1 |
.\" RCSid "$Id: rcontrib.1,v 1.6 2012/11/15 19:41:03 greg Exp $" |
2 |
.TH RCONTRIB 1 5/25/05 RADIANCE |
3 |
.SH NAME |
4 |
rcontrib - compute contribution coefficients in a RADIANCE scene |
5 |
.SH SYNOPSIS |
6 |
.B rcontrib |
7 |
8 |
.B "\-n nprocs" |
9 |
10 |
.B \-V |
11 |
12 |
.B "\-c count" |
13 |
14 |
.B \-fo |
15 |
16 |
.B \-r |
17 |
18 |
.B "\-e expr" |
19 |
20 |
.B "\-f source" |
21 |
22 |
.B "\-o ospec" |
23 |
24 |
.B "\-b binv" |
25 |
26 |
.B "\-bn nbins" |
27 |
28 |
29 |
.B "\-m mod | \-M file" |
30 |
31 |
32 |
33 |
.B $EVAR |
34 |
35 |
36 |
.B @file |
37 |
38 |
39 |
rtrace options |
40 |
41 |
.B octree |
42 |
.br |
43 |
.B "rcontrib [ options ] \-defaults" |
44 |
.SH DESCRIPTION |
45 |
.I Rcontrib |
46 |
computes ray coefficients |
47 |
for objects whose modifiers are named in one or more |
48 |
.I \-m |
49 |
settings. |
50 |
These modifiers are usually materials associated with |
51 |
light sources or sky domes, and must directly modify some geometric |
52 |
primitives to be considered in the output. |
53 |
A modifier list may also be read from a file using the |
54 |
.I \-M |
55 |
option. |
56 |
The RAYPATH environment variable determines directories to search for |
57 |
this file. |
58 |
(No search takes place if a file name begins with a '.', '/' or '~' |
59 |
character.)\0 |
60 |
.PP |
61 |
If the |
62 |
.I \-n |
63 |
option is specified with a value greater than 1, multiple |
64 |
processes will be used to accelerate computation on a shared |
65 |
memory machine. |
66 |
Note that there is no benefit to using more processes |
67 |
than there are local CPUs available to do the work, and the |
68 |
.I rcontrib |
69 |
process itself may use a considerable amount of CPU time. |
70 |
.PP |
71 |
By setting the boolean |
72 |
.I \-V |
73 |
option, you may instruct |
74 |
.I rcontrib |
75 |
to report the contribution from each material rather than the ray |
76 |
coefficient. |
77 |
This is particularly useful for light sources with directional output |
78 |
distributions, whose value would otherwise be lost in the shuffle. |
79 |
With the default |
80 |
.I -V- |
81 |
setting, the output of rcontrib is a coefficient that must be multiplied |
82 |
by the radiance of each material to arrive at a final contribution. |
83 |
This is more convenient for computing daylight coefficeints, or cases |
84 |
where the actual radiance is not desired. |
85 |
Use the |
86 |
.I -V+ |
87 |
setting when you wish to simply sum together contributions |
88 |
(with possible adjustment factors) to obtain a final radiance value. |
89 |
Combined with the |
90 |
.I \-i |
91 |
or |
92 |
.I \-I |
93 |
option, irradiance contributions are reported by |
94 |
.I \-V+ |
95 |
rather than radiance, and |
96 |
.I \-V- |
97 |
coefficients contain an additonal factor of PI. |
98 |
.PP |
99 |
The |
100 |
.I \-c |
101 |
option tells |
102 |
.I rcontrib |
103 |
how many rays to accumulate for each record. |
104 |
The default value is one, meaning a full record will be produced for |
105 |
each input ray. |
106 |
For values greater than one, contributions will be averaged together |
107 |
over the given number of input rays. |
108 |
If set to zero, only a single record will be produced at the very |
109 |
end, corresponding to the sum of all rays given on the input |
110 |
(rather than the average). |
111 |
This is equivalent to passing all the output records through a program like |
112 |
.I total(1) |
113 |
to sum RGB values together, but is much more efficient. |
114 |
Using this option, it is possible to reverse sampling, sending rays from |
115 |
a parallel source such as the sun to a diffuse surface, for example. |
116 |
Note that output flushing via zero-direction rays is disabled with |
117 |
.I \-c |
118 |
set to zero. |
119 |
.PP |
120 |
The output of |
121 |
.I rcontrib |
122 |
has many potential uses. |
123 |
Source contributions can be used as components in linear combination to |
124 |
reproduce any desired variation, e.g., simulating lighting controls or |
125 |
changing sky conditions via daylight coefficients. |
126 |
More generally, |
127 |
.I rcontrib |
128 |
can be used to compute arbitrary input-output relationships in optical |
129 |
systems, such as luminaires, light pipes, and shading devices. |
130 |
.PP |
131 |
.I Rcontrib |
132 |
sends the accumulated rays tallies |
133 |
to one or more destinations according to the given |
134 |
.I \-o |
135 |
specification. |
136 |
If a destination begins with an exclamation mark ('!'), then |
137 |
a pipe is opened to a command and data is sent to its standard input. |
138 |
Otherwise, the destination is treated as a file. |
139 |
An existing file of the same name will not be clobbered, unless the |
140 |
.I \-fo |
141 |
option is given. |
142 |
If instead the |
143 |
.I \-r |
144 |
option is specified, data recovery is attempted on existing files. |
145 |
(If |
146 |
.I "\-c 0" |
147 |
is used together with the |
148 |
.I \-r |
149 |
option, existing files are read in and new ray evaluations are added |
150 |
to the previous results, providing a convenient means for |
151 |
progressive simulation.)\0 |
152 |
If an output specification contains a "%s" format, this will be |
153 |
replaced by the modifier name. |
154 |
The |
155 |
.I \-b |
156 |
option may be used to further define |
157 |
a "bin number" within each object if finer resolution is needed, and |
158 |
this will be applied to a "%d" format in the output file |
159 |
specification if present. |
160 |
The actual bin number is computed at run time based on ray direction |
161 |
and surface intersection, as described below. |
162 |
The number of bins must be specified in advance with the |
163 |
.I \-bn |
164 |
option, and this is critical for output files containing multiple values |
165 |
per record. |
166 |
A variable or constant name may be given for this parameter if |
167 |
it has been defined via a previous |
168 |
.I \-f |
169 |
or |
170 |
.I \-e |
171 |
option. |
172 |
Since bin numbers start from zero, the bin count is always equal to |
173 |
the last bin plus one. |
174 |
Set the this value to zero if the bin count is unknown (the default). |
175 |
The most recent |
176 |
.I \-b, |
177 |
.I \-bn |
178 |
and |
179 |
.I \-o |
180 |
options to the left of each |
181 |
.I \-m |
182 |
setting are the ones used for that modifier. |
183 |
The ordering of other options is unimportant, except for |
184 |
.I \-x |
185 |
and |
186 |
.I \-y |
187 |
if the |
188 |
.I \-c |
189 |
is zero, when they control the resolution string |
190 |
produced in the corresponding output. |
191 |
.PP |
192 |
If a |
193 |
.I \-b |
194 |
expression is defined for a particular modifier, |
195 |
the bin number will be evaluated at run time for each |
196 |
ray contribution. |
197 |
Specifically, each ray's world intersection point will be assigned to |
198 |
the variables Px, Py, and Pz, and the normalized ray direction |
199 |
will be assigned to Dx, Dy, and Dz. |
200 |
These parameters may be combined with definitions given in |
201 |
.I \-e |
202 |
arguments and files read using the |
203 |
.I \-f |
204 |
option. |
205 |
The computed bin value will be |
206 |
rounded to the nearest whole number. |
207 |
This mechanism allows the user to define precise regions or directions |
208 |
they wish to accumulate, such as the Tregenza sky discretization, |
209 |
which would be otherwise impossible to specify |
210 |
as a set of RADIANCE primitives. |
211 |
The rules and predefined functions available for these expressions are |
212 |
described in the |
213 |
.I rcalc(1) |
214 |
man page. |
215 |
Unlike |
216 |
.I rcalc, |
217 |
.I rcontrib |
218 |
will search the RADIANCE library directories for each file given in a |
219 |
.I \-f |
220 |
option. |
221 |
.PP |
222 |
If no |
223 |
.I \-o |
224 |
specification is given, results are written on the standard output in order |
225 |
of modifier (as given on the command line) then bin number. |
226 |
Concatenated data is also sent to a single destination (i.e., an initial |
227 |
.I \-o |
228 |
specification without formatting strings). |
229 |
If a "%s" format appears but no "%d" in the |
230 |
.I \-o |
231 |
specification, then each modifier will have its own output file, with |
232 |
multiple values per record in the case of a non-zero |
233 |
.I \-b |
234 |
definition. |
235 |
If a "%d" format appears but no "%s", then each bin will get its own |
236 |
output file, with modifiers output in order in each record. |
237 |
For text output, each RGB coefficient triple is separated by a tab, |
238 |
with a newline at the end of each ray record. |
239 |
For binary output formats, there is no such delimiter to mark |
240 |
the end of each record. |
241 |
.PP |
242 |
Input and output format defaults to plain text, where each ray's |
243 |
origin and direction (6 real values) are given on input, |
244 |
and one line is produced per output file per ray. |
245 |
Alternative data representations may be specified by the |
246 |
.I \-f[io] |
247 |
option, which is described in the |
248 |
.I rtrace |
249 |
man page along with the associated |
250 |
.I \-x |
251 |
and |
252 |
.I \-y |
253 |
resolution settings. |
254 |
In particular, the color ('c') output data representation |
255 |
together with positive dimensions for |
256 |
.I \-x |
257 |
and |
258 |
.I \-y |
259 |
will produce an uncompressed RADIANCE picture, |
260 |
suitable for manipulation with |
261 |
.I pcomb(1) |
262 |
and related tools. |
263 |
.PP |
264 |
Options may be given on the command line and/or read from the |
265 |
environment and/or read from a file. |
266 |
A command argument beginning with a dollar sign ('$') is immediately |
267 |
replaced by the contents of the given environment variable. |
268 |
A command argument beginning with an at sign ('@') is immediately |
269 |
replaced by the contents of the given file. |
270 |
.SH EXAMPLES |
271 |
To compute the proportional contributions from sources modified |
272 |
by "light1" vs. "light2" on a set of illuminance values: |
273 |
.IP "" .2i |
274 |
rcontrib \-I+ @render.opt \-o c_%s.dat \-m light1 \-m light2 scene.oct < test.dat |
275 |
.PP |
276 |
To generate a pair of images corresponding to these two lights' |
277 |
contributions: |
278 |
.IP "" .2i |
279 |
vwrays \-ff \-x 1024 \-y 1024 \-vf best.vf | |
280 |
rcontrib \-ffc `vwrays \-d \-x 1024 \-y 1024 \-vf best.vf` |
281 |
@render.opt \-o c_%s.hdr \-m light1 \-m light2 scene.oct |
282 |
.PP |
283 |
These images may then be recombined using the desired outputs |
284 |
of light1 and light2: |
285 |
.IP "" .2i |
286 |
pcomb \-c 100 90 75 c_light1.hdr \-c 50 55 57 c_light2.hdr > combined.hdr |
287 |
.PP |
288 |
To compute an array of illuminance contributions according to a Tregenza sky: |
289 |
.IP "" .2i |
290 |
rcontrib \-I+ \-f tregenza.cal \-b tbin \-bn Ntbins \-o sky.dat \-m skyglow |
291 |
\-b 0 \-o ground.dat \-m groundglow @render.opt scene.oct < test.dat |
292 |
.SH ENVIRONMENT |
293 |
RAYPATH path to search for \-f and \-M files |
294 |
.SH AUTHOR |
295 |
Greg Ward |
296 |
.SH "SEE ALSO" |
297 |
cnt(1), genklemsamp(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1), |
298 |
rcalc(1), rpict(1), rsensor(1), rtrace(1), total(1), vwrays(1), ximage(1) |
