib options"
| 11 |
| 12 |
.B "{ sender.rad | - }"
| 13 |
.B receivers.rad
| 14 |
.B "[ scene.rad .. ]"
| 15 |
.SH DESCRIPTION
| 16 |
.I Rfluxmtx
| 17 |
samples rays uniformly over the surface given in
| 18 |
.I sender.rad
| 19 |
and records rays arriving at surfaces in the file
| 20 |
.I receivers.rad,
| 21 |
producing a flux transfer matrix per receiver.
| 22 |
Additional scene surfaces are given in optional
| 23 |
.I scene.rad
| 24 |
files, which are compiled with the receivers into an octree sent to the
| 25 |
.I rcontrib(1)
| 26 |
program to do the actual work.
| 27 |
If a single hyphen ('-') is given in place of the sender file, then
| 28 |
.I rfluxmtx
| 29 |
passes ray samples from its standard input directly to
| 30 |
.I rcontrib
| 31 |
without interpretation.
| 32 |
By default, all resulting matrix data are interleaved and sent to the standard output
| 33 |
in ASCII format, but this behavior is typically overridden using inline options
| 34 |
as described below.
| 35 |
.PP
| 36 |
The
| 37 |
.I \-v
| 38 |
option turns on verbose reporting for the number of samples and the executed
| 39 |
.I rcontrib
| 40 |
command.
| 41 |
All other supported options are passed on to
| 42 |
.I rcontrib(1).
| 43 |
However, the
| 44 |
.I \-f,
| 45 |
.I \-e,
| 46 |
.I \-p,
| 47 |
.I \-b,
| 48 |
.I \-bn,
| 49 |
.I \-m,
| 50 |
and
| 51 |
.I \-M
| 52 |
options are controlled by
| 53 |
.I rfluxmtx
| 54 |
and may not be set by the user.
| 55 |
Also, the
| 56 |
.I \-x,
| 57 |
.I \-y,
| 58 |
and
| 59 |
.I \-ld
| 60 |
options are ignored unless
| 61 |
.I rfluxmtx
| 62 |
is invoked in the pass-through mode,
| 63 |
in which case they may be needed to generate RADIANCE views from
| 64 |
.I vwrays(1).
| 65 |
The sample count, unless set by the
| 66 |
.I \-c
| 67 |
option, defaults to 10000 when a sender file is given, and 1 for pass-through mode.
| 68 |
.SH VARIABLES
| 69 |
The sender and receiver scene files given to
| 70 |
.I rfluxmtx
| 71 |
contain controlling parameters in specal comments of the form:
| 72 |
.nf
| 73 |
| 74 |
#@rfluxmtx variable=value ..
| 75 |
| 76 |
.fi
| 77 |
At minimum, both sender and receiver must specify one of the
| 78 |
hemisphere sampling types, and there must be at least
| 79 |
one surface in each file.
| 80 |
.TP 10n
| 81 |
.BI h =u
| 82 |
Set hemisphere sampling to "uniform," meaning a single bin
| 83 |
of (cosine-distributed) samples.
| 84 |
In the case of distant "source" primatives, this is the only
| 85 |
sampling method that supports arbitrary receiver sizes.
| 86 |
The other methods below require a full hemispherical source.
| 87 |
.TP
| 88 |
.BI h =kf
| 89 |
Divide the hemisphere using the LBNL/Klems "full" sampling basis.
| 90 |
.TP
| 91 |
.BI h =kh
| 92 |
Divide the hemisphere using the LBNL/Klems "half" sampling basis.
| 93 |
.TP
| 94 |
.BI h =kq
| 95 |
Divide the hemisphere using the LBNL/Klems "quarter" sampling basis.
| 96 |
.TP
| 97 |
.BI h =rN
| 98 |
Divide the hemisphere using Reinhart's substructuring of the Tregenza
| 99 |
sky pattern with
| 100 |
.I N
| 101 |
divisions in each dimension.
| 102 |
If it is not given,
| 103 |
.I N
| 104 |
defaults to 1, which is just the Tregenza sky.
| 105 |
.TP
| 106 |
.BI h =scN
| 107 |
Subdivide the hemisphere using the Shirley-Chiu square-to-disk mapping with an
| 108 |
.I NxN
| 109 |
grid over the square.
| 110 |
.TP
| 111 |
.BI u =[-]{X|Y|Z|ux,uy,uz}
| 112 |
Orient the "up" direction for the hemisphere using the indicated axis or direction
| 113 |
vector.
| 114 |
.TP
| 115 |
.BI o =output.mtx
| 116 |
Send the matrix data for this receiver to the indicated output file.
| 117 |
The file format will be determined by the command-line
| 118 |
.I \-fio
| 119 |
option and will include an information header unless the
| 120 |
.I \-h
| 121 |
option was used to turn headers off.
| 122 |
(The output file specification is ignored for senders.)\0
| 123 |
.PP
| 124 |
In normal execution, only a single sender surface is sampled, but it may be
| 125 |
comprised of any number of subsurfaces, as in a triangle mesh or similar.
| 126 |
The surface normal will be computed as the average of all the constituent
| 127 |
subsurfaces.
| 128 |
The subsurfaces themselves must be planer, thus only
| 129 |
.I polygon
| 130 |
and
| 131 |
.I ring
| 132 |
surface primitives are supported.
| 133 |
Other primitives will be silently ignored and will have no effect on the calculation.
| 134 |
.PP
| 135 |
In the receiver file, the
| 136 |
.I source
| 137 |
primitive is supported as well, and multiple receivers (and multiple output
| 138 |
matrices) are identified by different modifier names.
| 139 |
Though it may be counter-intuitive, receivers are often light sources,
| 140 |
since samples end up there in a backwards ray-tracing system such as RADIANCE.
| 141 |
.PP
| 142 |
Rays always eminate from the back side of the sender surface and arrive at the
| 143 |
front side of receiver surfaces.
| 144 |
In this way, a receiver surface may be reused as a sender in a subsequent
| 145 |
.I rfluxmtx
| 146 |
calculation and the resulting matrices will concatenate properly.
| 147 |
(Note that it is important to keep receiver surfaces together, otherwise a
| 148 |
"duplicate modifier" error will result.)\0
| 149 |
.SH EXAMPLES
| 150 |
To generate a flux transfer matrix connecting input and output apertures
| 151 |
on a light pipe:
| 152 |
.IP "" .3i
| 153 |
rcontrib int_aperture.rad ext_aperture.rad lpipe.rad > lpipe.mtx
| 154 |
.SH AUTHOR
| 155 |
Greg Ward
| 156 |
.SH "SEE ALSO"
| 157 |
genBSDF(1), getinfo(1), rcalc(1), rcollate(1), rcontrib(1), rmtxop(1), vwrays(1)
