root/radiance/ray/doc/man/man1/replmarks.1
Revision: 1.5
Committed: Tue Sep 4 17:36:41 2007 UTC (17 years, 8 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad3R9, rad4R2P1, rad5R3, HEAD
Changes since 1.4: +3 -3 lines
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
# User Rev Content
1 greg 1.5 .\" RCSid "$Id: replmarks.1,v 1.4 2004/04/21 15:01:46 greg Exp $"
2 greg 1.1 .TH REPLMARKS 1 3/24/94 RADIANCE
3     .SH NAME
4     replmarks - replace triangular markers in a RADIANCE scene description
5     .SH SYNOPSIS
6     .B replmarks
7     [
8     .B \-e
9     ][
10     .B "\-m newmod"
11     ][
12     .B "\-s scale"
13     ]
14     {
15     .B "\-x objfile"
16     |
17     .B "\-i octree"
18 greg 1.3 |
19     .B "\-I mesh"
20 greg 1.1 }
21     .B "modname .."
22     [
23     .B "file .."
24     ]
25     .SH DESCRIPTION
26     .I Replmarks
27     replaces triangular markers identified by the modifier
28     .I modname
29     in each scene description
30     .I file
31     and writes the result to the standard output.
32     The
33     .I \-x
34     option indicates that each marker should be replaced by an appropriate
35     .I xform(1)
36     command on
37     .I objfile.
38     The
39     .I \-i
40     option indicates that each marker should be replaced by an instance of
41     .I octree.
42 greg 1.3 The
43     .I \-I
44     option indicates that each marker should be replaced by an instance of
45     the Radiance mesh
46     .I mesh.
47 greg 1.4 One of these three options must appear on the command line, along with
48 greg 1.1 .I modname,
49     the modifier used by markers in the file.
50     .PP
51     Multiple modifiers may be given, as long as each one is preceded
52     by its own
53     .I \-x
54     or
55     .I \-i
56     option.
57     .PP
58     The transformation for each marker is determined by its location
59     and orientation.
60     A marker should be a right triangle pointing like a half-arrow in
61     the direction of the transformed x-axis, x'.
62     The longest side is the hypoteneuse, the second longest side is
63     the x'-axis, and the third longest side indicates the direction of
64     the y'-axis.
65     Any additional sides will be ignored (ie. a quadrilateral may be
66     used instead of a triangle if the extra side is small).
67     The z'-axis is determined by the cross product of the x' and y'
68     axes, and the origin is the common vertex between x' and y'.
69     .PP
70     The size of the marker is ignored unless the
71     .I \-s
72     option is used, where
73     .I scale
74     is a multiplier for the x'-axis length to indicate the total scale
75     factor.
76     For example, a
77     .I scale
78     value of 5 with a marker length of .5 would result in a total
79     scale factor of 2.5 to be used in the transformation.
80     .PP
81     The
82     .I \-e
83     option causes commands in the file to be expanded, and
84     is required to replace markers from commands in the input file.
85     Even with this option,
86     .I replmarks
87     will not examine objects for markers.
88     Specifically, an object included by
89     .I replmarks
90     as a result of a
91     .I \-x
92     expansion will be transferred verbatim, without regard
93     to any surfaces therein that might have been considered
94     as marks if they were on the main input.
95     .PP
96     The
97     .I \-m
98     option causes all replaced objects to be given the modifier
99     .I newmod.
100     Otherwise, the new object surfaces will use their originally defined
101     modifiers.
102     A different replacement modifier may be given for each marker type.
103     The marker modifier name itself is only used to identify markers,
104     and will not appear in the output in any form.
105     .PP
106     If no input
107     .I file
108     is given, the standard input is read.
109     .SH EXAMPLE
110     To replace all polygons with the modifier ``knobs'' in the file input
111     with a transformed ``knob.rad'' and write the result to output:
112     .IP "" .2i
113 greg 1.5 replmarks \-x knob.rad knobs input > output
114 greg 1.1 .PP
115     To use instances of ``tree.oct'' with scaling set to three times the
116     tree marker length:
117     .IP "" .2i
118 greg 1.5 replmarks \-s 3 \-i tree.oct tree input > output
119 greg 1.1 .SH AUTHOR
120     Greg Ward
121     .SH "SEE ALSO"
122     arch2rad(1), ies2rad(1), xform(1)
