root/radiance/ray/doc/man/man1/rcontrib.1
Mon Sep 12 20:31:34 2016 UTC (8 years, 9 months ago) by greg
Changes since 1.12: +5 -2 lines
Diff to previous 1.12 , to selected 1.3
Tue Feb 24 19:39:26 2015 UTC (10 years, 3 months ago) by greg
Changes since 1.11: +29 -4 lines
Diff to previous 1.11 , to selected 1.3
Tue Jul 22 21:55:31 2014 UTC (10 years, 10 months ago) by greg
Diff to previous 1.10 , to selected 1.3
Sat Jul 19 18:19:33 2014 UTC (10 years, 10 months ago) by greg
Changes since 1.9: +9 -1 lines
Diff to previous 1.9 , to selected 1.3
Sat Jul 19 00:07:03 2014 UTC (10 years, 10 months ago) by greg
Changes since 1.8: +2 -1 lines
Diff to previous 1.8 , to selected 1.3
Silently ignore negative bin values.
Fri Jul 11 01:52:38 2014 UTC (10 years, 11 months ago) by greg
Changes since 1.7: +5 -3 lines
Diff to previous 1.7 , to selected 1.3
Corrected errors in description
Fri Nov 1 15:32:58 2013 UTC (11 years, 7 months ago) by greg
Diff to previous 1.6 , to selected 1.3
Corrected errors in final example mentioned by Lars Grobe
Thu Nov 15 19:41:03 2012 UTC (12 years, 7 months ago) by greg
Changes since 1.5: +10 -9 lines
Diff to previous 1.5 , to selected 1.3
Thu Jun 14 22:51:04 2012 UTC (13 years ago) by greg
Diff to previous 1.4 , to selected 1.3
Added -bn requirement
Thu Jun 14 22:49:34 2012 UTC (13 years ago) by greg
Changes since 1.3: +4 -9 lines
Diff to previous 1.3
Removed inaccurate references to rtrace subprocesses.
Revision 1.3 - (view) (download) (annotate) - [selected]
Thu Jun 14 22:45:23 2012 UTC (13 years ago) by greg
Diff to previous 1.2
Missed a couple of other name changes
Thu Jun 14 22:44:50 2012 UTC (13 years ago) by greg
Diff to previous 1.1 , to selected 1.3
Missed one name change
Thu Jun 14 22:42:21 2012 UTC (13 years ago) by greg
Diff to selected 1.3
