root/Development/ray/doc/man/man1/rcontrib.1
Revision: 1.24
Committed: Wed Oct 23 23:51:20 2024 UTC (13 months, 3 weeks ago) by greg
Changes since 1.23: +6 -2 lines
fix(rcontrib): Added a check that the number of color samples doesn't change after the first modifier is specified
1 .\" RCSid "$Id: rcontrib.1,v 1.23 2023/12/12 16:31:45 greg Exp $"
2 .TH RCONTRIB 1 5/25/05 RADIANCE
3 .SH NAME
4 rcontrib - compute contribution coefficients in a RADIANCE scene
5 .SH SYNOPSIS
6 .B rcontrib
7 [
8 .B "\-n nprocs"
9 ][
10 .B \-V
11 ][
12 .B "\-t secs"
13 ][
14 .B "\-c count"
15 ][
16 .B \-fo
17 |
18 .B \-r
19 ][
20 .B "\-e expr"
21 ][
22 .B "\-f source"
23 ][
24 .B "\-o ospec"
25 ][
26 .B "\-p p1=V1,p2=V2"
27 ][
28 .B "\-b binv"
29 ][
30 .B "\-bn nbins"
31 ]
32 {
33 .B "\-m mod | \-M file"
34 }
35 ..
36 [
37 .B $EVAR
38 ]
39 [
40 .B @file
41 ]
42 [
43 rtrace options
44 ]
45 .B octree
46 .br
47 .B "rcontrib [ options ] \-defaults"
48 .br
49 .B "rcontrib \-features [feat1 ..]"
50 .SH DESCRIPTION
51 .I Rcontrib
52 computes ray coefficients
53 for objects whose modifiers are named in one or more
54 .I \-m
55 settings.
56 These modifiers are usually materials associated with
57 light sources or sky domes, and must directly modify some geometric
58 primitives to be considered in the output.
59 A modifier list may also be read from a file using the
60 .I \-M
61 option.
62 The RAYPATH environment variable determines directories to search for
63 this file.
64 (No search takes place if a file name begins with a '.', '/' or '~'
65 character.)\0
66 .PP
67 If the
68 .I \-n
69 option is specified with a value greater than 1, multiple
70 processes will be used to accelerate computation on a shared
71 memory machine.
72 Note that there is no benefit to using more processes
73 than there are local CPUs available to do the work, and the
74 .I rcontrib
75 process itself may use a considerable amount of CPU time.
76 .PP
77 By setting the boolean
78 .I \-V
79 option, you may instruct
80 .I rcontrib
81 to report the contribution from each material rather than the ray
82 coefficient.
83 This is particularly useful for light sources with directional output
84 distributions, whose value would otherwise be lost in the shuffle.
85 With the default
86 .I -V-
87 setting, the output of rcontrib is a coefficient that must be multiplied
88 by the radiance of each material to arrive at a final contribution.
89 This is more convenient for computing daylight coefficeints, or cases
90 where the actual radiance is not desired.
91 Use the
92 .I -V+
93 setting when you wish to simply sum together contributions
94 (with possible adjustment factors) to obtain a final radiance value.
95 Combined with the
96 .I \-i
97 or
98 .I \-I
99 option, irradiance contributions are reported by
100 .I \-V+
101 rather than radiance, and
102 .I \-V-
103 coefficients contain an additonal factor of PI.
104 .PP
105 The
106 .I \-c
107 option tells
108 .I rcontrib
109 how many rays to accumulate for each record.
110 The default value is one, meaning a full record will be produced for
111 each input ray.
112 For values greater than one, contributions will be averaged together
113 over the given number of input rays.
114 If set to zero, only a single record will be produced at the very
115 end, corresponding to the sum of all rays given on the input
116 (rather than the average).
117 This is equivalent to passing all the output records through a program like
118 .I total(1)
119 to sum RGB values together, but is much more efficient.
120 Using this option, it is possible to reverse sampling, sending rays from
121 a parallel source such as the sun to a diffuse surface, for example.
122 Note that output flushing via zero-direction rays is disabled with
123 .I \-c
124 set to zero.
125 .PP
126 Output flushing at fixed intervals may be enabled with the
127 .I \-x
128 option, which specifies the number of records
129 (-c accumulations) before each flush.
130 If the
131 .I \-y
132 option is also set, then periodic flushing is disabled and the
133 output size for an RGB image is the taken from the x and y dimensions.
134 In lieu of periodic flushing, a flush may be forced as mentioned above
135 by sending a sample with a zero direction vector, although you
136 must still send a full record of rays before output occurs.
137 .PP
138 If progress reports are desired, the
139 .I \-t
140 option specifies a time interval in seconds for reports sent to
141 standard error.
142 This requires that the number of input samples is known, meaning a
143 .I \-y
144 parameter has been specified.
145 .PP
146 The output of
147 .I rcontrib
148 has many potential uses.
149 Source contributions can be used as components in linear combination to
150 reproduce any desired variation, e.g., simulating lighting controls or
151 changing sky conditions via daylight coefficients.
152 More generally,
153 .I rcontrib
154 can be used to compute arbitrary input-output relationships in optical
155 systems, such as luminaires, light pipes, and shading devices.
156 .PP
157 .I Rcontrib
158 sends the accumulated rays tallies
159 to one or more destinations according to the given
160 .I \-o
161 specification.
162 If a destination begins with an exclamation mark ('!'), then
163 a pipe is opened to a command and data is sent to its standard input.
164 Otherwise, the destination is treated as a file.
165 An existing file of the same name will not be clobbered, unless the
166 .I \-fo
167 option is given.
168 If instead the
169 .I \-r
170 option is specified, data recovery is attempted on existing files.
171 (If
172 .I "\-c 0"
173 is used together with the
174 .I \-r
175 option, existing files are read in and new ray evaluations are added
176 to the previous results, providing a convenient means for
177 progressive simulation.)\0
178 If an output specification contains a "%s" format, this will be
179 replaced by the modifier name.
180 The
181 .I \-b
182 option may be used to further define
183 a "bin number" within each object if finer resolution is needed, and
184 this will be applied to a "%d" format in the output file
185 specification if present.
186 (The final integer will be offset incrementally
187 if the output is a RADIANCE picture and more than one modifier has
188 the same format specification.)\0
189 The actual bin number is computed at run time based on ray direction
190 and surface intersection, as described below.
191 The number of bins must be specified in advance with the
192 .I \-bn
193 option, and this is critical for output files containing multiple values
194 per record.
195 A variable or constant name may be given for this parameter if
196 it has been defined via a previous
197 .I \-f
198 or
199 .I \-e
200 option.
201 Since bin numbers start from zero, the bin count is always equal to
202 the last bin plus one.
203 The most recent
204 .I \-p,
205 .I \-b,
206 .I \-bn
207 and
208 .I \-o
209 options to the left of each
210 .I \-m
211 name are the ones used for that modifier.
212 Any
213 .I \-cs
214 option changing the number of spectral color
215 samples must appear before the first modifier.
216 The ordering of other options is unimportant, except for
217 .I \-x
218 and
219 .I \-y
220 if the
221 .I \-c
222 is zero, when they control the resolution string
223 produced in the corresponding output.
224 .PP
225 If a
226 .I \-b
227 expression is defined for a particular modifier,
228 the bin number will be evaluated at run time for each
229 ray contribution.
230 Specifically, each ray's world intersection point will be assigned to
231 the variables Px, Py, and Pz, and the normalized ray direction
232 will be assigned to Dx, Dy, and Dz.
233 These parameters may be combined with definitions given in
234 .I \-e
235 arguments and files read using the
236 .I \-f
237 option.
238 Additional parameter values that apply only to this modifier may be specified
239 with a
240 .I \-p
241 option, which contains a list of variable names and assigned values, separated
242 by commas, colons, or semicolons.
243 The computed bin value will be
244 rounded to the nearest whole number.
245 (Negative bin values will be silently ignored.)\0
246 For a single bin, you may specify
247 .I "\-b 0",
248 which is the default.
249 This mechanism allows the user to define precise regions or directions
250 they wish to accumulate, such as the Tregenza sky discretization,
251 which would be otherwise impossible to specify
252 as a set of RADIANCE primitives.
253 The rules and predefined functions available for these expressions are
254 described in the
255 .I rcalc(1)
256 man page.
258 .I rcalc,
259 .I rcontrib
260 will search the RADIANCE library directories for each file given in a
261 .I \-f
262 option.
263 .PP
264 If no
265 .I \-o
266 specification is given, results are written on the standard output in order
267 of modifier (as given on the command line) then bin number.
268 Concatenated data is also sent to a single destination (i.e., an initial
269 .I \-o
270 specification without formatting strings).
271 If a "%s" format appears but no "%d" in the
272 .I \-o
273 specification, then each modifier will have its own output file, with
274 multiple values per record in the case of a non-zero
275 .I \-b
276 definition.
277 If a "%d" format appears but no "%s", then each bin will get its own
278 output file, with modifiers output in order in each record.
279 For text output, each RGB coefficient triple is separated by a tab,
280 with a newline at the end of each ray record.
281 For binary output formats, there is no such delimiter to mark
282 the end of each record.
283 .PP
284 Input and output format defaults to plain text, where each ray's
285 origin and direction (6 real values) are given on input,
286 and one line is produced per output file per ray.
287 Alternative data representations may be specified by the
288 .I \-f[io]
289 option, which is described in the
290 .I rtrace
291 man page along with the associated
292 .I \-x
293 and
294 .I \-y
295 resolution settings.
296 In particular, the color ('c') output data representation
297 together with positive dimensions for
298 .I \-x
299 and
300 .I \-y
301 will produce an uncompressed RADIANCE picture,
302 suitable for manipulation with
303 .I pcomb(1)
304 and related tools.
305 .PP
306 Options may be given on the command line and/or read from the
307 environment and/or read from a file.
308 A command argument beginning with a dollar sign ('$') is immediately
309 replaced by the contents of the given environment variable.
310 A command argument beginning with an at sign ('@') is immediately
311 replaced by the contents of the given file.
312 .PP
313 .I Rcontrib
314 supports light source contributions from photon maps generated by
315 .I mkpmap(1)
316 with its
317 .I -apC
318 option. Enabling photon mapping is described in the
319 .I rtrace
320 man page along with its relevant settings. In photon mapping mode,
321 .I rcontrib
322 only supports contributions from light sources, not arbitrary modifiers.
323 The
324 .I -b
325 option is supported along with its associated ray variables, as
326 discussed above. Ray coefficients are also supported via the
327 .I \-V-
328 option. Using fewer photons than there are light sources for the photon
329 density estimates results in omitted contributions, thus the bandwidth
330 is clamped accordingly and a warning is issued.
331 .SH EXAMPLES
332 To compute the proportional contributions from sources modified
333 by "light1" vs. "light2" on a set of irradiance values:
334 .IP "" .2i
335 rcontrib \-I+ @render.opt \-o c_%s.dat \-m light1 \-m light2 scene.oct < test.dat
336 .PP
337 To generate a pair of images corresponding to these two lights'
338 contributions:
339 .IP "" .2i
340 vwrays \-ff \-x 1024 \-y 1024 \-vf best.vf |
341 rcontrib \-ffc `vwrays \-d \-x 1024 \-y 1024 \-vf best.vf`
342 @render.opt \-o c_%s.hdr \-m light1 \-m light2 scene.oct
343 .PP
344 These images may then be recombined using the desired outputs
345 of light1 and light2:
346 .IP "" .2i
347 pcomb \-c 100 90 75 c_light1.hdr \-c 50 55 57 c_light2.hdr > combined.hdr
348 .PP
349 To compute an array of irradiance contributions according to a Tregenza sky:
350 .IP "" .2i
351 rcontrib \-I+ \-f tregenza.cal \-b tbin \-bn Ntbins \-o sky.dat \-m skyglow
352 \-b 0 \-o ground.dat \-m groundglow @render.opt scene.oct < test.dat
353 .PP
354 To perform an annual simulation of 365 daily sun positions in photon mapping
355 mode:
356 .IP "" .2i
357 rcontrib \-I+ \-h \-V \-fo \-o c_%s.dat \-M lights \-ap contrib.pm 365
358 scene.oct < test.dat,
359 .SH ENVIRONMENT
360 RAYPATH path to search for \-f and \-M files
361 .SH BUGS
362 We do not currently compute contributions or coefficients properly
363 in scenes with participating media.
364 A single warning will be issued if a scattering or absorbing medium
365 is detected.
366 .SH AUTHOR
367 Greg Ward
368 .SH "SEE ALSO"
369 cnt(1), genklemsamp(1), getinfo(1), mkpmap(1), pcomb(1), pfilt(1),
370 ra_rgbe(1), rcalc(1), rcomb(1), rfluxmtx(1), rmtxop(1), rpict(1),
371 rsensor(1), rtrace(1), total(1), vwrays(1), ximage(1)
372
