root/Development/ray/doc/man/man1/rcrop.1
Fri May 17 20:50:57 2024 UTC (19 months ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 1.8: +3 -1 lines
Diff to previous 1.8
feat(rcrop): Negative counts for #rows or #columns cut from the ends
Tue Dec 12 16:31:45 2023 UTC (2 years ago) by greg
Diff to previous 1.7
Wed Dec 6 01:27:00 2023 UTC (2 years ago) by greg
Diff to previous 1.6
docs(rmtxcomb): Added man page for new rmtxcomb tool
Tue Nov 21 02:16:59 2023 UTC (2 years, 1 month ago) by greg
Changes since 1.5: +8 -3 lines
Diff to previous 1.5
docs: Added mention of Radiance spectral picture support
Thu Mar 17 17:08:27 2022 UTC (3 years, 9 months ago) by greg
Changes since 1.4: +6 -8 lines
Diff to previous 1.4
docs(rcrop): Reorganized man page a bit for clarity
Wed Mar 16 00:06:08 2022 UTC (3 years, 9 months ago) by greg
Changes since 1.3: +3 -3 lines
Diff to previous 1.3
docs: Added cross-references
Tue Mar 15 17:19:52 2022 UTC (3 years, 9 months ago) by greg
Changes since 1.2: +19 -1 lines
Diff to previous 1.2
docs(rcrop): Added comment about header requirements and added rmtxop example
Tue Mar 15 04:41:45 2022 UTC (3 years, 9 months ago) by greg
Changes since 1.1: +12 -2 lines
Diff to previous 1.1
feat(rcrop): Added support for cropping encoded depth and normal files
Tue Mar 15 00:25:50 2022 UTC (3 years, 9 months ago) by greg
feat(rcrop): Created simple cropping utility for matrices and pictures
