root/Development/ray/doc/man/man1/replmarks.1
Revision: 1.5
Committed: Tue Sep 4 17:36:41 2007 UTC (18 years ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R1, rad4R0, rad3R9, rad4R2P1, rad4R2P2, HEAD
Changes since 1.4: +3 -3 lines
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
1 .\" RCSid "$Id: replmarks.1,v 1.4 2004/04/21 15:01:46 greg Exp $"
2 .TH REPLMARKS 1 3/24/94 RADIANCE
3 .SH NAME
4 replmarks - replace triangular markers in a RADIANCE scene description
5 .SH SYNOPSIS
6 .B replmarks
7 [
8 .B \-e
9 ][
10 .B "\-m newmod"
11 ][
12 .B "\-s scale"
13 ]
14 {
15 .B "\-x objfile"
16 |
17 .B "\-i octree"
18 |
19 .B "\-I mesh"
20 }
21 .B "modname .."
22 [
23 .B "file .."
24 ]
25 .SH DESCRIPTION
26 .I Replmarks
27 replaces triangular markers identified by the modifier
28 .I modname
29 in each scene description
30 .I file
31 and writes the result to the standard output.
32 The
33 .I \-x
34 option indicates that each marker should be replaced by an appropriate
35 .I xform(1)
36 command on
37 .I objfile.
38 The
39 .I \-i
40 option indicates that each marker should be replaced by an instance of
41 .I octree.
42 The
43 .I \-I
44 option indicates that each marker should be replaced by an instance of
45 the Radiance mesh
46 .I mesh.
47 One of these three options must appear on the command line, along with
48 .I modname,
49 the modifier used by markers in the file.
50 .PP
51 Multiple modifiers may be given, as long as each one is preceded
52 by its own
53 .I \-x
54 or
55 .I \-i
56 option.
57 .PP
58 The transformation for each marker is determined by its location
59 and orientation.
60 A marker should be a right triangle pointing like a half-arrow in
61 the direction of the transformed x-axis, x'.
62 The longest side is the hypoteneuse, the second longest side is
63 the x'-axis, and the third longest side indicates the direction of
64 the y'-axis.
65 Any additional sides will be ignored (ie. a quadrilateral may be
66 used instead of a triangle if the extra side is small).
67 The z'-axis is determined by the cross product of the x' and y'
68 axes, and the origin is the common vertex between x' and y'.
69 .PP
70 The size of the marker is ignored unless the
71 .I \-s
72 option is used, where
73 .I scale
74 is a multiplier for the x'-axis length to indicate the total scale
75 factor.
76 For example, a
77 .I scale
78 value of 5 with a marker length of .5 would result in a total
79 scale factor of 2.5 to be used in the transformation.
80 .PP
81 The
82 .I \-e
83 option causes commands in the file to be expanded, and
84 is required to replace markers from commands in the input file.
85 Even with this option,
86 .I replmarks
87 will not examine objects for markers.
88 Specifically, an object included by
89 .I replmarks
90 as a result of a
91 .I \-x
92 expansion will be transferred verbatim, without regard
93 to any surfaces therein that might have been considered
94 as marks if they were on the main input.
95 .PP
96 The
97 .I \-m
98 option causes all replaced objects to be given the modifier
99 .I newmod.
100 Otherwise, the new object surfaces will use their originally defined
101 modifiers.
102 A different replacement modifier may be given for each marker type.
103 The marker modifier name itself is only used to identify markers,
104 and will not appear in the output in any form.
105 .PP
106 If no input
107 .I file
108 is given, the standard input is read.
109 .SH EXAMPLE
110 To replace all polygons with the modifier ``knobs'' in the file input
111 with a transformed ``knob.rad'' and write the result to output:
112 .IP "" .2i
113 replmarks \-x knob.rad knobs input > output
114 .PP
115 To use instances of ``tree.oct'' with scaling set to three times the
116 tree marker length:
117 .IP "" .2i
118 replmarks \-s 3 \-i tree.oct tree input > output
119 .SH AUTHOR
120 Greg Ward
121 .SH "SEE ALSO"
122 arch2rad(1), ies2rad(1), xform(1)
