--- ray/doc/man/man1/rcontrib.1 2016/09/12 20:31:34 1.13 +++ ray/doc/man/man1/rcontrib.1 2018/01/26 18:31:23 1.15 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rcontrib.1,v 1.13 2016/09/12 20:31:34 greg Exp $" +.\" RCSid "$Id: rcontrib.1,v 1.15 2018/01/26 18:31:23 rschregle Exp $" .TH RCONTRIB 1 5/25/05 RADIANCE .SH NAME rcontrib - compute contribution coefficients in a RADIANCE scene @@ -283,12 +283,13 @@ A command argument beginning with an at sign ('@') is replaced by the contents of the given file. .PP .I Rcontrib -has EXPERIMENTAL support for light source contributions from photon maps -generated by +supports light source contributions from photon maps generated by .I mkpmap(1) with its .I -apC -option. In photon mapping mode, +option. Enabling photon mapping is described in the +.I rtrace +man page along with its relevant settings. In photon mapping mode, .I rcontrib only supports contributions from light sources, not arbitrary modifiers. The @@ -298,7 +299,7 @@ discussed above. Ray coefficients are also supported v .I \-V- option. Using fewer photons than there are light sources for the photon density estimates results in omitted contributions, thus the bandwidth -is clamped accordingly and a warning issued. +is clamped accordingly and a warning is issued. .SH EXAMPLES To compute the proportional contributions from sources modified by "light1" vs. "light2" on a set of illuminance values:
