--- ray/doc/man/man1/rcontrib.1 2012/11/15 19:41:03 1.6 +++ ray/doc/man/man1/rcontrib.1 2014/07/19 00:07:03 1.9 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rcontrib.1,v 1.6 2012/11/15 19:41:03 greg Exp $" +.\" RCSid "$Id: rcontrib.1,v 1.9 2014/07/19 00:07:03 greg Exp $" .TH RCONTRIB 1 5/25/05 RADIANCE .SH NAME rcontrib - compute contribution coefficients in a RADIANCE scene @@ -171,7 +171,6 @@ or option. Since bin numbers start from zero, the bin count is always equal to the last bin plus one. -Set the this value to zero if the bin count is unknown (the default). The most recent .I \-b, .I \-bn @@ -204,6 +203,10 @@ arguments and files read using the option. The computed bin value will be rounded to the nearest whole number. +(Negative bin values will be silently ignored.)\0 +For a single bin, you may specify +.I "\-b 0", +which is the default. This mechanism allows the user to define precise regions or directions they wish to accumulate, such as the Tregenza sky discretization, which would be otherwise impossible to specify @@ -212,7 +215,7 @@ The rules and predefined functions available for these described in the .I rcalc(1) man page. -Unlike +Like .I rcalc, .I rcontrib will search the RADIANCE library directories for each file given in a @@ -287,8 +290,8 @@ pcomb \-c 100 90 75 c_light1.hdr \-c 50 55 57 c_light2 .PP To compute an array of illuminance contributions according to a Tregenza sky: .IP "" .2i -rcontrib \-I+ \-b tbin \-o sky.dat \-m skyglow \-b 0 \-o ground.dat \-m groundglow -@render.opt \-f tregenza.cal scene.oct < test.dat +rcontrib \-I+ \-f tregenza.cal \-b tbin \-bn Ntbins \-o sky.dat \-m skyglow +\-b 0 \-o ground.dat \-m groundglow @render.opt scene.oct < test.dat .SH ENVIRONMENT RAYPATH path to search for \-f and \-M files .SH AUTHOR
