root/radiance/ray/doc/man/man1/rcontrib.1
Revision: 1.10
Committed: Sat Jul 19 18:19:33 2014 UTC (10 years, 11 months ago) by greg
Changes since 1.9: +9 -1 lines
1 .\" RCSid "$Id: rcontrib.1,v 1.9 2014/07/19 00:07:03 greg Exp $"
2 .TH RCONTRIB 1 5/25/05 RADIANCE
3 .SH NAME
4 rcontrib - compute contribution coefficients in a RADIANCE scene
5 .SH SYNOPSIS
6 .B rcontrib
7 [
8 .B "\-n nprocs"
9 ][
10 .B \-V
11 ][
12 .B "\-c count"
13 ][
14 .B \-fo
15 |
16 .B \-r
17 ][
18 .B "\-e expr"
19 ][
20 .B "\-f source"
21 ][
22 .B "\-o ospec"
23 ][
24 .B "\-p p1=V1,p2=V2"
25 ][
26 .B "\-b binv"
27 ][
28 .B "\-bn nbins"
29 ]
30 {
31 .B "\-m mod | \-M file"
32 }
33 ..
34 [
35 .B $EVAR
36 ]
37 [
38 .B @file
39 ]
40 [
41 rtrace options
42 ]
43 .B octree
44 .br
45 .B "rcontrib [ options ] \-defaults"
46 .SH DESCRIPTION
47 .I Rcontrib
48 computes ray coefficients
49 for objects whose modifiers are named in one or more
50 .I \-m
51 settings.
52 These modifiers are usually materials associated with
53 light sources or sky domes, and must directly modify some geometric
54 primitives to be considered in the output.
55 A modifier list may also be read from a file using the
56 .I \-M
57 option.
58 The RAYPATH environment variable determines directories to search for
59 this file.
60 (No search takes place if a file name begins with a '.', '/' or '~'
61 character.)\0
62 .PP
63 If the
64 .I \-n
65 option is specified with a value greater than 1, multiple
66 processes will be used to accelerate computation on a shared
67 memory machine.
68 Note that there is no benefit to using more processes
69 than there are local CPUs available to do the work, and the
70 .I rcontrib
71 process itself may use a considerable amount of CPU time.
72 .PP
73 By setting the boolean
74 .I \-V
75 option, you may instruct
76 .I rcontrib
77 to report the contribution from each material rather than the ray
78 coefficient.
79 This is particularly useful for light sources with directional output
80 distributions, whose value would otherwise be lost in the shuffle.
81 With the default
82 .I -V-
83 setting, the output of rcontrib is a coefficient that must be multiplied
84 by the radiance of each material to arrive at a final contribution.
85 This is more convenient for computing daylight coefficeints, or cases
86 where the actual radiance is not desired.
87 Use the
88 .I -V+
89 setting when you wish to simply sum together contributions
90 (with possible adjustment factors) to obtain a final radiance value.
91 Combined with the
92 .I \-i
93 or
94 .I \-I
95 option, irradiance contributions are reported by
96 .I \-V+
97 rather than radiance, and
98 .I \-V-
99 coefficients contain an additonal factor of PI.
100 .PP
101 The
102 .I \-c
103 option tells
104 .I rcontrib
105 how many rays to accumulate for each record.
106 The default value is one, meaning a full record will be produced for
107 each input ray.
108 For values greater than one, contributions will be averaged together
109 over the given number of input rays.
110 If set to zero, only a single record will be produced at the very
111 end, corresponding to the sum of all rays given on the input
112 (rather than the average).
113 This is equivalent to passing all the output records through a program like
114 .I total(1)
115 to sum RGB values together, but is much more efficient.
116 Using this option, it is possible to reverse sampling, sending rays from
117 a parallel source such as the sun to a diffuse surface, for example.
118 Note that output flushing via zero-direction rays is disabled with
119 .I \-c
120 set to zero.
121 .PP
122 The output of
123 .I rcontrib
124 has many potential uses.
125 Source contributions can be used as components in linear combination to
126 reproduce any desired variation, e.g., simulating lighting controls or
127 changing sky conditions via daylight coefficients.
128 More generally,
129 .I rcontrib
130 can be used to compute arbitrary input-output relationships in optical
131 systems, such as luminaires, light pipes, and shading devices.
132 .PP
133 .I Rcontrib
134 sends the accumulated rays tallies
135 to one or more destinations according to the given
136 .I \-o
137 specification.
138 If a destination begins with an exclamation mark ('!'), then
139 a pipe is opened to a command and data is sent to its standard input.
140 Otherwise, the destination is treated as a file.
141 An existing file of the same name will not be clobbered, unless the
142 .I \-fo
143 option is given.
144 If instead the
145 .I \-r
146 option is specified, data recovery is attempted on existing files.
147 (If
148 .I "\-c 0"
149 is used together with the
150 .I \-r
151 option, existing files are read in and new ray evaluations are added
152 to the previous results, providing a convenient means for
153 progressive simulation.)\0
154 If an output specification contains a "%s" format, this will be
155 replaced by the modifier name.
156 The
157 .I \-b
158 option may be used to further define
159 a "bin number" within each object if finer resolution is needed, and
160 this will be applied to a "%d" format in the output file
161 specification if present.
162 The actual bin number is computed at run time based on ray direction
163 and surface intersection, as described below.
164 The number of bins must be specified in advance with the
165 .I \-bn
166 option, and this is critical for output files containing multiple values
167 per record.
168 A variable or constant name may be given for this parameter if
169 it has been defined via a previous
170 .I \-f
171 or
172 .I \-e
173 option.
174 Since bin numbers start from zero, the bin count is always equal to
175 the last bin plus one.
176 The most recent
177 .I \-p,
178 .I \-b,
179 .I \-bn
180 and
181 .I \-o
182 options to the left of each
183 .I \-m
184 setting are the ones used for that modifier.
185 The ordering of other options is unimportant, except for
186 .I \-x
187 and
188 .I \-y
189 if the
190 .I \-c
191 is zero, when they control the resolution string
192 produced in the corresponding output.
193 .PP
194 If a
195 .I \-b
196 expression is defined for a particular modifier,
197 the bin number will be evaluated at run time for each
198 ray contribution.
199 Specifically, each ray's world intersection point will be assigned to
200 the variables Px, Py, and Pz, and the normalized ray direction
201 will be assigned to Dx, Dy, and Dz.
202 These parameters may be combined with definitions given in
203 .I \-e
204 arguments and files read using the
205 .I \-f
206 option.
207 Additional parameter values that apply only to this modifier may be specified
208 with a
209 .I \-p
210 option, which contains a list of variable names and assigned values, separated
211 by commas or semicolons.
212 The computed bin value will be
213 rounded to the nearest whole number.
214 (Negative bin values will be silently ignored.)\0
215 For a single bin, you may specify
216 .I "\-b 0",
217 which is the default.
218 This mechanism allows the user to define precise regions or directions
219 they wish to accumulate, such as the Tregenza sky discretization,
220 which would be otherwise impossible to specify
221 as a set of RADIANCE primitives.
222 The rules and predefined functions available for these expressions are
223 described in the
224 .I rcalc(1)
225 man page.
227 .I rcalc,
228 .I rcontrib
229 will search the RADIANCE library directories for each file given in a
230 .I \-f
231 option.
232 .PP
233 If no
234 .I \-o
235 specification is given, results are written on the standard output in order
236 of modifier (as given on the command line) then bin number.
237 Concatenated data is also sent to a single destination (i.e., an initial
238 .I \-o
239 specification without formatting strings).
240 If a "%s" format appears but no "%d" in the
241 .I \-o
242 specification, then each modifier will have its own output file, with
243 multiple values per record in the case of a non-zero
244 .I \-b
245 definition.
246 If a "%d" format appears but no "%s", then each bin will get its own
247 output file, with modifiers output in order in each record.
248 For text output, each RGB coefficient triple is separated by a tab,
249 with a newline at the end of each ray record.
250 For binary output formats, there is no such delimiter to mark
251 the end of each record.
252 .PP
253 Input and output format defaults to plain text, where each ray's
254 origin and direction (6 real values) are given on input,
255 and one line is produced per output file per ray.
256 Alternative data representations may be specified by the
257 .I \-f[io]
258 option, which is described in the
259 .I rtrace
260 man page along with the associated
261 .I \-x
262 and
263 .I \-y
264 resolution settings.
265 In particular, the color ('c') output data representation
266 together with positive dimensions for
267 .I \-x
268 and
269 .I \-y
270 will produce an uncompressed RADIANCE picture,
271 suitable for manipulation with
272 .I pcomb(1)
273 and related tools.
274 .PP
275 Options may be given on the command line and/or read from the
276 environment and/or read from a file.
277 A command argument beginning with a dollar sign ('$') is immediately
278 replaced by the contents of the given environment variable.
279 A command argument beginning with an at sign ('@') is immediately
280 replaced by the contents of the given file.
281 .SH EXAMPLES
282 To compute the proportional contributions from sources modified
283 by "light1" vs. "light2" on a set of illuminance values:
284 .IP "" .2i
285 rcontrib \-I+ @render.opt \-o c_%s.dat \-m light1 \-m light2 scene.oct < test.dat
286 .PP
287 To generate a pair of images corresponding to these two lights'
288 contributions:
289 .IP "" .2i
290 vwrays \-ff \-x 1024 \-y 1024 \-vf best.vf |
291 rcontrib \-ffc `vwrays \-d \-x 1024 \-y 1024 \-vf best.vf`
292 @render.opt \-o c_%s.hdr \-m light1 \-m light2 scene.oct
293 .PP
294 These images may then be recombined using the desired outputs
295 of light1 and light2:
296 .IP "" .2i
297 pcomb \-c 100 90 75 c_light1.hdr \-c 50 55 57 c_light2.hdr > combined.hdr
298 .PP
299 To compute an array of illuminance contributions according to a Tregenza sky:
300 .IP "" .2i
301 rcontrib \-I+ \-f tregenza.cal \-b tbin \-bn Ntbins \-o sky.dat \-m skyglow
302 \-b 0 \-o ground.dat \-m groundglow @render.opt scene.oct < test.dat
303 .SH ENVIRONMENT
304 RAYPATH path to search for \-f and \-M files
305 .SH AUTHOR
306 Greg Ward
307 .SH "SEE ALSO"
308 cnt(1), genklemsamp(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1),
309 rcalc(1), rpict(1), rsensor(1), rtrace(1), total(1), vwrays(1), ximage(1)
