--- ray/doc/man/man1/rcontrib.1 2012/06/14 22:51:04 1.5 +++ ray/doc/man/man1/rcontrib.1 2023/12/06 01:27:00 1.22 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rcontrib.1,v 1.5 2012/06/14 22:51:04 greg Exp $" +.\" RCSid "$Id: rcontrib.1,v 1.22 2023/12/06 01:27:00 greg Exp $" .TH RCONTRIB 1 5/25/05 RADIANCE .SH NAME rcontrib - compute contribution coefficients in a RADIANCE scene @@ -9,6 +9,8 @@ rcontrib - compute contribution coefficients in a RADI ][ .B \-V ][ +.B "\-t secs" +][ .B "\-c count" ][ .B \-fo @@ -21,6 +23,8 @@ rcontrib - compute contribution coefficients in a RADI ][ .B "\-o ospec" ][ +.B "\-p p1=V1,p2=V2" +][ .B "\-b binv" ][ .B "\-bn nbins" @@ -41,6 +45,8 @@ rtrace options .B octree .br .B "rcontrib [ options ] \-defaults" +.br +.B "rcontrib \-features [feat1 ..]" .SH DESCRIPTION .I Rcontrib computes ray coefficients @@ -101,9 +107,9 @@ The option tells .I rcontrib how many rays to accumulate for each record. -The default value is 1, meaning a full record will be produced for +The default value is one, meaning a full record will be produced for each input ray. -For values greater than 1, contributions will be averaged together +For values greater than one, contributions will be averaged together over the given number of input rays. If set to zero, only a single record will be produced at the very end, corresponding to the sum of all rays given on the input @@ -113,9 +119,30 @@ This is equivalent to passing all the output records t to sum RGB values together, but is much more efficient. Using this option, it is possible to reverse sampling, sending rays from a parallel source such as the sun to a diffuse surface, for example. -Note that output flushing via zero-direction rays is disabled -for accumulated evaluations. +Note that output flushing via zero-direction rays is disabled with +.I \-c +set to zero. .PP +Output flushing at fixed intervals may be enabled with the +.I \-x +option, which specifies the number of records +(-c accumulations) before each flush. +If the +.I \-y +option is also set, then periodic flushing is disabled and the +output size for an RGB image is the taken from the x and y dimensions. +In lieu of periodic flushing, a flush may be forced as mentioned above +by sending a sample with a zero direction vector, although you +must still send a full record of rays before output occurs. +.PP +If progress reports are desired, the +.I \-t +option specifies a time interval in seconds for reports sent to +standard error. +This requires that the number of input samples is known, meaning a +.I \-y +parameter has been specified. +.PP The output of .I rcontrib has many potential uses. @@ -155,7 +182,10 @@ The option may be used to further define a "bin number" within each object if finer resolution is needed, and this will be applied to a "%d" format in the output file -specification if present. +specification if present. +(The final integer will be offset incrementally +if the output is a RADIANCE picture and more than one modifier has +the same format specification.)\0 The actual bin number is computed at run time based on ray direction and surface intersection, as described below. The number of bins must be specified in advance with the @@ -168,10 +198,10 @@ it has been defined via a previous or .I \-e option. -Since bin numbers start from 0, the bin count is always equal to -the last bin plus 1. -Set the this value to 0 if the bin count is unknown (the default). +Since bin numbers start from zero, the bin count is always equal to +the last bin plus one. The most recent +.I \-p, .I \-b, .I \-bn and @@ -185,7 +215,7 @@ and .I \-y if the .I \-c -is 0, when they control the resolution string +is zero, when they control the resolution string produced in the corresponding output. .PP If a @@ -201,8 +231,17 @@ These parameters may be combined with definitions give arguments and files read using the .I \-f option. +Additional parameter values that apply only to this modifier may be specified +with a +.I \-p +option, which contains a list of variable names and assigned values, separated +by commas, colons, or semicolons. The computed bin value will be rounded to the nearest whole number. +(Negative bin values will be silently ignored.)\0 +For a single bin, you may specify +.I "\-b 0", +which is the default. This mechanism allows the user to define precise regions or directions they wish to accumulate, such as the Tregenza sky discretization, which would be otherwise impossible to specify @@ -211,7 +250,7 @@ The rules and predefined functions available for these described in the .I rcalc(1) man page. -Unlike +Like .I rcalc, .I rcontrib will search the RADIANCE library directories for each file given in a @@ -266,9 +305,28 @@ A command argument beginning with a dollar sign ('$') replaced by the contents of the given environment variable. A command argument beginning with an at sign ('@') is immediately replaced by the contents of the given file. +.PP +.I Rcontrib +supports light source contributions from photon maps generated by +.I mkpmap(1) +with its +.I -apC +option. Enabling photon mapping is described in the +.I rtrace +man page along with its relevant settings. In photon mapping mode, +.I rcontrib +only supports contributions from light sources, not arbitrary modifiers. +The +.I -b +option is supported along with its associated ray variables, as +discussed above. Ray coefficients are also supported via the +.I \-V- +option. Using fewer photons than there are light sources for the photon +density estimates results in omitted contributions, thus the bandwidth +is clamped accordingly and a warning is issued. .SH EXAMPLES To compute the proportional contributions from sources modified -by "light1" vs. "light2" on a set of illuminance values: +by "light1" vs. "light2" on a set of irradiance values: .IP "" .2i rcontrib \-I+ @render.opt \-o c_%s.dat \-m light1 \-m light2 scene.oct < test.dat .PP @@ -284,14 +342,27 @@ of light1 and light2: .IP "" .2i pcomb \-c 100 90 75 c_light1.hdr \-c 50 55 57 c_light2.hdr > combined.hdr .PP -To compute an array of illuminance contributions according to a Tregenza sky: +To compute an array of irradiance contributions according to a Tregenza sky: .IP "" .2i -rcontrib \-I+ \-b tbin \-o sky.dat \-m skyglow \-b 0 \-o ground.dat \-m groundglow -@render.opt \-f tregenza.cal scene.oct < test.dat +rcontrib \-I+ \-f tregenza.cal \-b tbin \-bn Ntbins \-o sky.dat \-m skyglow +\-b 0 \-o ground.dat \-m groundglow @render.opt scene.oct < test.dat +.PP +To perform an annual simulation of 365 daily sun positions in photon mapping +mode: +.IP "" .2i +rcontrib \-I+ \-h \-V \-fo \-o c_%s.dat \-M lights \-ap contrib.pm 365 +scene.oct < test.dat, .SH ENVIRONMENT RAYPATH path to search for \-f and \-M files +.SH BUGS +We do not currently compute contributions or coefficients properly +in scenes with participating media. +A single warning will be issued if a scattering or absorbing medium +is detected. .SH AUTHOR Greg Ward .SH "SEE ALSO" -cnt(1), genklemsamp(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1), -rcalc(1), rpict(1), rsensor(1), rtrace(1), total(1), vwrays(1), ximage(1) +cnt(1), genklemsamp(1), getinfo(1), mkpmap(1), pcomb(1), pfilt(1), +ra_rgbe(1), rcalc(1), rfluxmtx(1), rmtxcomb(1), rmtxop(1), rpict(1), +rsensor(1), rtrace(1), total(1), vwrays(1), ximage(1) +
