root/Development/ray/doc/man/man1/rcontrib.1
Revision: 1.20
Committed: Wed Oct 19 18:23:14 2022 UTC (3 years, 1 month ago) by greg
docs: made use of "virtual" and "secondary" sources more consistent
1 .\" RCSid "$Id: rcontrib.1,v 1.19 2020/09/10 17:52:46 greg Exp $"
2 .TH RCONTRIB 1 5/25/05 RADIANCE
3 .SH NAME
4 rcontrib - compute contribution coefficients in a RADIANCE scene
5 .SH SYNOPSIS
6 .B rcontrib
7 [
8 .B "\-n nprocs"
9 ][
10 .B \-V
11 ][
12 .B "\-t secs"
13 ][
14 .B "\-c count"
15 ][
16 .B \-fo
17 |
18 .B \-r
19 ][
20 .B "\-e expr"
21 ][
22 .B "\-f source"
23 ][
24 .B "\-o ospec"
25 ][
26 .B "\-p p1=V1,p2=V2"
27 ][
28 .B "\-b binv"
29 ][
30 .B "\-bn nbins"
31 ]
32 {
33 .B "\-m mod | \-M file"
34 }
35 ..
36 [
37 .B $EVAR
38 ]
39 [
40 .B @file
41 ]
42 [
43 rtrace options
44 ]
45 .B octree
46 .br
47 .B "rcontrib [ options ] \-defaults"
48 .SH DESCRIPTION
49 .I Rcontrib
50 computes ray coefficients
51 for objects whose modifiers are named in one or more
52 .I \-m
53 settings.
54 These modifiers are usually materials associated with
55 light sources or sky domes, and must directly modify some geometric
56 primitives to be considered in the output.
57 A modifier list may also be read from a file using the
58 .I \-M
59 option.
60 The RAYPATH environment variable determines directories to search for
61 this file.
62 (No search takes place if a file name begins with a '.', '/' or '~'
63 character.)\0
64 .PP
65 If the
66 .I \-n
67 option is specified with a value greater than 1, multiple
68 processes will be used to accelerate computation on a shared
69 memory machine.
70 Note that there is no benefit to using more processes
71 than there are local CPUs available to do the work, and the
72 .I rcontrib
73 process itself may use a considerable amount of CPU time.
74 .PP
75 By setting the boolean
76 .I \-V
77 option, you may instruct
78 .I rcontrib
79 to report the contribution from each material rather than the ray
80 coefficient.
81 This is particularly useful for light sources with directional output
82 distributions, whose value would otherwise be lost in the shuffle.
83 With the default
84 .I -V-
85 setting, the output of rcontrib is a coefficient that must be multiplied
86 by the radiance of each material to arrive at a final contribution.
87 This is more convenient for computing daylight coefficeints, or cases
88 where the actual radiance is not desired.
89 Use the
90 .I -V+
91 setting when you wish to simply sum together contributions
92 (with possible adjustment factors) to obtain a final radiance value.
93 Combined with the
94 .I \-i
95 or
96 .I \-I
97 option, irradiance contributions are reported by
98 .I \-V+
99 rather than radiance, and
100 .I \-V-
101 coefficients contain an additonal factor of PI.
102 .PP
103 The
104 .I \-c
105 option tells
106 .I rcontrib
107 how many rays to accumulate for each record.
108 The default value is one, meaning a full record will be produced for
109 each input ray.
110 For values greater than one, contributions will be averaged together
111 over the given number of input rays.
112 If set to zero, only a single record will be produced at the very
113 end, corresponding to the sum of all rays given on the input
114 (rather than the average).
115 This is equivalent to passing all the output records through a program like
116 .I total(1)
117 to sum RGB values together, but is much more efficient.
118 Using this option, it is possible to reverse sampling, sending rays from
119 a parallel source such as the sun to a diffuse surface, for example.
120 Note that output flushing via zero-direction rays is disabled with
121 .I \-c
122 set to zero.
123 .PP
124 Output flushing at fixed intervals may be enabled with the
125 .I \-x
126 option, which specifies the number of records
127 (-c accumulations) before each flush.
128 If the
129 .I \-y
130 option is also set, then periodic flushing is disabled and the
131 output size for an RGB image is the taken from the x and y dimensions.
132 In lieu of periodic flushing, a flush may be forced as mentioned above
133 by sending a sample with a zero direction vector, although you
134 must still send a full record of rays before output occurs.
135 .PP
136 If progress reports are desired, the
137 .I \-t
138 option specifies a time interval in seconds for reports sent to
139 standard error.
140 This requires that the number of input samples is known, meaning a
141 .I \-y
142 parameter has been specified.
143 .PP
144 The output of
145 .I rcontrib
146 has many potential uses.
147 Source contributions can be used as components in linear combination to
148 reproduce any desired variation, e.g., simulating lighting controls or
149 changing sky conditions via daylight coefficients.
150 More generally,
151 .I rcontrib
152 can be used to compute arbitrary input-output relationships in optical
153 systems, such as luminaires, light pipes, and shading devices.
154 .PP
155 .I Rcontrib
156 sends the accumulated rays tallies
157 to one or more destinations according to the given
158 .I \-o
159 specification.
160 If a destination begins with an exclamation mark ('!'), then
161 a pipe is opened to a command and data is sent to its standard input.
162 Otherwise, the destination is treated as a file.
163 An existing file of the same name will not be clobbered, unless the
164 .I \-fo
165 option is given.
166 If instead the
167 .I \-r
168 option is specified, data recovery is attempted on existing files.
169 (If
170 .I "\-c 0"
171 is used together with the
172 .I \-r
173 option, existing files are read in and new ray evaluations are added
174 to the previous results, providing a convenient means for
175 progressive simulation.)\0
176 If an output specification contains a "%s" format, this will be
177 replaced by the modifier name.
178 The
179 .I \-b
180 option may be used to further define
181 a "bin number" within each object if finer resolution is needed, and
182 this will be applied to a "%d" format in the output file
183 specification if present.
184 (The final integer will be offset incrementally
185 if the output is a RADIANCE picture and more than one modifier has
186 the same format specification.)\0
187 The actual bin number is computed at run time based on ray direction
188 and surface intersection, as described below.
189 The number of bins must be specified in advance with the
190 .I \-bn
191 option, and this is critical for output files containing multiple values
192 per record.
193 A variable or constant name may be given for this parameter if
194 it has been defined via a previous
195 .I \-f
196 or
197 .I \-e
198 option.
199 Since bin numbers start from zero, the bin count is always equal to
200 the last bin plus one.
201 The most recent
202 .I \-p,
203 .I \-b,
204 .I \-bn
205 and
206 .I \-o
207 options to the left of each
208 .I \-m
209 setting are the ones used for that modifier.
210 The ordering of other options is unimportant, except for
211 .I \-x
212 and
213 .I \-y
214 if the
215 .I \-c
216 is zero, when they control the resolution string
217 produced in the corresponding output.
218 .PP
219 If a
220 .I \-b
221 expression is defined for a particular modifier,
222 the bin number will be evaluated at run time for each
223 ray contribution.
224 Specifically, each ray's world intersection point will be assigned to
225 the variables Px, Py, and Pz, and the normalized ray direction
226 will be assigned to Dx, Dy, and Dz.
227 These parameters may be combined with definitions given in
228 .I \-e
229 arguments and files read using the
230 .I \-f
231 option.
232 Additional parameter values that apply only to this modifier may be specified
233 with a
234 .I \-p
235 option, which contains a list of variable names and assigned values, separated
236 by commas, colons, or semicolons.
237 The computed bin value will be
238 rounded to the nearest whole number.
239 (Negative bin values will be silently ignored.)\0
240 For a single bin, you may specify
241 .I "\-b 0",
242 which is the default.
243 This mechanism allows the user to define precise regions or directions
244 they wish to accumulate, such as the Tregenza sky discretization,
245 which would be otherwise impossible to specify
246 as a set of RADIANCE primitives.
247 The rules and predefined functions available for these expressions are
248 described in the
249 .I rcalc(1)
250 man page.
252 .I rcalc,
253 .I rcontrib
254 will search the RADIANCE library directories for each file given in a
255 .I \-f
256 option.
257 .PP
258 If no
259 .I \-o
260 specification is given, results are written on the standard output in order
261 of modifier (as given on the command line) then bin number.
262 Concatenated data is also sent to a single destination (i.e., an initial
263 .I \-o
264 specification without formatting strings).
265 If a "%s" format appears but no "%d" in the
266 .I \-o
267 specification, then each modifier will have its own output file, with
268 multiple values per record in the case of a non-zero
269 .I \-b
270 definition.
271 If a "%d" format appears but no "%s", then each bin will get its own
272 output file, with modifiers output in order in each record.
273 For text output, each RGB coefficient triple is separated by a tab,
274 with a newline at the end of each ray record.
275 For binary output formats, there is no such delimiter to mark
276 the end of each record.
277 .PP
278 Input and output format defaults to plain text, where each ray's
279 origin and direction (6 real values) are given on input,
280 and one line is produced per output file per ray.
281 Alternative data representations may be specified by the
282 .I \-f[io]
283 option, which is described in the
284 .I rtrace
285 man page along with the associated
286 .I \-x
287 and
288 .I \-y
289 resolution settings.
290 In particular, the color ('c') output data representation
291 together with positive dimensions for
292 .I \-x
293 and
294 .I \-y
295 will produce an uncompressed RADIANCE picture,
296 suitable for manipulation with
297 .I pcomb(1)
298 and related tools.
299 .PP
300 Options may be given on the command line and/or read from the
301 environment and/or read from a file.
302 A command argument beginning with a dollar sign ('$') is immediately
303 replaced by the contents of the given environment variable.
304 A command argument beginning with an at sign ('@') is immediately
305 replaced by the contents of the given file.
306 .PP
307 .I Rcontrib
308 supports light source contributions from photon maps generated by
309 .I mkpmap(1)
310 with its
311 .I -apC
312 option. Enabling photon mapping is described in the
313 .I rtrace
314 man page along with its relevant settings. In photon mapping mode,
315 .I rcontrib
316 only supports contributions from light sources, not arbitrary modifiers.
317 The
318 .I -b
319 option is supported along with its associated ray variables, as
320 discussed above. Ray coefficients are also supported via the
321 .I \-V-
322 option. Using fewer photons than there are light sources for the photon
323 density estimates results in omitted contributions, thus the bandwidth
324 is clamped accordingly and a warning is issued.
325 .SH EXAMPLES
326 To compute the proportional contributions from sources modified
327 by "light1" vs. "light2" on a set of irradiance values:
328 .IP "" .2i
329 rcontrib \-I+ @render.opt \-o c_%s.dat \-m light1 \-m light2 scene.oct < test.dat
330 .PP
331 To generate a pair of images corresponding to these two lights'
332 contributions:
333 .IP "" .2i
334 vwrays \-ff \-x 1024 \-y 1024 \-vf best.vf |
335 rcontrib \-ffc `vwrays \-d \-x 1024 \-y 1024 \-vf best.vf`
336 @render.opt \-o c_%s.hdr \-m light1 \-m light2 scene.oct
337 .PP
338 These images may then be recombined using the desired outputs
339 of light1 and light2:
340 .IP "" .2i
341 pcomb \-c 100 90 75 c_light1.hdr \-c 50 55 57 c_light2.hdr > combined.hdr
342 .PP
343 To compute an array of irradiance contributions according to a Tregenza sky:
344 .IP "" .2i
345 rcontrib \-I+ \-f tregenza.cal \-b tbin \-bn Ntbins \-o sky.dat \-m skyglow
346 \-b 0 \-o ground.dat \-m groundglow @render.opt scene.oct < test.dat
347 .PP
348 To perform an annual simulation of 365 daily sun positions in photon mapping
349 mode:
350 .IP "" .2i
351 rcontrib \-I+ \-h \-V \-fo \-o c_%s.dat \-M lights \-ap contrib.pm 365
352 scene.oct < test.dat,
353 .SH ENVIRONMENT
354 RAYPATH path to search for \-f and \-M files
355 .SH BUGS
356 We do not currently compute contributions or coefficients properly
357 in scenes with participating media.
358 A single warning will be issued if a scattering or absorbing medium
359 is detected.
360 .SH AUTHOR
361 Greg Ward
362 .SH "SEE ALSO"
363 cnt(1), genklemsamp(1), getinfo(1), mkpmap(1), pcomb(1), pfilt(1),
364 ra_rgbe(1), rcalc(1), rfluxmtx(1), rmtxop(1), rpict(1), rsensor(1),
365 rtrace(1), total(1), vwrays(1), ximage(1)
366
