root/Development/ray/doc/man/man1/rcontrib.1
Sat Mar 14 16:25:46 2020 UTC (5 years, 9 months ago) by greg
Diff to previous 1.16 , to selected 1.11
Allow for colon as separator in parameter settings
Fri Feb 22 19:42:27 2019 UTC (6 years, 9 months ago) by greg
Changes since 1.15: +6 -1 lines
Diff to previous 1.15 , to selected 1.11
Added warning for contribution coefficient calculation with participating media
Fri Jan 26 18:31:23 2018 UTC (7 years, 10 months ago) by rschregle
Changes since 1.14: +5 -3 lines
Diff to previous 1.14 , to selected 1.11
Referred to rtrace for pmap settings
Fri Jan 26 18:11:50 2018 UTC (7 years, 10 months ago) by rschregle
Changes since 1.13: +2 -3 lines
Diff to previous 1.13 , to selected 1.11
Revised documentation of rcontrib's photon mapping mode; Promoted from
experimental (to semi-mature? ;^)
Mon Sep 12 20:31:34 2016 UTC (9 years, 3 months ago) by greg
Changes since 1.12: +5 -2 lines
Diff to previous 1.12 , to selected 1.11
Tue Feb 24 19:39:26 2015 UTC (10 years, 9 months ago) by greg
Changes since 1.11: +29 -4 lines
Diff to previous 1.11
Revision 1.11 - (view) (download) (annotate) - [selected]
Tue Jul 22 21:55:31 2014 UTC (11 years, 4 months ago) by greg
Diff to previous 1.10
Sat Jul 19 18:19:33 2014 UTC (11 years, 4 months ago) by greg
Changes since 1.9: +9 -1 lines
Diff to previous 1.9 , to selected 1.11
Sat Jul 19 00:07:03 2014 UTC (11 years, 4 months ago) by greg
Changes since 1.8: +2 -1 lines
Diff to previous 1.8 , to selected 1.11
Silently ignore negative bin values.
Fri Jul 11 01:52:38 2014 UTC (11 years, 5 months ago) by greg
Changes since 1.7: +5 -3 lines
Diff to previous 1.7 , to selected 1.11
Corrected errors in description
Fri Nov 1 15:32:58 2013 UTC (12 years, 1 month ago) by greg
Diff to previous 1.6 , to selected 1.11
Corrected errors in final example mentioned by Lars Grobe
Thu Nov 15 19:41:03 2012 UTC (13 years, 1 month ago) by greg
Changes since 1.5: +10 -9 lines
Diff to previous 1.5 , to selected 1.11
Thu Jun 14 22:51:04 2012 UTC (13 years, 6 months ago) by greg
Diff to previous 1.4 , to selected 1.11
Added -bn requirement
Thu Jun 14 22:49:34 2012 UTC (13 years, 6 months ago) by greg
Changes since 1.3: +4 -9 lines
Diff to previous 1.3 , to selected 1.11
Removed inaccurate references to rtrace subprocesses.
Thu Jun 14 22:45:23 2012 UTC (13 years, 6 months ago) by greg
Diff to previous 1.2 , to selected 1.11
Missed a couple of other name changes
Thu Jun 14 22:44:50 2012 UTC (13 years, 6 months ago) by greg
Diff to previous 1.1 , to selected 1.11
Missed one name change
Thu Jun 14 22:42:21 2012 UTC (13 years, 6 months ago) by greg
Diff to selected 1.11
