root/Development/ray/doc/man/man1/replmarks.1
Revision: 1.2
Committed: Tue Dec 9 15:59:06 2003 UTC (22 years ago) by greg
Fixed RCSid specification
1 .\" RCSid "$Id$"
2 .TH REPLMARKS 1 3/24/94 RADIANCE
3 .SH NAME
4 replmarks - replace triangular markers in a RADIANCE scene description
5 .SH SYNOPSIS
6 .B replmarks
7 [
8 .B \-e
9 ][
10 .B "\-m newmod"
11 ][
12 .B "\-s scale"
13 ]
14 {
15 .B "\-x objfile"
16 |
17 .B "\-i octree"
18 }
19 .B "modname .."
20 [
21 .B "file .."
22 ]
23 .SH DESCRIPTION
24 .I Replmarks
25 replaces triangular markers identified by the modifier
26 .I modname
27 in each scene description
28 .I file
29 and writes the result to the standard output.
30 The
31 .I \-x
32 option indicates that each marker should be replaced by an appropriate
33 .I xform(1)
34 command on
35 .I objfile.
36 The
37 .I \-i
38 option indicates that each marker should be replaced by an instance of
39 .I octree.
40 One of these two options must appear on the command line, along with
41 .I modname,
42 the modifier used by markers in the file.
43 .PP
44 Multiple modifiers may be given, as long as each one is preceded
45 by its own
46 .I \-x
47 or
48 .I \-i
49 option.
50 .PP
51 The transformation for each marker is determined by its location
52 and orientation.
53 A marker should be a right triangle pointing like a half-arrow in
54 the direction of the transformed x-axis, x'.
55 The longest side is the hypoteneuse, the second longest side is
56 the x'-axis, and the third longest side indicates the direction of
57 the y'-axis.
58 Any additional sides will be ignored (ie. a quadrilateral may be
59 used instead of a triangle if the extra side is small).
60 The z'-axis is determined by the cross product of the x' and y'
61 axes, and the origin is the common vertex between x' and y'.
62 .PP
63 The size of the marker is ignored unless the
64 .I \-s
65 option is used, where
66 .I scale
67 is a multiplier for the x'-axis length to indicate the total scale
68 factor.
69 For example, a
70 .I scale
71 value of 5 with a marker length of .5 would result in a total
72 scale factor of 2.5 to be used in the transformation.
73 .PP
74 The
75 .I \-e
76 option causes commands in the file to be expanded, and
77 is required to replace markers from commands in the input file.
78 Even with this option,
79 .I replmarks
80 will not examine objects for markers.
81 Specifically, an object included by
82 .I replmarks
83 as a result of a
84 .I \-x
85 expansion will be transferred verbatim, without regard
86 to any surfaces therein that might have been considered
87 as marks if they were on the main input.
88 .PP
89 The
90 .I \-m
91 option causes all replaced objects to be given the modifier
92 .I newmod.
93 Otherwise, the new object surfaces will use their originally defined
94 modifiers.
95 A different replacement modifier may be given for each marker type.
96 The marker modifier name itself is only used to identify markers,
97 and will not appear in the output in any form.
98 .PP
99 If no input
100 .I file
101 is given, the standard input is read.
102 .SH EXAMPLE
103 To replace all polygons with the modifier ``knobs'' in the file input
104 with a transformed ``knob.rad'' and write the result to output:
105 .IP "" .2i
106 replmarks -x knob.rad knobs input > output
107 .PP
108 To use instances of ``tree.oct'' with scaling set to three times the
109 tree marker length:
110 .IP "" .2i
111 replmarks -s 3 -i tree.oct tree input > output
112 .SH AUTHOR
113 Greg Ward
114 .SH "SEE ALSO"
115 arch2rad(1), ies2rad(1), xform(1)
