--- ray/doc/man/man1/rcrop.1 2022/03/15 04:41:45 1.2 +++ ray/doc/man/man1/rcrop.1 2024/05/17 20:50:57 1.9 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rcrop.1,v 1.2 2022/03/15 04:41:45 greg Exp $" +.\" RCSid "$Id: rcrop.1,v 1.9 2024/05/17 20:50:57 greg Exp $" .TH RCROP 1 3/14/2022 RADIANCE .SH NAME rcrop - crop RADIANCE matrix or picture @@ -20,11 +20,23 @@ Note that rows are numbered from 0 at the top of a mat and columns are changing fastest in the input, which can have any number of components per matrix element. .PP +The input must have a valid header, including dimensions and format, +and a header will always be produced. +This is similar behavior to +.I rmtxop(1). +If the input header is missing, one can usually be added with an +appropriate call to +.I rcollate(1). +If an output header is not desired, it can be removed using +.I getinfo(1). +.PP One cannot specify crop boundaries outside the matrix dimension limits. If a 0 value is specified for the number of rows to copy, then all rows will be copied, starting from row0. Similarly, a 0 value for the number of columns to copy implies all columns >= col0 will be copied. +A negative count for the number of rows or columns cuts the +corresponding amount off the end(s). .PP Using .I rcrop @@ -36,22 +48,25 @@ and preserves the exposure in a way that is compatible However, one must remember that rows correspond to Y coordinates, and the orientation is reversed from a standard picture, where Y=0 is the bottom scanline. +Spectral pictures, as might be produced by +.I rtrace(1) +or +.I rfluxmtx(1), +are also supported. .PP +All matrix formats are supported, including text (ASCII), binary float +and double. The .I rcrop tool also works on encoded normal vector files produced by .I rcode_norm(1) and encoded depth files produced by .I rcode_depth(1). -However, it is not able to crop identifier files produced by -.I rcode_ident(1). +Data is copied verbatim, i.e., there is no internal conversion to +another representation, although white space may change in text files. .PP If no input file is given, data will be taken from the standard input. If no output file is specified, data will be copied to the standard output. -All matrix formats are supported, including text (ASCII), binary float -and double. -Data is copied verbatim, i.e., there is no internal conversion to -another representation, although white space may change in text files. .SH EXAMPLES To crop a matrix down to 15 rows by 19 columns, starting at row 10 and column 12: @@ -66,8 +81,16 @@ To crop a picture to (X by Y) = (1500 by 1000), starting from upper-left corner: .IP "" .2i rcrop 0 0 1000 1500 orig.hdr cropped.hdr +.PP +Two ways of computing the inner product of row 15 in matrix 1 by +column 27 in matrix 2 and extracting the result without a header, +the second command being more efficient: +.IP "" .2i +rmtxop -fa mat1.mtx mat2.mtx | rcrop 15 27 1 1 | getinfo - +.IP "" .2i +rmtxop -fa '!rcrop 15 0 1 0 mat1.mtx' '!rcrop 0 27 0 1 mat2.mtx' | getinfo - .SH AUTHOR Greg Ward .SH "SEE ALSO" -evalglare(1), pcompos(1), rcalc(1), rcode_depth(1), -rcode_ident(1), rcode_norm(1), rcollate(1), rfluxmtx(1), rmtxop(1) +evalglare(1), pcompos(1), rcalc(1), rcode_depth(1), rcode_norm(1), +rcollate(1), rcomb(1), rfluxmtx(1), rmtxop(1), rsplit(1), rtrace(1)
